F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > So I got my downpipe!
proTUNING Freaks
      11-15-2012, 05:23 PM   #1
slmdgee
Usofstance
78
Drives: 328I 6SPD
328i 6spd Downpipe Install And Video!!
So i should be installing it tm, just wondering i know i will have a check engine light. The big problem is i dont want to have the light come on and go to the dealership. So should i get the bms check engine light fix? How do you install the bms engine light fix. Let me know i am a little confused.
With the downpipe the car shouldn't have problems rite? Lolz. :confused0068
UPDATE
Update after doing 25miles!
Inside view
Update 11/20/12
2013 328i 6MT Bagged
IG Stu_UnitedStatesOfStance
United States Of Stance
      11-15-2012, 08:52 PM   #2
brian99997
45
Drives: slowly
So the way the two O2 sensors work is that one reads before and one reads after the catalyst. Removing it causes the car to think it has a bad cat so most cars will throw a light but it should not result in limp mode or anything like that.
I personally wouldn't take a car with a downpipe into the dealership because it's really obvious looking unless you already know your service guy is cool but he probably isn't because you haven't shared enough ale with him.
I have basically a fancy o2 sensor with its own computer that sends a fake value back to the ecu based on what it reads that I've used on a 2010 Porsche most recently so I know you can lie to the ECU to avoid the code all together but I'm not sure if a simple $25 O2 simulator can lie to the newer cars but that is the route I would look for.
      11-15-2012, 09:31 PM   #3
slmdgee
Usofstance
78
Drives: 328I 6SPD
Thanks for the reply i just wasn't sure how it works on a turbo car... I had a g37 with full bolt ons and never had a issue. So i got 200 miles on the car i might just wait till 500 and do the down pipe? What you guys think? I really hate the autostart button it really annoys me! Hahha
      11-15-2012, 10:49 PM   #4
brian99997
45
Drives: slowly
aFe says "A check engine light will emitt and aFe recommends using a programmer but it is not necessary" in the product docs so they are saying the car will not go into limp mode or anything crazy but the light will be on.
I don't really believe in break-in but I never plan on keeping a car more than 20k miles so I personally would install the downpipe and everything you plan on having the first day you drive it :P Enjoy the car
As for autostart, my dealer won't disable it but there is supposed to be a BMW instruction to the service departments to be able to do it if you check with them and get lucky. Short of that, coding for $20 was effective for me because autostart is annoying.
      11-16-2012, 02:22 AM   #5
topcat87
No_Country
35
Drives: F30
pls install it and let us know if u do get a cel
      11-16-2012, 06:49 AM   #6
slmdgee
Usofstance
78
Drives: 328I 6SPD
Alright guys i think ill do it today than as soon as i get out of college. I cant wait for my coil overs to come in!!! They said about 3 weeks
      11-16-2012, 07:34 AM   #7
topcat87
No_Country
35
Drives: F30
could you take a video of before and after as well of the downpipe. Would like to know how much more noiser it will be
      11-16-2012, 07:53 AM   #8
rado
Drives: F30 328i M Sport
You may be able to avoid a CEL by using a "mini cat O2 sensor CEL fix", from Big Daddies Garage (easy to find with Google). You would use this with the second (rear) O2 sensor. It's an O2 sensor adapter that has a built-in miniature catalytic converter. I haven't tried this on my F30, but I have used one for track days with my Exige, and it worked fine. This may be a cheaper and simpler solution than patching the ECU.
(no affiliation with Big Daddies Garage, just a satisfied customer)
HTH,
-Ed
2013 F30 328i M Sport
2008 Lotus Exige S240
      11-16-2012, 07:58 AM   #9
slmdgee
Usofstance
78
Drives: 328I 6SPD
Okay ill try to do it today, just a little hard since the hurricane wiped my house. Ill try my best.
      11-16-2012, 08:11 AM   #10
topcat87
No_Country
35
Drives: F30
damn, lucky ur car is intact!
      11-16-2012, 08:27 AM   #11
slmdgee
Usofstance
78
Drives: 328I 6SPD
It wasn't man, i actually owned a g37s 6spd with all bolt ons it got flooded :X. So i found this one in va and i got it ordered to me. My car is the one with the bluetooth and usb removal :X
      11-16-2012, 04:07 PM   #12
slmdgee
Usofstance
78
Drives: 328I 6SPD
Well here's how the exhaust sounds stock Check out this video on YouTube:<br/><br/>
I didn't have time to do it today. Maybe next week now since my whole weeknd I am busy
      11-17-2012, 01:43 PM   #13
slmdgee
Usofstance
78
Drives: 328I 6SPD
i just installed it, deff hear the turbo more.
      11-17-2012, 02:05 PM   #14
slmdgee
Usofstance
78
Drives: 328I 6SPD
Here is a video
      11-17-2012, 03:38 PM   #15
Joshhleee
///M Enthusiast
Joshhleee's Avatar
30
Drives: '12 F30, '15 x5 5.0, '15 M4,M5
any intake? and can you smell gas or anything when youre driving.
      11-17-2012, 03:54 PM   #16
slmdgee
Usofstance
78
Drives: 328I 6SPD
Everything is stock!! No smell! It's getting colder so it deff back pops alot more when in first gear. Also pull harder but i have like 300 miles now. I dont really like to beat on my car and i am going to break it in properly.
      11-17-2012, 07:57 PM   #17
bcl0328
127
Drives: 2012 328i
wow, you can really hear the turbo spool and it sounds more gurgly.
      11-17-2012, 08:05 PM   #18
slmdgee
Usofstance
78
Drives: 328I 6SPD
Yes it does, the install was fairly easy.. I sprayed pb blaster on all the nuts and everything came off easy. I got pictures which i will post when i charge my phone. I tried doing a little diy hahah
      11-18-2012, 06:28 AM   #19
topcat87
No_Country
35
Drives: F30
cool, thanks for vid. sounds really loud now makes me more undecided
      11-18-2012, 07:26 AM   #20
slmdgee
Usofstance
78
Drives: 328I 6SPD
It's really not that loud. Literally inside no drone. Sounds how it should of sounded from the factory.
      11-18-2012, 09:54 AM   #21
slmdgee
Usofstance
78
Drives: 328I 6SPD
another update
      11-18-2012, 10:18 AM   #22
bcl0328
127
Drives: 2012 328i
you know you can turn off the auto start stop right?
f30post
