F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Halogen to LED replacement for DRLs
Studio RSR
      10-29-2012, 05:47 PM   #1
NiceNotRiceBMW
15
Drives: 2012 Mineral Grey Sport 328i
Hello, after many hours of searching I can't find an led replacement bulb for the DRLs. Any help?
      01-29-2013, 04:07 PM   #2
echangf30
13
Drives: 14' F30 MSport 335xi
so how is working out? Did you add the leds with no problem?
      01-30-2013, 02:01 AM   #3
loz3rxfreak
19
Drives: 2012 328i
http://www.ebay.com/itm/130826331101...84.m1497.l2649
these actually work nicely i have it installed in my car
      01-30-2013, 10:29 AM   #4
echangf30
13
thanks man. any luck on the fog leds? will they work? i have 15watts on them and i think they are smd led's. let me know. im lost
      02-01-2013, 07:09 PM   #5
Casualvic
26
Drives: 328i xdrive
how in the world did you install them???? i bought a set...messed up one stock bulb trying to get it off the first harness that connects to the wire to the car!!! big headache
      02-02-2013, 01:04 AM   #6
loz3rxfreak
19
Drives: 2012 328i
http://store.ijdmtoy.com/BMW-F30-PW2...ghts-a/446.htm
i used this guide to help me. hope it helps
      04-08-2013, 09:51 PM   #7
momo3605
208
Drives: M340i LCI, 718 GTS 4.0
Has anyone got these working on a 2013 328i? In the comments it says the guy's 2013 throws error codes
      06-01-2013, 02:40 AM   #8
ahmk
Drives: e90-2011
ijdmtoy gave me a error too, any ideas?
      06-03-2013, 03:41 PM   #9
mjmonjure
mjmonjure's Avatar
14
Drives: 2013 F30
I have them working. They are tricky to get in. I started with only one pin in the connector, pushing it in and when I got resistance, moving it slightly. After about 10 seconds of this, it's almost as if this punches a hole through or it finally finds the existing hole. I then, pull it out and do the same to the other connector with the other bulb leg.
Then I put the both in at the same time, no errors. I've taken these out several times (wasn't sure I liked the color at first, then because I brought the car into BMW) and put them back in with no problem.
      06-03-2013, 06:34 PM   #10
DXL XLR8
47
Drives: F30
The 2013 F30s will throw an error code when install "error free" leds. I made a write up on how to code them out if you have knowledge on coding.
http://www.f30post.com/forums/showthread.php?t=829691
      07-14-2013, 01:57 AM   #11
MarkyMarkOz
Australia
Drives: F30 328
Ont the compatibility checker on this ebay page, the result for a search on a 2013 328 series says that these are not compatible.
Anyone found DRL replacements that work with no codes and are supported as compatible with the canbus?
      07-15-2013, 09:46 PM   #12
mcorf
Drives: 740 Li
Anyone try these? I called Bavarian Auto Sport and was told they are compatible with the 24 Watt DRL.
19227 PIAA SUPERWHITE BULBS - 1 PAIR - 1156 (SINGLE ELEMENT) $13.95
      07-22-2013, 12:32 PM   #13
F30 Epal
19
Drives: F30 320i
Is this compatible for the f30 320i? And how hard is it to replace the DRL?
My Instagram
Alpine White '14 BMW 320i 6-Speed MT: GSR Tuned, H&R Sport Springs, Injen CAI, Borla catback exhaust, ER FMIC/Chargepipe/Downpipe, VMR V810 wheels
      07-22-2013, 07:41 PM   #14
Deacon
Drives: 2012 BMW 328i Sportline
I installed the iJDM DRL in my Halogen 2012 F30 sportline -- Loved them for 2 weeks then all of a sudden error codes constantly. I put up with the constant error codes display/alerts for 2 days. I thought maybe it would go away or relearn since there wasn't an issue for the first 2 weeks..
NOPE -- error city --
I actually returned them last week with a tracking number since I was in my 30 day return window... So will see If I get back my $30 bones..
Good luck if you want to try it but didn't work for me.
2012 Black Sapphire Metallic 328i Sportline | Technology | Premium | Heated Seats
      07-29-2013, 12:23 AM   #15
MarkyMarkOz
Australia
Drives: F30 328
I have installed a set of LED replacements for my Halogen DRL's, unfortunately I ordered 2 sets instead of 1. So I have one for sale at my cost but will post to you free. PM me if interested.
      07-29-2013, 01:36 PM   #16
zibawal
36
Drives: 2012 X5D
any pictures or videos of your install pls
      07-30-2013, 02:36 PM   #17
Stiunit
Stiunit's Avatar
23
Drives: 2020 M340I
interested in some pics also
      08-27-2013, 08:36 AM   #18
josb0513
Drives: BMW 2013 328i Xdrive
^ ditto
      08-28-2013, 03:56 PM   #19
TheTradingJD
Drives: 2013 F30 328i Xdrive
Added LEDs to drls
I added too, very easy. (no errors (yet, knock on wood)).
      08-28-2013, 03:57 PM   #20
TheTradingJD
btw guys, no idea how to make the images appear upright. When I uploaded them they were normal but now they're flipped, any ideas? But, just save and rotate and they'll look normal. Like the lights?!
      08-28-2013, 04:17 PM   #21
TheTradingJD
also, very strange. In real life they look constant, but when video record them on iphone they look like they're flashing. Anyone know why? thx
      08-28-2013, 07:36 PM   #22
TheTradingJD
u just open ring looking thing on the lights that says "open close" pull the drl light from headlight enclosure, pull out the bulb, put in led bulb (test to make sure works, if not flip it around and test again), then put bulb back in the hole you took it from inside the headlight (make sure clicks in, you'll know when it's in right). Finally, put the ring thing back and close it. Then close hood. done
f30post
