DIY: Installing E90 M3 Rocker Panels on a 335
10-21-2012, 08:24 PM | #1 |
I even mod my cereal
246
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
First off I want to thank DSBJ for his DIY on the E92 coupe for M3 rocker panel install. His DIY gave me courage to tackle this on the E90 model. On to the DIY. With that said, do NOT look at the E92 M3 rocker panel install as it is totally different than the E90 install.
I will be listing the fasteners/rivot part numbers in this area soon. starting out.....stock rockers Tools needed: Flat blade screw driver, Torx 30 ratchet and needle nose plyers. First step is situate the car in the best posistion to work on the rocker panels. My car is lowered on KW v1 coilovers and I decided to put it up on jack stands (in the front). On the underside of the rocker panel you want to unsrcew the back Torx 30 plastic bolts that hold the rocker panel. Once the black plastic torx 30 screws are all taken out you can manipulate the rocker panel a bit. You will want to go to the front of the rocker panel and pull lightly to pop out the rivots that hold the rocker panel to the body of the car. Once you have the stock rocker panel off you can inspect it for existing rivots. If any rivots are still attached to the body of the car you can pry them off with a flat blade screw driver. see pics. The white M3-specifc body rivot must be pushed into place as shown for it to work correctly. White M3-specific body rivots installed Next you will need to pull all but one of the green rubber grommets that are in the body of the car. These green grommets are for use with the 335-specific yellow clips that are on the stock rocker panels and are no longer used. YOU NEED TO LEAVE THE FIRST GREEN GROMMET IN PLACE AS IT IS USED WITH A 335-SPECIFIC YELLOW CLIP. The rest get pulled out. When installing the M3 rocker panel make sure to install the BOTTOM first. Slide the bottom UNDER the black felt under body cover, but make sure to get the rocker panel under the rivot that the plastic torx 30 screw goes into. Once the bottom portion of the rocker panel is PLACED you can now line up the white M3-specific body rivots and push them into place. They will "snap" into place. Lightly push on each one to get it to "snap". After the rivots are all in, now re-install the black plastic torx 30 rivots underneath the car. Again, make sure the black under body felt is OVER the rocker panel material. NOTE: For the area behind the front tire and in front of the rear tire will tuck in behind the rocker panel material. Make sure that all areas are fitting flush. Finished Product: Special thanks to LTBMW for making tweaks to the OEM M3 rocker panels.
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser Last edited by bigdaddycane; 10-22-2012 at 03:14 PM.. |
10-27-2012, 01:47 PM | #3 |
246
Rep 3,441
Thanks. I bought the parts from someone that had the work done at LTBMW. LTBMW does some modifications to the OEM M3 rockers. I don't think LTBMW sells the OEM M3 rockers for the 325/328/335 any longer because of fittment issues. I could be wrong, but that is the sense I got from them in conversations over the phone.
After going throught all this if I had to do it again, I would just buy the Sonic Tuning M3 rep rocker panels as they do not have to be modified and fit very well.
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser |
08-04-2013, 09:41 AM | #4 |
driver mod in progress
225
Rep 1,858
Drives: with both feet
Nice DIY - thanks!
08-15-2013, 08:59 AM | #7 |
246
Rep 3,441
I believe they modified an attachment section at the front of the rocker panel, but you would have to check with LTMWs as I bought them slightly used from an individual that bought them from LTMW.
Again, if I had to do it again, I would get the Sonic Tuning or another good replica side skirt as there is customization needed for the oem M3 rockers that is not needed for the replica versions.
08-16-2013, 01:36 AM | #8 | |
130
Rep 775
Drives: 2007 E90 328i
Performance Mods: ST Coilovers | R1 Concepts Premier Rotors w/Hawk HPS Pads | ECS Stainless Steel Brake Lines | OEM 219M Wheels | Bridgestone Potenza RE760 | Precision Euro Spacers | AA Race Headers | AFE Race Midpipes | Remus Powersound Quad Exhaust | AA Offroad Tune | RevMotoring Intake Pipe | Cyba Scoops
