BMW X3 Forum
BMW X3 Forum
      10-12-2012, 08:33 AM   #1
SE3P_to_E90
231
Drives: E90 Msport + E83 Msport
Calling All X3 (e83) Owners. Advice needed.
Hi all,
My fiance and I are in the market to pick up another vehicle... we're looking into the 2004-2006 X3's -- with 60k-90k miles.
I'm wondering if any current (or previous) owners had any issues with this car. What should I look out for, and what can I expect from such a vehicle with 60k+ mileage?
Thanks in advance for your help, and any advice will be greatly appreciated.
Edit: CarMD car report on vehicle health and common problems - attached.
      10-12-2012, 09:47 AM   #2
Derek8819
Derek8819's Avatar
35
Drives: 2015 F80 M3
My wife has a 09 with about 35k on it. The SUV is great, rides nice and has good power, even beat my friends FR-S in it. Reliable it has not been though, but mine is a CPO. We have had the entire PS system replaced because of a bad hose that ran the system dry and we have had the efan replaced. They are known for random electrical gremlins too, we can drive along and randomly all of the lights will turn off and on, cant reproduce it and no codes.
Like I said though, we really like it, but I do not know if I would own one out of warranty.
      10-12-2012, 10:07 AM   #3
SE3P_to_E90
231
^ thanks for the heads up... PS System = power steering? That's a scare...
Warranty claims are what scare me the most - since i'll be picking up an X3 w/o warranty... I've heard about X3/X5's having quite a few electrical gremlins... let alone, all BMW for that matter. My e90 has some issues itself - radio stopped working >:[
      10-13-2012, 03:18 PM   #4
Agentss
Drives: Black/black 2005 E83 X3 3.0iA
I have a 2005 X3 SAV and have seen similar electrical
gremlins, I push a button to do one thing and something else happens with nothing reporting a code or bring reproducible.
Make sure you check the air intake rubber boot, if it feels dry and/or hard replace it. With the tempature extremes they will suddenly get a small crack sending error codes, better to change it on your terms then when it fails randomly
Dana
      10-30-2012, 03:46 PM   #5
MFox_Iowa
Drives: '04 X3
Unhappy Mid-Throttle stumble
As posted elsewhere we have the mid-throttle stumble, Wide open it runs fine, but a gradual passing situation (normality) makes you wonder if you are going to make it.
I have been to two dealers several times with many parts replaced. Still stumbles. Theory is that BMW will interface with Dealership at next oil change. This has been going on from 85,000 to the current 113,000 miles.
Car is fun to drive, yes, reliability is otherwise reasonable. Had the rear outside hatch switch fail while under CPO, but they would not cover it. Also, the battery in a key failed. This is not good as BMW says the battery can be replaced, but even if you use the Web solution to replace the battery you will need another key to reprogram the dead battery key!!! Not a pretty picture if you are many miles away from home and obviously do not carry a spare key with you. <<Dumb Design>>
      10-31-2012, 09:15 AM   #6
SE3P_to_E90
231
^ thanks for the heads up... I think i'll be making a purchase either for a 2004 or 2007 this weekend. I'll be sure to post updates.
      10-31-2012, 12:35 PM   #7
SE3P_to_E90
231
On a different topic, are there any x3 owners who have run a staggered setup?
A lot of the X3's i've been looking at have some pretty ugly wheels on them, and I would like to use my other set of rims if it won't cause any issues...
The wheels i have in mind are factory 197's -- which is staggered (18x8 front, 18x8.5 rears). I know BMW advises against deviating from a square setup on X-drive vehicles... however, i've seen some 335xi drivers run a staggered setup without issue.
Any advice on this would be helpful! Thanks in advance!!!
      10-31-2012, 02:50 PM   #8
kq328xi
kq328xi's Avatar
Drives: BSM e92 328xi, Flamenco Red X3
2008 e92 328xi  [0.00]
I bought my wife a 2005 2.5i X3 last year with 75k miles on it. It is a blast to drive. I second the comment on the air intake boot on the M54 engine. I changed the intake boot after a CEL was thrown. It was a pain to remove all the hoses, but it was pretty easy to do. You may also hear a 'whoosh' while accelerating which could intake a small intake boot tear.
On the staggered set-up: I have a e92 328xi with staggered wheels. The key is to keep the rolling diameter similar between front and rear. My 18"'s are 225/40 F and 255/35 R for a rolling diameter difference of ~0.2%. The tire diameter calculator on the e90post Wheels & Tire section is a good place to do the math automatically. Conventional wisdom is to keep difference less than 1%.
2008 328xi e92/Black Sapphire Metallic/Saddle Brown/18" 220M Reps w 225/255 Falken 452's
Next: Sways and springs
      11-02-2012, 08:28 AM   #9
SE3P_to_E90
231
Thanks for the huge heads up! Going to look at (a very promising) x3 today. will post pictures later
      11-06-2012, 06:39 AM   #10
JDAURIA
JDAURIA's Avatar
725
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
Picked up an 06' X3 M-sport with only 58k on the clock. Get a PPI done before purchase, check cylinder heads for cracking, transfer case, rear springs.
Overall, no problems
2016 F31 328iX | Alpine White | Black | ///MSport | iND | Eventuri | AC Schnitzer | MPerformance | 513M | Michelin PS4 |
2005 | 330CiC | Sparkling Graphite | Black | 6MT | ZHP
Purchase your W///AGON Stickers Here: https://f30.bimmerpost.com/forums/sh....php?t=1930190
      11-08-2012, 12:06 AM   #11
alexsih
Drives: 2014 X3 M Sport F25
Upgraded 19" Style 179 with non-standard rubber,
staggered: 19x8 F and 19x9 R
rubber: 245/45R19 F and 275/40R19 R
no rubbing - I was glad I went only 19" and slighty larger rubber
softened the ride a little, otherwise the sport suspension was a killer
also the above setup was very close match for the front & back outer diameter for the tires
see: http://x3.xbimmers.com/forums/showthread.php?t=684276
'14 F25 X3 xDrive35i M Sport
      11-11-2012, 10:02 PM   #12
stevexjet
Drives: '07 X3, '04 M3, '05 Element
2004 BMW M3  [0.00]
We experienced bad front struts on ours at 80k. Easy to fix but $231 a piece for the parts. I know a tech that said he has seen a few front suspension issues over the years so our issue might not be all that isolated.
      11-13-2012, 01:36 PM   #13
SE3P_to_E90
231
Thanks for all the heads-up guys. Ended up taking delivery a couple weeks ago, and couldn't be happier. It's a 2007 x3 3.0si with m-sport everything. Just went to get it officially inspected, and all is well!
Alexsih - i wish i can see your car pictures with those wheels, but my work probably blocked the pictures. I'm currently on the sport-package rims (unsure what style), but they're 19"s and they're staggered! 235 front, 265 rears. I'm with you on the harsh ride - the sport suspension and low pro tires make the car really stiff.
      11-14-2012, 01:27 PM   #14
Tallest
Tallest's Avatar
1307
Drives: 911
2011 911  [10.00]
both my mechanic and BMW sales guy said to me that if I\m in a market for a 4x4 bmw to by E83 as it is the most reliable BMW from late models. It has very cheap suspension and parts are tried and tested.
Later I read a review on it which listed all the issues and in the end said the car is super reliable for its age, price etc.
Problem areas as others too said>
- blocked drains means water in car, check carpets to be dry!
- failing springs *esp on cars used on poor roads
- gearbox software glitch which means bad uphill performance
- turbos that fail on diesels
- water gets to headlight washer motors
In Europe, a 2l diesel with manual is considered the best and most reliable car to buy from BMWs I\ve seen in most magazines.
997.2
F30.F11.E86.E90.E90.E36
      11-14-2012, 02:47 PM   #15
SE3P_to_E90
231
Thanks for the heads up on this, research. Looks like you've done your HW as well
My BMW mechanic said these cars are pretty bulletproof. the only area where he sees problems -- are with the transfer cases. Typically, he said the TC's fail because the owner tows boats/trailers -- which this car really isn't meant to do. Other than that, minimal electrical problems -- it seems the electrical components are the same as it's e46 counter parts.
Overall, no issues thus far :knock on wood:
The only thing I need to get used to is gas mileage. I've been getting 24mpg on my e90 n52 (combined city/hwy), and i'm getting 17mpg on my e83. But, this isn't a big deal as i know i'm not driving a leaf lol.
      11-21-2012, 08:46 AM   #16
SE3P_to_E90
231
are there any X3 (e83) owners who have the factory alarm installed? I got my alarm installed from the dealer the other week, and i'm a little disappointed...
First, the alarm is pretty quiet. The acoustic arm/disarm is far more "quiet" than the alarm on my e90... Sometimes, i have to lock/unlock the car a 2nd time because i can barely hear it.
2nd... the acoustic ARM notification is "active" as per the BMW programming "machine", but the acoustic armed notification doesn't work. Easily put, the car doesn't beep when i lock it... anyone else have these issues?
Many thanks in advance for the help/advice!
      11-27-2012, 12:45 PM   #17
Tallest
Tallest's Avatar
1307
Drives: 911
2011 911  [10.00]
Can't help with alarm but that gas milage is nothing crazy if you drive in town (heavy car, engine needs to spin 4 wheels not 2, etc). If I go for X3 i'd only get it in diesel here though. sorry for jacking the thread, lol.
997.2
      11-27-2012, 02:27 PM   #18
SE3P_to_E90
231
Diesel for sure! if there was a diesel option state-side, i would've gone that route. i've ridden in a 335d, and it's a whole different animal.
      11-28-2012, 03:00 PM   #19
cagui1223
Drives: 2007 BMW X3[E83]
Hey,
congrats on your purchase! My girlfriend also has a 2007 x3 3.0si. She purchased it having ~39,000 miles. Now at 88,000 miles the SEL came on. I had the code run through the local autozone and it returned "P0597 | Thermostat heater control circuit open". Probable cause "Failed engine cooling thermostat". Its weird because the car gave no indication of overheating and continued to run just fine.
      11-28-2012, 03:43 PM   #20
cleung
Drives: 1997 Z3 1.9,2014 X1 28i xdrive
congrats on the purchase. I bought a '08 last winter for my wife and so far we really like it minus a few electrical glemins as mentioned (cd player stops working). I thought I would post regarding the staggered setup question. I bought 19" staggered rims for the x3 at the beginning of the summer and have loved them so far. Here is the post I made with some pics and sizing.
http://x3.xbimmers.com/forums/showthread.php?t=672294
2003 325xi (retired)
2004 530i (retired)
2008 X3 3.0i (retired)
1997 Z3 1.9
2014 X1 28i xdrive
      11-29-2012, 09:40 AM   #21
SE3P_to_E90
231
Originally Posted by cagui1223 View Post
Hey,
Thanks for the heads up! Just as an FYI, it seems those thermostat problems are the most common problem on these cars. i did a quick report with CarMD and the results are as follows - attached. It seems that the error code p0957 is the most common code being thrown...
      11-29-2012, 09:46 AM   #22
SE3P_to_E90
231
Nice looking ride! When i picked up the vehicle, i ended up getting the Msport model - which came w/ staggered 19"s from the factory. I'm running a similar tire size as you... i believe the fronts are 235/40/19 and the rears are 255/35/19. I might be slightly off on the sidewall measure. Nevertheless, I'm glad to see that you're not having any issues with the staggered setup.
The set I currently have on the vehicle has summer tires. This weekend, I plastidipped my winter setup, and will be putting them on the x3 in the next few weeks. Teaser attached
xbimmers
