F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > New iPhone 5 Cradle - Self made DIY
Studio RSR
      10-07-2012, 12:06 PM   #1
gspannu
199
Drives: F10 535, F82 M4
I have managed to get a DIY cradle for the new iPhone 5 that sits in the central console and fits the new iPhone 5 perfectly (with a case).
I had the iPhone4S cradle and was very disappointed that BMW have not yet made a iPhone5 cradle and it seems we cannot expect one at least for 6 months.
So, I set upon making one myself - not exactly a cradle but something to hold the phone and connect to the USB cable without having to fiddle with the tiny lightning connector and slot it each time.
Items used:
1. Base plate of the Cradle (blanking plate)
2. Original Apple USB to Lightning cable
3. Filing tools
4. Hot Glue
5. A bit of time...
I have used the original USB to Lightning cable for the connection and this provides all features except iPod Out functionality and antennae connectivity.
The cynics amongst you might say that one can just use the cable in the USB slot and get the same functionality. Technically you are correct - but what I wanted
- the convenience of just placing my iPhone5 and sliding it into the slot (almost like a cradle)
- not having to fiddle with the lightning connector each time (trying to fit in the iPhone)
- a more aesthetically pleasing solution
Photos attached should make it clear as to what I have done.
Happy to field any questions..
      10-07-2012, 01:10 PM   #2
Silververtu
Silververtu's Avatar
231
Drives: 2015 X5 50i M Sport
Great job! Nice and creative
2019 Cayenne Turbo
Gone but not forgotten:
2006 2.0T A4 Avant, 2007 Z4 Roadster 3.0si, 2006 M Roadster, 2013 550i M Sport, 2015 Cayman S, 2015 X5 50i M Sport
      10-07-2012, 07:11 PM   #3
XDEEDUBBX
XDEEDUBBX's Avatar
64
Drives: 535I
very nice!
      10-07-2012, 10:22 PM   #4
ATOMBOY
ATOMBOY's Avatar
Taiwan
Drives: F10 520D
Well done!
      10-08-2012, 07:02 AM   #5
bringonthenite
11
Drives: 2013 335i XDrive M sport
Great job!!!
      10-08-2012, 08:19 AM   #6
gspannu
199
@Silververtu
@XDEEDUBBX
@ATOMBOY
@bringonthenite
Thank you...
      10-11-2012, 06:07 AM   #7
Smartie2
Drives: E60 520d M Sport
Take That?!
      10-15-2012, 08:54 PM   #8
vaxpilot
vaxpilot's Avatar
Drives: 2013 328 xdrive sport line
Did you just glue the connector at the back of the base plate?
How about the dimensions of the hole, did you just measure off the floor of the plate?
      10-16-2012, 07:10 AM   #9
gspannu
199
Yes, I just poured oodles of hot-glue once I had the connector in place.
What I did was...
a) Measured from base with vernier callipers. I also stuck some blu-tag on the baseplate at the back (where the hole is required). Placed the Phone on the baseplate and pushed the phone backwards, this put indentation in the blu-tag to give a slightly better idea of the hole.
b) Drilled a small hole.
c) Filed the hole to make it bigger.
d) Once I could get the connector through (barely so a tight fit). Connected the iPhone. Secured the iPhone with a few rubber bands and pushed the iPhone back/ pushed cable inwards to get the exact position I wanted the connector.
e) Poured oodles of hot glue in the underside of the baseplate. Let is rest for 45 mins
f) Also made a slight indentation (filed) on the side of the base plate to route the cable (not really required, just makes a better fit).
      10-16-2012, 07:18 AM   #10
vaxpilot
vaxpilot's Avatar
What I did was...
Well done! I'll follow your lead when I get my car. One more thought though,
Does the phone get inserted on an angle, if so, are you concerned about the connector being bent?
      10-16-2012, 11:17 AM   #11
gspannu
199
No, you put the iPhone straight on the baseplate and then push it backwards. There is enough leeway to place the iPhone and then slide the iPhone5 back.
That's why it is important that you affix the cable connector, secure the iPhone with rubber bands, slide the iPhone back as far as possible and then pour the hot-glue. This ensures that there is enough space to drop the iPhone on the plate and then slide it backwards.
      10-26-2012, 05:55 PM   #12
elusiv
elusiv's Avatar
Australia
Drives: 135i coupe
Neat and tidy, but not totally functional. You see the antenna connection is not considered when using this method. But as for the rest, it's very neat. I think I'll just wait till the full one comes out and in the meanwhile, simply plug the phone in to a non fitted cable.
      12-11-2012, 02:25 AM   #13
pkimM3r
pkimM3r's Avatar
205
Drives: m3 saloon in granny mode.
Items used:
3. Filing tools
4. Hot Glue
5. A bit of time...
Attachment 763669
Attachment 763670
Attachment 763671
Attachment 763672
Attachment 763673
Attachment 763674
Attachment 763675
No ipod out with the usb connection? Arent you on the music page in your pictures? I dont follow.
      12-11-2012, 02:26 AM   #14
pkimM3r
pkimM3r's Avatar
205
I find it fits perfectly in the cupholder tray/cover. I cant stand food in my car.
      12-11-2012, 07:52 AM   #15
Who?
Who?'s Avatar
Australia
485
Drives: F87 LCI
hmm, my car says iphone 5 is not compatible.. maybe outdated software?
looks clean, but probably not for me, I always forget my phone if i put it there
      12-13-2012, 01:15 AM   #16
pkimM3r
pkimM3r's Avatar
205
I have the 5. Everything works except email.
      01-21-2013, 04:44 PM   #17
mjmonjure
mjmonjure's Avatar
14
Drives: 2013 F30
Great Job! I only wish I had seen this before purchasing the cradle for my 4S ($250). The only one drawback that I can see to this is that you do not get the benefit of boosting the cell phone signal through the use of the car antenna.
      01-22-2013, 04:37 PM   #18
gspannu
199
The iPod functionality is different from the music functionality. I can play Music using the car's catering controls… but I cannot run the BMW internal App. The lightning connector over USB does not support 'iPod out' functionality - this is supported only through the BMW Cradle.
      01-22-2013, 04:39 PM   #19
gspannu
199
The iPhone 5 has a pretty good signal (at most places)… so I really do not miss this feature…. technically you are correct; there would be a boost to the signal available with the proper cradle….
trouble is by the time BNW releases the iPhone5 cradle, iPhone 5S or 6 is going to be out...
      01-22-2013, 09:04 PM   #20
SamS
866
Drives: Tesla M3 Perf + '18 X3 M40i
Here's my DIY. I used the following part numbers from ProclipUSA.com: 830530, 215421, 514422.
Forgive the poor lighting conditions, I was in my garage, and it's dark out! You can see where I slid up the phone to reveal the Lighting connector that is semi-permanently attached to the dock. The iPhone 5 snaps in with a perfect fit, and of course charges, streams audio as a USB device, etc.
After living with the Media cradle + iPhone 4 in my M3, I decided I wanted something different for my iPhone 5 and F30. The two main problems with putting your phone in the center armrest are the fact that you can't easily access it to launch Pandora, etc., and it is easy to forget the phone inside the car. Outta sight, outta mind! I like this much better, although it's obviously a bit utilitarian.
      03-06-2013, 04:27 PM   #21
rinax808
rinax808's Avatar
Drives: 2013 F30 M-Sport
Pretty creative :: I've been wanting to cover that thing up!
2013 F30 328i ///M-Sport
Search this Thread:
Advanced Search
f30post
