Is this easier than golf tee mod?
08-03-2007, 06:51 PM | #1 |
Rep 143
By now everyone has heard about the little door in the driver's side muffler. Has anyone tried just unplugging the control module in the trunk instead of plugging the vacuum lines? Does it generate any error codes?
The module is located in the trunk, just below the tail lights. (Inside the driver's side access panel.) There is a vacuum line coming into the solenoid and another one exiting before passing down through the trunk floor. |
08-03-2007, 09:58 PM | #2 |
Too many Alex's, from now on, call me Beaufort
342
Rep 6,188
Yes its been done. Yes it generates error codes. No it does not produce any dummy lights on the dash. Yes it produces the same effect.
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip 16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone) 07 335i(gone) |
08-03-2007, 10:16 PM | #3 | |
e92
Rep 391
http://www.e90post.com/forums/showthread.php?t=69940 |
08-04-2007, 07:04 AM | #4 | |
Rep 143
I've seen lots of links on how to do the golf tee thing, but none said anything about any error codes. (That I remember.) FWIW I have no plans to disable the muffler flap, I just wondered why no one simply unplugged the electronic control solenoid for it or alternately removed/plugged the vacuum line at the solenoid in the trunk. Last edited by fer360; 08-04-2007 at 07:37 AM.. Reason: spelling |
08-04-2007, 07:55 AM | #5 |
375
Rep 1,428
I know I should probably search for this (I'm post-call, so bah), but while were on it... when one talks about "throwing an error code," etc, will this disappear once the "error" is corrected. For example, if I were to simply plug this module back in, would the error code disappear? And when you say that it won't show a dummy light on the dash, are the errors only seen by BMW (or whoever has a vehicle link)?
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
08-04-2007, 08:36 AM | #6 | |
Rep 143
Although I haven't installed one myself, I've noticed the instructions for a lot of aftermarket mufflers say to remove and plug the vacuum line. |
08-04-2007, 08:50 AM | #7 |
Rep 143
Access panel
For clarity, this is the driver's side panel that contains the solenoid. If you look down inside the hole below the tailight, you will see it. In fact, you can see the wires going to the solenoid, in the picture, at the bottom of the opening.
08-04-2007, 01:22 PM | #9 | |
e92
Rep 391
Namely, the code that computer STORES when you disconnect the solenoid. though the code won't throw a CEL or any sign of anything being wrong on your dash/i-drive, it is stored and a tech CAN read it. though i personally don't see anything going wrong just b/c that solenoid is unplugged and tech finds out about it, for the peace of mind, most decide to go with mechanical solution since it's not that hard to do anyways. SO perhaps when someone gives you a link, you should READ THE WHOLE THREAD before saying something. in fact, if you SEARCHED, you'd've found that thread. now go read that thread please. |
