10-23-2012, 01:23 PM | #1 |
64
Rep 411
Automatic Car Wash
Realizing it is sub-optimal to utilize an auto wash, I think I may be forced into it as I have to turn my hose off or the pipes will freeze. Thoughts?
10-23-2012, 02:06 PM | #2 |
2762
Rep 5,082
bucket and sponge or better still a wollen mitten.
There's separate threads about detailing and washing cars but I would certianly never put my car through a automated car wash personally. |
10-23-2012, 03:03 PM | #4 |
Rep 261
This is how you do a propper car wash. With a bit of practice you are done in approx 30 minutes for a F11.
1: Spray the whole car with Bilthamber Surfex HD diluted 1:30. This stuff eats dirt and dust like nothing else and wont damage paint or wax when diluted 1:30 Leave on for five minutes. I make a mixture of total 6 liters and soak the car in this. 2: Rins off with a pressure washer. Now you car allready looks clean by most peoples standard (yes, it's that good) 3: Wash the car with a wollen mitten using the two bucket method with grit guards (google it) 4: Spray off all soap with a pressure washer 5: DRY the car. Make sure whatever you do use is not harsh and is 100% CLEAN. I recommend using chemical guys miracle dryer. Have two of them. One will dry your whole car, and have the second one for getting the last bits and parts. This is the least abrasive way to wash your car and is what is generally considered the "propper" way in the car detailing community. Even when washing it this way you do get swirelmarks, but you will get them much much slower than most other people. Polish you car once or twice a year and wash it this way and it will be a head turner all the time. Better than new. It has to be said that a bad hand wash is just as bad or worse (depending on the machine) then a automat. |
10-23-2012, 10:48 PM | #7 |
Rep 261
That usually leads to swirl marks. They actually tested this on the british show Fifth Gear. A regular cheap hand wash turned out to damage the car more then the automatic car wash. If you want to keep it clean, you need to take it to a detailer (expensive for the good ones) or do it your self.
10-24-2012, 07:27 PM | #8 | |
15
Rep 140
10-30-2012, 03:08 PM | #10 |
Rep 56
I've been hand washing my car but with winter weather coming, not sure what I am going to do either. Maybe bundle up and go out to the car wash bays where you can use the pressure washers on low setting. That way, I can shutdown my outside faucets for the winter.
10-30-2012, 07:45 PM | #11 |
350
Rep 2,937
Drives: 2013 Estoril 328i M Sport
10-31-2012, 11:07 AM | #13 |
64
Rep 411
Thanks for all you help. I finally came to my senses and found a place where I could use the wand and my own bucket.
That being said, anyone have any good lines on cloths/brushes to assist in washing rims? |
11-13-2012, 03:53 PM | #14 | |
500
Rep 1,580
I read your post with interest. I've just taken delivery of a F10 in Sophisto grey and as yet has never been washed. I'd like to keep swirl marks to an absolute minimum so have been looking for ways to best clean the car. This surfex stuff you mention - how do you apply it? Foam lance?. Also, I read somewhere that the best method of rinsing is just with an open ended hose?, and that its best to let it dry naturally so no contact is made with the paint? Thanks in advance. |
11-15-2012, 01:17 PM | #15 | |
Rep 261
I like to use a high pressure washer for rinsing. Most detailers I know about does. If you want to air dry the car, you would need some extremely clean water to make sure you don't get chalk marks and what not. Regular tap water usually won't cut it, and you need to dry it. You should also make sure surfex hd or soap doesn't dry on the paint. I like to do it indoors or in the shade with very little wind. |
11-16-2012, 01:48 PM | #16 |
1381
Rep 3,834
I run my Jet Black F10 through the local auto wash twice a month. I clay and wax my car with Zymol twice a year, so far the paint still looks new w/o visible swirl marks. However, I don't plan on keeping any of my any of my cars past 3yrs so I can't speak for long term effect.
If you have the time, use the 2 bucket with wollen mitten wash method mentioned above. Never wipe off after rinse, only dap dry. Always soap/rinse from top to bottom. Don't buy any car wash soap that claims that it comes with wax. Wax doesn't stick to your paint that way. If you can't wash it home, bring the buckets to the pressure car wash bay. Fill buckets with soapy water, rinse, soap the car, rinse, spot free rinse, and then dap dry with micro fibre or shammy. Clay/Wax your car at least once a year. |
11-30-2012, 11:40 AM | #18 |
Rep 261
12-03-2012, 10:43 AM | #19 |
64
Rep 411
Thanks for all your input and you've effectively talked me into avoiding the evil auto wash. That being said, does anyone have any tips for washing the undercarriage to remove salt?
12-19-2012, 08:44 AM | #20 |
Rep 10
01-30-2013, 02:54 AM | #21 |
Rep 56
