The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Will These Fit On A 335xdrive?
      10-18-2012, 08:17 AM   #1
Cure12
Cure12's Avatar
Trinidad_and_tobago
29
Drives: 2011 335
19x8.5 front and 19x10 rear +30 front and +37 rear???
///Mods: ER CP, Helix FMIC, Dinan FFE, BMS N55 Intake, VRSF Catless DP, proTUNED...///
      10-18-2012, 10:42 PM   #2
Yvette
761
Drives: M
shouldn't be problem, as long as you have the right size tires.
      10-19-2012, 08:53 AM   #3
Cure12
Cure12's Avatar
Trinidad_and_tobago
29
Drives: 2011 335
thanks...after 61 views finally someone helps...what size would u recommend..
      10-19-2012, 10:27 AM   #4
SilverEmu
SilverEmu's Avatar
17
Drives: Car
Different tire brands/models have slightly different rolling diameter and thread width, even if size is listed as being the same. I think your wheel sizes work best with 235/35 F and 275/30 R (265/30, being another option). Whether it will rub or not depends on your ride height (is your car dropped?), on your car being an LCI or not (if sedan, can't tell from your profile) and, again, the tire brand/model.
      10-19-2012, 10:50 AM   #5
Cure12
Cure12's Avatar
Trinidad_and_tobago
29
Drives: 2011 335
Thanks...the car isn't dropped yet but will roll the fender when that time comes...it's an e90 lci...
      10-19-2012, 11:44 AM   #6
SilverEmu
SilverEmu's Avatar
17
Drives: Car
You should be fine then with the options I have listed...265 in the back might be a safer option, but it might look slightly stretched.
      10-19-2012, 12:35 PM   #7
Cure12
Cure12's Avatar
Trinidad_and_tobago
29
Drives: 2011 335
cool man thanks for the help...
      10-19-2012, 05:37 PM   #8
prairieoyster
Drives: 2011 335xi SE
You'll be fine. I'm running 8.5" ET35 and a 12mm spacer with a 235/35 on the front, 10" ET36 with a 275/30 on the rear, no roll.
No issues. DO IT!!
