BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - California > SMOG TIME for 2007's
      11-14-2012, 01:39 PM   #1
joec500
125
Drives: it has 4 wheels
Has anyone taken their tuned N54's to SMOG yet. Thankfully mine are not due until January (NO MORE SNIFFER in 2013), but I was curious how crazy the technicians go over visuals, as I have Downpipes installed, but my secondaries are in place on the stock exhaust. I can easily re-install my stock intake, so I am not worried about that.
2007 E92 6MT SGM: MusicarNW Level 2, Procede Rev 2.5, FFTEC/Vishnu LPFP with Flexfuel Sensor and Flash, M3 Offset V701's, WaveTrac LSD, Michelin PSS, Downpipes, M3 Control Arms, TCKline D/A Suspension, LCI Tail lights, Lux AE's, ER Charge Pipe, DCI's, Mtech Front and Rear, M3 Sideskirts, HPF Stage 1 Clutch
      11-14-2012, 01:45 PM   #2
Mahhvinn
EUROPROJEKTZ
Mahhvinn's Avatar
187
Drives: backwards
2008 E90 335i  [7.00]
Some of the places I've been to and my buddies, the smog tech checks the engine bay and exhaust. They didn't check the cats. Good luck Joe! I'm sure you'll pass!
LTMW|SPEEDELEMENT|EUROPROJEKTZ
#TeamStretchNPoke
      11-14-2012, 05:48 PM   #3
Elliott@DetailAddict
300
Drives: E90
Marvin... which spot? PM?
      11-14-2012, 06:33 PM   #4
wafflesmartano
wafflesmartano's Avatar
Drives: 2007 335i sedan
2007 BMW/335i  [0.00]
Has anyone heard about whether or not it is illegal now to have High Flow Cats installed?
      12-30-2012, 10:56 AM   #5
joec500
125
BUMP, anyone getting Smogged in JAN, I heard they are removing the Sniffer test
http://www.bar.ca.gov/80_BARResource...esentation.pdf
      12-30-2012, 11:15 AM   #6
skinrock
Agent Smith
skinrock's Avatar
270
Drives: 2016 i8
2016 BMW i8  [10.00]
Old post, but anything except stock is technically illegal, even in states that don't check for emissions.
The i8 needs a V8 amirite?
      12-30-2012, 12:12 PM   #7
Bimmer Barney
Bimmer Barney's Avatar
1250
Drives: 2011.5 E90M ZCP
Mine is in October. I'm going to install a DP Fix then, turn JB4 off and then go for it. If I fail the first time I'll put everything back to stock and go back. I expect to pass the first time, though...No Sniffer this year
      12-30-2012, 03:30 PM   #8
acdHQK713K
acdHQK713K's Avatar
231
Drives: Car
I know with Cobb that the dp codes are still present when you check the obd port so it won't pass. But maybe it will with a dp fix?
      12-30-2012, 05:23 PM   #9
Bimmer Barney
1250
Correct. Same with JB4; gotta have it turned of for OBDII readiness, and thus need the DP Fix so suppress codes for c@less dp's
      01-01-2013, 03:29 PM   #10
64-46
Drives: e91xi
On a side note. If you're in SF, get your smog check at the Chevron on Market and Castro. $30 for the test and certificate. Tell them you saw the deal on Google. I just got mine done 2 weeks ago.
      01-01-2013, 04:23 PM   #11
sourphish
115
Drives: '22 i4 M50
Dang, mine is due in 2 weeks -_-. Worried about visual like intake and secondary cats removed..
2022 i4 M50, Dravit Grey. fully loaded minus the carbon fiber bits and 20" wheel package
2007 E92 335i, 6MT, Sparking Graphite, ZPP, ZSP, Nav, Logic7 (Sold)
      01-01-2013, 09:56 PM   #12
ign335i
Drives: 335i e92
I am concerned about the DCI and meth for visual inspection.
      01-01-2013, 10:58 PM   #13
joec500
125
The intake is easy...Not sure about Meth though. I don't have my primary cats!!!
      01-02-2013, 12:48 AM   #14
ign335i
Drives: 335i e92
I don't think they will remove underbody trays. I wouldn't worry about them if you have a dpfix.
      01-02-2013, 02:52 PM   #15
300
Drives: E90
So for sure no more sniffers?
DP fix and engine bay with stock air box should be good to go?
      01-02-2013, 02:59 PM   #16
joec500
125
According to this:
http://www.bar.ca.gov/80_BARResource...ual%202013.pdf
NO, but I will try to drive by a SMOG shop to ask.
      01-02-2013, 03:10 PM   #17
300
Drives: E90
You rock, thanks man.
Please let us know your findings.
      01-02-2013, 03:20 PM   #18
joec500
125
http://www.importtuner.com/tech/impp...missions_laws/
      01-02-2013, 07:29 PM   #19
joec500
125
UPDATE, stopped by two Smog stations, Tailpipe will still be used, they will eventually phase it out, but unknown when...I am guessing secondaries only will not pass :\ Time to get some downpipes.
      01-02-2013, 07:52 PM   #20
Route 16
I got lei'd
Route 16's Avatar
Philippines
844
Drives: '10 E90 M3
You have secondaries but no primary? Did you happen to ask removal of 2ndary will not pass but pass with primary? (for us NA cars)
      01-02-2013, 07:57 PM   #21
hipnotic
hipnotic's Avatar
149
Drives: e92 335i
2008 335i coupe  [7.00]
how about removal of muffler in the case of a muffler delete will that pass the visual inspection of the smog test or they don't even do a visual inspection?
      01-02-2013, 07:59 PM   #22
joec500
125
Nope...sorry.
Yah I have stock exhaust on my aftermarket DP's
