Head count of VANOS replacement individuals
11-12-2012, 08:30 PM | #1 |
Rainbow Racer
1008
Rep 2,540
I'm suspecting future VANOS's failure for my vehicle (12/07 build date), 69K miles, used M1 0w40 or Castrol 0w30
Symptoms: 1)Marbles in a can like noise during cold start in the interior of the car 2) "warble-warble" like noise at the top of the engine near the VANOS timing gear during the same conditions 3) repeated VANOS codes and CEL lights after WOT runs I'm just gathering information from others. Please post if you've had a complete VANOS assembly replacement done, not VANOS solenoid-related stuff. Post your build date, type of oil, milage, and symptoms. I'm wanting to keep the thread alive for future buyers or current owners who may have the same issue. I guess no BMW is safe from VANOS issue's.
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
11-12-2012, 08:50 PM | #2 |
31
Rep 439
I had to get a new vanos unit at 89k miles...wasn't cheap either
I used BMW oil Symptoms were half engine light, no boost, marble like sounds
2011 335is "Redrkt" 6 MT
DocRace 6266 Single Turbo - Fuel it stage 3 LPFP - Fuel it PI - spec stage 3+ clutch - mfactory SM flywheel - 100% E85 - VRSF 7.5" intercooler - VRSF charge pipe w/ HKS BOV - JB4 - MHD back end flash 768 whp 695 ft lbs - E85 - 32PSI |
11-13-2012, 06:15 PM | #3 |
21
Rep 354
11-13-2012, 06:17 PM | #4 |
26
Rep 497
vanos are super easy to swap theres a DIY here.
08' 335xi 6MT Space Metallic Grey Premium, Nav, Cold weather, Sport Procede 2.5, DCI, Forge DV, PWM, Scoops, KW V1, ETS 5" FMIC, VRSF Downpipes, M3 Skirts |
11-13-2012, 08:30 PM | #5 |
Rainbow Racer
1008
Rep 2,540
You may be confusing VANOS unit with VANOS solenoid, which are two completely different things
-Loe P.-
11-13-2012, 08:31 PM | #6 |
Rainbow Racer
1008
Rep 2,540
Thanks for the update. Did you have marbles-in-a-can noise at idle with a feather foot on the throttle too?
-Loe P.-
11-13-2012, 10:22 PM | #7 |
335
Rep 4,633
My car is FBO and 28k miles.
When im inside the car, no music, I hear a very faint, like marbles griding or like a buzz sound at idle, and when I give slight partial throttle. Is this vanos?
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
11-14-2012, 04:37 AM | #8 |
31
Rep 439
It was almost 7 months ago now but I believe somewhere in the woods of 1800-2000$
11-14-2012, 05:40 AM | #9 |
Rainbow Racer
1008
Rep 2,540
is it a cycling buzzing noise? or is it constant?
-Loe P.-
11-15-2012, 11:23 PM | #10 |
335
Rep 4,633
Yea its like a buzz buzz buzz buzz on and off on and off.. And then when I rev, it gets a lil louder and faster buzbuzbuzbuzbuzz..
11-16-2012, 05:55 AM | #11 |
Rainbow Racer
1008
Rep 2,540
That's the sound i'm hearing too
-Loe P.-
11-16-2012, 06:59 AM | #12 |
55
Rep 1,690
VANOS Solenoid replacement: http://www.e90post.com/forums/showthread.php?t=486201
11-16-2012, 07:42 AM | #13 |
99
Rep 508
What vanos codes are you getting? That will really help pinpoint the issue.
The sounds that you are hearing could be normal for direct injection. My 335i was noisy as hell and it always worried me. My 135i sounds the same as does my friends 335i. All of these cars have had the vanos solenoid's replaced. We were throwing vanos codes after hard pulls. |
11-16-2012, 08:29 AM | #14 | |
335
Rep 4,633
Car has 28K miles, and the noise has been present for about 5-8K miles. with the radio off, its an annoying whiring sound. whiring comes on strong, and then quiets down, comes back strong, quiets down, does this sound quickly and on going. Im going to remove and clean my intake/exhaust solenoids with wd40 and compressed air, see if the sound goes away. I have ruled out the DME fan inside the ECU box, and the boost solenoids, since my issue, the sound moves with RPM's in neutral.. So boost solenoids aren't rpm dependent, and these two should be making noise always, not sometimes, and not when warm only.
11-16-2012, 01:30 PM | #15 |
Mad Linux Guru On The Loose
1121
Rep 5,397
Drives: 2008 335i Sedan, 2023 M3
Are we talking about the VANOS solenoids here? If so, then count me in for 1 intake vanos solenoid dead at 28K miles. Replaced it in my own garage in under 30 minutes.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
11-16-2012, 01:37 PM | #17 |
125
Rep 3,004
mine died at 20k miles.
2007 E92 6MT SGM: MusicarNW Level 2, Procede Rev 2.5, FFTEC/Vishnu LPFP with Flexfuel Sensor and Flash, M3 Offset V701's, WaveTrac LSD, Michelin PSS, Downpipes, M3 Control Arms, TCKline D/A Suspension, LCI Tail lights, Lux AE's, ER Charge Pipe, DCI's, Mtech Front and Rear, M3 Sideskirts, HPF Stage 1 Clutch
11-16-2012, 01:39 PM | #18 |
Knower of all Things Useless
29
Rep 254
I had mine replaced around 40K under factory warranty, Been fine for the last 23K now.
07, always used BMW oil, same marble sound everybody else has been talking about. |
11-16-2012, 03:35 PM | #19 |
125
Rep 1,546
11-16-2012, 03:55 PM | #20 |
22
Rep 251
Mine went when I was around 53k, exhaust side vanos solenoid. Threw a code for it under acceleration, which resulted in limp mode. Bought a replacement and has been good ever since.
11-16-2012, 05:06 PM | #21 |
Rainbow Racer
1008
Rep 2,540
hey guys, strictly VANOS only, not VANOS solenoid. This noise is caused by the VANOS unit itself starting to fail.
-Loe P.-
11-17-2012, 12:22 PM | #22 |
1121
Rep 5,397
Codes. At first the code was popping up every 3-4 months. Then it started happening more frequently. It got worse and I was getting the CEL almost once per week during normal city driving. So I bought one and replaced it.
No noises at all. Just went bad.
