10-17-2012, 07:44 PM | #1 |
Rep 12
Any way to get more growl out of 328i?
I have a baseline 2012 328i sedan, I was wondering if there is any way to get some more engine sound out of without opting for a 1200$ exhaust.
I really like how it sounds when you turn it on a cold start then the growl disappears. |
10-17-2012, 07:49 PM | #2 |
I plead the 5th.
523
Rep 1,519
Check this thread out, should be exactly what you're looking for -> http://www.f30post.com/forums/showthread.php?t=676468
edit: lol, just saw you were the most recent post in that thread. Have you tried it out?
-Matt
10-17-2012, 09:54 PM | #4 |
193
Rep 3,780
See my dyno thread below on the new exhaust.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc) '15 Buick Regal "T"(wife) '06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc) |
10-18-2012, 02:52 AM | #5 |
I plead the 5th.
523
Rep 1,519
Ah, I did it for kicks, it's pretty easy. Will require getting on your back and looking around the muffler section. There's a 'spring' loaded flap that, if you remove the 'spring', you can secure the flap open.
-Matt
10-18-2012, 08:34 AM | #6 |
193
Rep 3,780
For maybe $50 you could have the resonator cut out and straight piped. The standard exhaust is pretty well crafted. It's mostly 3".
10-18-2012, 12:22 PM | #7 |
Rep 12
I looked under next to the inside exhaust there is this small u shaped spring that connected in between 2 bolts, do I pull that out? How do i make the flap open?
11-30-2012, 08:19 AM | #9 |
Rep 53
Did any of you delete the resonator already?! I've changed the DP, and was willing to get a sporty sound. Deleting the resonator and using a race DP will make it sound good or maybe it's too loud?!
11-30-2012, 12:32 PM | #11 |
Rep 34
Personally, I've run into one individual with a "racey" downpipe and found that it, to me, just sound really good. There's not a lot of drone inside the cabin as the sound-proofing done by BMW is quite good but, take my opinion with a grain of salt.
12-02-2012, 01:03 AM | #12 |
210
Rep 3,288
Drives: anything given a chance
Downpipe without cat's will give you what you're after for a bit less than an axle-back. As a few guys above said, the stock system is actually pretty good work.
I'll be springing for the M Performance exhaust myself rather than fiddle with the DP's this time around, but as you said that's out of your price range. |
