Coolant flush
10-25-2012, 07:24 PM | #1 |
Rep 5
Coolant flush
I'm looking to flush my coolant for the first time and I was wondering if the car absolutely needs to be level or if using service ramps will be ok?
I was looking at flushing with Prestone super radiator cleaner or the super flush. Is there any benefit from one over the other? Also, my car has 124k miles on it (all highway) so any extra tips to help the longevity of my cooling system would be appreciated. |
12-01-2012, 01:46 AM | #3 | |
Team iTouge
121
Rep 2,101
Replace the thermostat. Even if it might not have failed, you'll never know if it does or not because there's no CEL or error code produced from it. Check all hoses for dryness, cracking, rips etc. And keep an eye on the water pump if you haven't changed it yet
12-01-2012, 06:36 AM | #4 |
17315
Rep 18,737
This is backwards. The T-stat will throw a code and will illuminate the SES light, so you will know when it goes bad. But "going bad" only means the heating element has failed in it, the t-stat will still operate properly. The only way to "keep an eye" on the waterpump is to scan the ECU for shadow codes that indicate a slow waterpump speed, which do not illuminate the SES. Once you find the code for a slow waterpump it means the pump is on the way out.
12-01-2012, 04:48 PM | #5 | ||
Team iTouge
121
Rep 2,101
12-01-2012, 04:52 PM | #6 |
sheesh!
14
Rep 195
I wouldn't sweat the thermostat by its self. Most electric water pumps die eventually.... And as preventative maintenance I would replace the pump and thermostat at the same time you drain the coolant with that type of mileage.
Yes, expensive but its better than being stranded somewhere when you don't want to |
