BMW X3 Forum
BMW X3 Forum
      11-02-2012, 07:46 AM   #1
BMWs
16
Drives: 2012 X3 35i
Alternate Tire Size for 245/50-18
Wondering if there was another more common tire size than the factory 245/50-18. Would like more of a selection of tires but don't want to affect speedometer readings, etc.
      11-02-2012, 11:43 AM   #2
Amber
Drives: 2012 X3 Sport 19" rims
My 2012 35i with sport package came with 245/45-19" tires on all wheels. I plan to change for non runflat 235/50-19". I dont like the existing low profile and prefer the non run flat tires. It will only have a small effect on the speed reading, that I can live with. As far as the runflat issue is concerned, I cant remember the last time I had a flat tire.
      01-05-2013, 04:45 PM   #3
Gerber92
Drives: 2013 2.8 M Sport
Did you change your tires already? How is the ride on the new tire size plus non RFT?
      01-06-2013, 08:54 PM   #4
Amber
The problem I have run into is what tire to buy
      01-07-2013, 02:45 PM   #5
Teemo Panda
*Bimmerpost Plasti Dip Guru*
Teemo Panda's Avatar
83
Drives: E53, E46-M3, E70, F25-X3
2013 BMW X3  [5.66]
Go to Tirerack.com
It has a great selection of tires and rims, it's always has an updated car specs.
      01-19-2013, 08:46 AM   #6
Gerber92
Latitude Tour HP by Michelin is what I'm looking at. I have it in my Acura MDX. I believe that it is also use by Lexus as their OEM tires on their RX 350.
      01-19-2013, 03:44 PM   #7
Amber
19" rim dimensions and tire size
According to BMW CANADA the following, is the actual dimensions of the 19" alloy wheels and they do not recommend a aspect ratio higher than 45 for the 19" wheel. BMW CANADA will probably not support a higher aspect ratio than the original 18" tires on your vehicle.
The dimensions of the 19 inch double spoke alloy wheels are as follows: 8,5Jx19 EH2+ with an offset of 38mm. We do not recommend any tires with an aspect ratio higher than 45 for the 19inch wheel base. This is a result of extensive testing by BMW AG. Any non approved changes to the tire or wheel package would make the vehicle unpredictable and could cause issues with the suspension/steering.
Do you really believe BMW CANADA on this issue?
xbimmers
