      11-06-2012, 03:15 PM   #1
Kirst
Australia
20
Drives: BSM e82 135i
130i N54 upgrade
Just wanted to sound out people's thoughts on upgrading to the N54?
I've heard it's doable but fiddly at best due to wiring?
      11-09-2012, 01:54 PM   #2
xcharles1
Drives: E87 130i
You read my mind, BMWlady. I was just thinking about that the other day. Can't wait to hear some thoughts from other members.
      12-10-2012, 05:47 AM   #3
Newby
1Mtech
Drives: BMW
Engine+gear box will be a bolt in affair, I'm unsure about the prop shaft. Run N54 DME+CAS(and engine harness) and key set plus locks barrels from a 135i. You would need to get the car programmed, I suspect the JBE and DSC will be ok.
Would be advantageous to buy a 135i that had been rear ended so you could fit all the front end items(cooling system, intercooler etc) too.
This conversion would be costly and could turn into a shit fight without dealer resources. I havent personally looked into this conversion, but there is no reason it wouldn't be easy enough to achieve with some forward planning.
      12-10-2012, 03:37 PM   #4
Dackelone
European Editor
Dackelone's Avatar
Germany
10528
Drives: N54 e82
Its been done before. Last year a 1Addict member from Sweden(?) finished a black e87, 1M hatch conversion. It was a black car and had some seriously flared rear fenders. The whole car was very hot looking!
      12-10-2012, 07:17 PM   #5
ALEJANDRO
17
Drives: White 1M 2012
any way we can see a pic of the car?
      12-11-2012, 04:29 AM   #6
Newby
1Mtech
Drives: BMW
Fairly sure the N54 powered E87 Dack speaks of was in an issue of Performance BMW mid way through this year?
Update - you would also need JBE from doner N54 vehicle along with CAS and DME
      12-12-2012, 11:17 PM   #7
Venom
Venom's Avatar
374
Drives: M2 Competition
2008 BMW 135i  [8.50]
Here you go http://www.1addicts.com/forums/showt...light=1m+hatch
Simple search of 1m and Hatch turned it up
      12-13-2012, 09:11 PM   #8
flinchy
126
Drives: E82 135i
I'm doing it myself, New engine, gearbox, custom driveshaft
Yep, perfectly 100% bolt on, driveshaft lengths depend if you swap out the diff and halfshafts too, for a 130i though, custom driveshaft yes, not too exxy though.
The DME, i'm currently looking through BMW TIS stuff just to confirm it's all perfectly PnP.. i'm 99% sure, it's a cakewalk.. only coding is AT>MT if that's the job.
don't need new lock barrels if you keep your old key, just swap the physical key into the new fob lol
i didn't know enough when i started, but really nothing has come up that's TOO hard so far, everything is pretty smooth.
it's a good chance to 'upgrade' things like that intercooler, if you don't get a full halfcut... things like radiator/PS/etc. all fit on as same parts.
you NEED the new gearbox, starter motors are 100% opposite sides of the bellhousing, as well as bolt patterns differing.
no you don't, the JBE between models has the same things.. you'd be surprised at how many parts are IDENTICAL between models
http://tis.spaghetticoder.org/s/view.pl?1/09/87/85
ED: ok, it depends what module you're talking about, and what side f the swap it's on
anything on the car side of the ECU, don't matter, it'll work with all your auxiliary stuff no worries...
engine side, of course it matters and it should come with the engine!, it's more a part of the ECU than anything else in that case...
      12-13-2012, 09:54 PM   #9
Newby
1Mtech
Drives: BMW
^^ wow awsome swap to undertake man!!!
I think N54 powered E87 is the best swap around atm. In regards to JBE, the JB(junction box) itself should be fine, I wasnt sure whether the JBE(junction box electronics control unit) would need to be swapped. It would plug into the E87 JB tho if it was required. It was just a thought, Id be interested to know what you did here?
LOL about Key, I must have been having a moment... not sure what i was thinking haha. Just need FOB to match dme/cas, which im sure would come with your engine/half cut/wreck you would buy.
      12-14-2012, 12:27 AM   #10
flinchy
126
Drives: E82 135i
where abouts is the JBE located?... i found the part numbers/what it looks like blah blah.. i'm still trying to get the TIS software working, it's a huge PITA..
all i have here is the CAS module (6943830) and the DME (inc the white plastic box it sits in, 7604567 ) as well as the 335i dash cluster.. plus the fully wired up engine of course
and the key fob, yeah
the guy who did the full 1m style swap, there's no real 'details' on it, nor does he reply... everythign i do, will be well documented.. any hurdles i find, i'll put em on the internet for anyone else that wants to swap in an N54 >_<
      12-14-2012, 03:24 AM   #11
Newby
1Mtech
Drives: BMW
JBE is in LH front passenger footwell mounted on firewall. The JB Incorperates the fuse box, and the JBE( this control unit is the "gateway" module on e8x,e9x, etc). It slides into the junction box and there is 2 x plugs on the front of the control unit.
      01-05-2013, 11:23 PM   #12
Kirst
Australia
20
Flinchy,
Where are you getting the driveshaft done? I'm having trouble sourcing somewhere in Australia for a custom job
I've sourced an engine from a 135, the original owner is upgrading his engine, I assume it will still have the same issues you've mentioned?
      05-12-2013, 09:32 PM   #13
flinchy
126
Drives: E82 135i
Flinchy,
i know who you are now, just stumbled on this thread lol
heaps of places, like hardy spicer, driveline services aus etc. easy to find on google lol
and since i just stumbled on this thread, i just re-read this post and as always, worry about things i haven't checked --
http://realoem.com/bmw/showparts.do?...93&hg=61&fg=25 - list of 130i JBE part numbers
and if you search globally for any of those part numbers, it shows various 3 series (inc 335i/335xi) and 1 series (e87 at least, not E82).. hard to find much on the JBE, but even when it needs replacing, it's not a module that needs coding it seems, it's just a quick replace.. i gathered all it does it
and
http://www.bawarec.ru/manuals/3er/e9...3er-e90-12.pdf
is a training document for the electronics system, basically says the JBE can be configured as per equipment loadouts... so keeping my current JBE is the best idea since it's going to be set up for the same equipment (it means my rear windows and doors should still work as it's THIS module that knows they're there.. i think lol)
and upon further reading, it's what bridges the internal electronics with the DME, so thanks for making me look it up.. eventually. haha. i was still kinda wondering how it all hooked up.
      01-03-2021, 03:34 PM   #14
Marshan
Drives: 2007 e90 335i
2006 130i n54 swap
Hey , guys need detailed info on swapping my wrecked 2006 335i motor into a 2006 130i
Cheers
1addicts
