TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > i drive not always right
      08-04-2007, 10:25 PM   #1
cal99_99
29
Drives: 2007 328i coupe
My navigation sometimes tells me to make some non sense turns, like to a one way street or make a immediate u turn when I merge to freeway. Is that the Navi CD problem or software problem? I am wondering if I could use this excuse to get my idrive updates for free. anyone has the same problem?
TiAg 328i coupe with zsp, nav, ca, rearshade, power seats, black leatherette with burl walnut trim.
Placed order:9-16-06
production started:10-18-06
Production finished:10-24-06
waited at port of exit:10-25-06
Shipped: 11-01-06
Arrived:11-16-06
At VPC:11-21-06
At dealer:11-25-06
delivery: 11-27-06
      08-04-2007, 10:30 PM   #2
E92_335
E92_335's Avatar
156
Drives: G20 330i
it has happened to me once but not very often.. its not usualy the navigation and sometimes the address maybe moved a little and the navigation gets confused but i doubt there is a new update considering you have a 2007 3er
      08-04-2007, 10:34 PM   #3
BMW F22
BMW F22's Avatar
3566
Drives: ///M235i
yeah I've had problems like that about 2 or 3 times now. For example I wanted to go to this place and the house # was 90. The Nav told me to turn right and "you've arrived". I did that and noticed the numbers were decreasing so I just did a u-turn and found the correct address.
I guess it's not really a big deal but if it happens a lot then it could get annoying. No nav system is perfect though. I mean even sites like Mapquest get directions wrong sometimes too.
      08-05-2007, 01:20 AM   #4
Aija
29
Drives: 335Coupe 6-Speed!
Be aware that if you live in a newly development area, (the house is < 2 years old) your GPS system may not pick it up.
      08-05-2007, 04:02 AM   #5
SoYank
SoYank's Avatar
571
Drives: 2009 E90 335i MT
I think it's a problem with the navi disc information. For example, my navigator, Luna, directs me to take a street and turn right onto another but there are bollards across the entry. When the disc is updated with the knowledge of the bollards, this should go away.
One thing I've noticed is it tries to take the "crow's path". The simplest way to my house from the main drag is composed of two left turns. However, Luna wants me to bear left, turn right, turn right, turn left, turn left, turn right, and then turn right into those bollards. Presumably, without the bollards she'd tell me to turn right, turn left, turn left, you've arrived. Some of the streets Luna says to take are only two cars wide with cars parked on both sides.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7
European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor
Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269
      08-05-2007, 08:32 AM   #6
nyc3r
nyc3r's Avatar
112
Drives: E90
They are mostly correct, but there are cases will your nav will tell you to turn into 1 way street against traffic.. just use it in combination with your best judgement and you should be okay.
      08-05-2007, 09:15 AM   #7
poiney
36
Drives: 328i coupe
I figure that once in a while the map is not updated properly which causes the error.
I once had it route me to a wrong location that I know it also routed me correctly previously (e.g., a major location that hasn't changed). Bizarre. Fortunately, it only happened once.
      08-05-2007, 10:51 PM   #8
Black Chili
IT geek
Black Chili's Avatar
Drives: M4 Black Saphire Metalic
I was about to loop/onramp right onto an overhead highway from an underneith road and the latest Euro DVD told me to make a plain left onto the highway as though they were at the same level (a left turn would have met me with an embankment the freeway sits on top of),
On the up side the white arrow WAS pointing right to indicate that I should be taking the freeway onramp/upramp, so I'd have to think about that for a while. Was it half right or half wrong??
      08-06-2007, 07:48 AM   #9
SteveMD
SteveMD's Avatar
195
Drives: 2016 F10 535i MSport
Keep in mind that the location of a particlular street number/house is 'guessed' or interpolated.
There is no way that the exact locations of every building/dwelling in North America are on a 4Gb DVD.
2006 E90 330i (retired)
2009 E90 335i (retired)
2012 E70 X5 50i M Sport (retired)
2016 F10 535i M Sport
      08-09-2007, 02:35 PM   #10
richlux
Drives: 330i Blk/Blk Prem/Sport/Nav
It's definitely a problem with the Nav DVD. I've had 3 DVD versions (2006.2, 2007.1, and 2007.2). The first two were dead on when navigating to my Work address. The latest one, however, has me passing the building and taking two out of the way turns to get where I need to go. When I put the older DVD back in, the navigation is correct.
Rich
      08-09-2007, 04:46 PM   #11
msimon18
Retired
msimon18's Avatar
19
Drives: Z4 s30i
I have the latest and it still sucks !! IN 3 attempots to get appropriate directions in the past 8 weeks since I have had the car it has NEVER got me to where I wanted to go CLEANLY.
M3 GTR - 1/5 scale - 4.2 HP w/ Collari hydraulic brakes - would you believe ~80 MPH on straightaway !!
      08-09-2007, 05:39 PM   #12
killer_bee
16
Drives: '07 328i, '15 435i
Navi should really be programmed to how people prefer to drive:
1. fewer turns when going from A to B
2. major straight road with lights better than a smaller straight road with stop signs crossing multiple major roads
3. general preference of right turns to left turns especially when there are no left turn signals
#1 alone would help a lot- Hate it when it goes right,left,right,left when I could have made just one right turn in two blocks.
      08-09-2007, 08:22 PM   #13
zenmaster
1577
Drives: '17 M2
You can report errors here: NAVTEQ Map Reporter™. Navteq may work it in to the next release.
      08-16-2007, 05:17 PM   #14
tman
tman's Avatar
44
Drives: 2014 i3 BEV
2014 i3 BEV  [0.00]
Rich
+1. I've had the exact same problems. 'Cept I can't find the older 2007.1 version.
OMG! Born Electric 10/17/2018!
2014 I01 i3 BEV
2011 E91 328i xDRIVE TOURING
| 2010 F83 X3 3.0i xDRIVE | 2006 E90 330i 6MT (Ret)
