Simple as plugging in a 55watt ballast?
11-13-2012, 05:20 AM | #1 |
170
Rep 3,828
Drives: AzuriteBlack 335i E92
Hi Guys,
Unsure whether it has been done. in my quest for brighter low beam output, I was thinking of upping the power of the ballast. I have 6k bulbs in there,and I know I will get better brightness using 4300k but I like the look of the 6k too much. I have my lights open right now putting in some Led AEs and blacking out my chrome bits, so now is a good time to ask whether I need to do any other work whilst its all open. Here are my questions -do you think the e92 headlights handle the extra heat from. 55watt ballast? -would the 55watt ballast work with the stock projectors and existing 6k d1s bulbs? Or would any of those parts need to be changed? -would any general 55watt ballast work with these lights? Cheers guys!!! |
11-14-2012, 10:59 AM | #2 |
3441
Rep 79,211
I would not recommend it.
It could possibly fry the control module or the ballast on the base of the bulb. Both the controller and the bulb would need to be 55 watt too. The BMW d1s ballast controllers are pretty fragile, there have been countless people buying buying aftermarket bulbs and frying the OEM hardware. This is why you should replace your hardware with quality products and matching controllers. Last edited by Jeff@TopGearSolutions; 11-14-2012 at 02:47 PM.. |
11-15-2012, 02:26 PM | #3 | |
Brotographer
88
Rep 1,741
But if I were to do a high-wattage D1S ballast, I would get your OEM ballast and wiring harness modified, rather that going with an aftermarket ballast. The OEM Hella projectors can take the heat. Even if an aftermarket 55W D1S ballast existed, I wouldn't want it. I wouldn't trust that startup current with the FRM. But the issue is that you have crappy bulbs. No matter how you cut it, there is colored glass on this bulb to give them a 6000K output. I'm assuming they're also aftermarket? HIDplanet has measured noticeably lower output with 6000K aftermarket vs. 4300K OEM bulbs. Fine for fogs and such, but I wouldn't ever put something that I know reduces nighttime vision in my headlights. I gather you want a whiter light than the stock 4300K bulb? What you want is the new gold-standard of OEM bulbs (on new F10 I believe, several Benz's), the OSRAM CBI (cool blue intense). It creates a 5000K color by using a different salt mixture rather than a color tint, so there's no lumen loss from the glass. In fact, the lumen output is slightly higher than the defacto Phillips 4300k OEM bulb. Comine that with the higher color temperature, and it definitely appears brighter. Cheaper than OEM Phillips replacements through BMW, you can get them from TheRetrofitSource.com http://www.theretrofitsource.com/pro...ducts_id=17166 for $200. I think they'll have a black friday sale though, so it would probably be wise to wait about a week. It may exclude these bulbs, but can't hurt! And if you decide the CBI's (after the 8-12 hours of burn-in time) aren't bright enough, you can get a wiring harness and the OEM ballasts boosted, and then you'll be throwing out absurd lumens. |
11-15-2012, 11:07 PM | #5 |
Where'd my VTEC go?
481
Rep 6,067
There is no 55w ballast that will fit the oem headlight. The ballast is integrated with the headlight housing.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
11-16-2012, 09:51 AM | #7 | |
Brotographer
88
Rep 1,741
11-16-2012, 11:10 PM | #8 | |
52
Rep 1,357
Drives: '08 e92 335i COBB 4.01 Stage 1
11-17-2012, 06:19 PM | #9 | |
Brotographer
88
Rep 1,741
The ballasts will have to be disassembled, and modifications will have to be made. Ramping up the ballast is not a terribly complex process (I believe it's just one resistor that changes, I'll try and dig up a DIY) and building the harness isn't difficult (splice on some terminations, and a trip to the junk yard for connectors if they're hard to come by) BUT you are setting yourself up for an expensive mistake if it doesn't go well. TL;DR get rid of your low-output aftermarket bulbs, get CBI's = impossible to screw up. |
