rear end
08-04-2007, 05:16 PM | #2 |
29
Rep 957
Drives: 2022 X3 M40i
Overkill for a high-torque car. If I change the rear-end ratio, I will go with a taller gear. With a 4.11, you will have to use second gear, since the wheels won't get traction in first. If you were running huge slicks with a spool, you may have a reason for going that route, but if you plan on mods similar to most, lighter wheels, PROceed, and exhaust, you will find that you will lose traction with one wheel only receiving power.
I recently had an LSD installed and find acceleration in the straights to be improved. Around curves, it's really quite phenomenal. I see no need whatsoever in going with a shorter rear-end. |
08-05-2007, 05:34 PM | #4 |
35
Rep 1,169
Drives: 67 GT500,69 Boss 429, 335i
I agree with what is posted above... If anything i would want taller gears. 1st is practically useless with procede.
-Mat
Tuned E92 335, Riss Racing downpipes! And hopefully over 400RWHP!! |
08-05-2007, 07:12 PM | #5 |
576
Rep 6,750
Yes, I would think traction would be a problem without the LSD. However, an E46 M3 owner had switched to 4:11 gearing and his car cooks.
08-05-2007, 09:25 PM | #6 | |
35
Rep 1,169
Mat
-Mat
08-05-2007, 09:30 PM | #7 |
29
Rep 957
and I don't think you'd want to run slicks in the rain, because you won't be going anywhere but sideways.
08-06-2007, 05:04 AM | #8 |
14
Rep 1,137
+1, 335i puts far more power to the ground than M3 from the launch up to some 4500rpm.
