New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      11-08-2012, 11:01 PM   #1
AsiaKid
54
Drives: GTR/Gallardo Spyder/X5
just did golf tee mod :D
Pinched the tube and ziptied it..sounds much deeper at startup....can tell its definitely the right side that has the new deeper sound..
now gonna switch the pipes from 1 out each side to 2 out each side..save like 3K on a new exhaust (and the wait) pretty happy with the sound..was just looking for a bit more from the exhaust but rather spend the 3K on a LSD
      11-09-2012, 07:22 AM   #2
Hoa
No_Country
513
Drives: BMW
this is what i did on mines
if you have JB4, you also have an option to leave it open by adjusting the settings in it. no mod required and can go into quiet mode at any given time
      11-12-2012, 04:53 AM   #3
ManiacGT
ManiacGT's Avatar
85
Drives: Z4 sDrive 35i
I like the fact you've got the parts to block this. I simply put a screw inside the pipe, which grips and blocks the airflow. I can simply unscrew it from the pipe if required. I've had to do this on mine as the flap rattles from time to time.
      11-12-2012, 08:18 PM   #4
AsiaKid
54
The flap rattles? at what rpm?
btw, having taken off the rear msport bumper to install diffuser..i realize that for anyon doing the golf tee mod, if you want to have easier/neater access (like Hoa's pics), taking off the bumper makes it so much easier.
      11-12-2012, 10:40 PM   #5
Hoa
No_Country
513
Drives: BMW
search for "rubber vacuum cap" on eBay. i just happened to have these laying around because they came with my SS Brake lines
      12-27-2012, 06:54 PM   #6
haspi
13
Drives: SDrive35i
different method
Guys - I have been reading about the golf tee mod for a while. I really want to take a shot but now I'm a bit confused.
I just saw this video.
Is this an easier way of doing the same thing? What do you think?
      12-28-2012, 05:06 AM   #7
ManiacGT
ManiacGT's Avatar
85
You're watching a video for a 335i which (of course) is a different car.
On the z4 you simply block the vacuum pipe near the rear right back box.
      01-22-2013, 10:57 AM   #8
mpbruin108
Mpbruin108
mpbruin108's Avatar
180
Drives: I'm a hypermiler
so this golf tee mod is putting you rubber things on 2 vacuum outlets? Can I do this without lifting the car on a lift? Does it sound deeper only at startup or while you drive too? I already have a catless DP so I wonder how much louder the car will be? Crazy enough, this is the first I've heard of this exhaust mod. I must be in a Z hole.
So Cal Drivers: Get your Tires from us to get them QUICKLY (same or next day) and at a GREAT Deal.
2244 Tyler Avenue, South El Monte| Call: 626-443-8539
Active: 2015 BMW i8, 2024 BMW iX, 2018 Mclaren 720s
      01-22-2013, 01:54 PM   #9
Hoa
No_Country
513
Drives: BMW
i think all bmw has this valve. i remember my e36 had it as well. it just make the car sound louder overall
      01-25-2013, 01:12 PM   #10
ZheHbKa
ZheHbKa's Avatar
77
Drives: the Wind
2014 BMW 335 Xi  [10.00]
sometime i hear the flap rattling on a cold start with hard acceleration, and under all other conditions its quiet
2014 F30 335 X-Drive | 6-MT | Alpine White/Coral Red | ZMM ZDH ZDA |
      01-25-2013, 04:32 PM   #11
ManiacGT
ManiacGT's Avatar
85
Yeah it seems pretty common. I hated the rattle, albeit occasional, hence the mod to get rid of it and it sounds so much better!
      01-26-2013, 09:44 AM   #12
Desmo85
Desmo85's Avatar
81
Drives: E60 / E87 / E89
The Z has the same plug like the E9X, but in a different Location:
      02-06-2013, 06:26 PM   #13
goaljnky
Drives: 2011 S Drive 3.5 IS
so why exactly is it called a golf tee mod?
      02-07-2013, 12:20 AM   #14
VailM3
61
Drives: 2011 Z4 35is
and the point in this plug would be?
      02-07-2013, 12:38 AM   #15
Desmo85
Desmo85's Avatar
81
It does the same like this:
EDIT:
Quote did not work out, scroll up and watch the Video
      02-07-2013, 03:00 AM   #16
VailM3
61
EDIT:
Ah ok so pulling that plug nets the same results as actually blocking the hose on both ends then?
      02-07-2013, 03:21 AM   #17
Desmo85
Desmo85's Avatar
81
Indeed, it is just the easier and "cleaner" way to do it. Since no Jackstands or Lifters are needed, and you can not damage anything. And to reverse it you just plug it back in.
http://www.youtube.com/watch?feature...&v=p5phT3LPl80
      02-07-2013, 03:50 AM   #18
VailM3
61
I will have to try this when i get home tonight. No issue with any dust/dirt falling down there i hope. Though that cover seems very hard to get to with those pics to say the least.
      02-07-2013, 05:12 AM   #19
Frogg
Frogg's Avatar
France
Drives: Z4 e89 red pearl/Black roof
So, is it the same rsults than unplugg the vaccum hose?
      02-07-2013, 05:47 AM   #20
VailM3
61
Apparently it is as a few posts have been stated. Going to give this a whirl tonight but unclear how to stick ones hand down such a tiny opening. I had serious issue with lux halos as the slot was so small to get my hand in there to twist it on correctly.
      02-07-2013, 10:26 AM   #21
Frogg
Frogg's Avatar
France
Because the first mod was made With a real tee of golf for plugged the vacuum Line
      02-07-2013, 10:35 AM   #22
Frogg
Frogg's Avatar
France
For the lux i asked my wife i have too much big fingers
zpost
