F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Swapping wheels...
proTUNING Freaks
      10-05-2012, 05:05 PM   #1
JamesMA
JamesMA's Avatar
80
Drives: 2018 F80 ZCP
Swapping wheels...
My car came with standard M-Sport 18" all season wheels from the factory.
I had my dealer throw on M405 20" rims/parellis before delivery and I kept the 18" to put on for winter use.
I recall my dealer suggesting that the car needed to be coded to use the need wheel set.
Dors any one know if coding is necessary when changing wheel sizes some have to bring the car to the dealer to "sync" the wheels, or can I do it myself?
2023 G80 ///M3x Comp. BSM on Black M Brakes
Gone: 2018 F80 ///M3 ZCP 6 MT, 2013 F30 335i 6MT M-Sport
      10-05-2012, 05:09 PM   #2
justinnum1
651
Drives: 2018 330i Msport 6mt
have the dealer do it.
F30 330i Alpine white/Coral red Msport 6MT
      10-05-2012, 05:52 PM   #3
E36toF30
19
Drives: 2011 E92 M3 DCT
Why would any coding be necessary when changing wheel sizes?
      10-05-2012, 06:04 PM   #4
justinnum1
651
Speedometer... larger wheel needs to be calibrated
      10-05-2012, 06:13 PM   #5
Maz335i
BMW 4 Life...
Maz335i's Avatar
148
Drives: 2015 SO M3 (on order)
I never had anything done to my car. What will u do when u put winter tires on? Code it again?
Just leave it as it is.
MODS: *** / M Sport + Performance / Meisterschaft / Challenge / MORR / more to come! ***
      10-05-2012, 06:16 PM   #6
Rick4345
Rick4345's Avatar
470
Drives: 2022 WRX World Rally Blue
Just because you have larger wheels shouldn't matter. If everything is done right, the total diameter should be the same. Hence, you don't need anything coded. He's more full of crap than a Christmas turkey.
      10-05-2012, 06:22 PM   #7
EnerJi
15
Drives: '13 BMW 335i M-Sport EB-II
Just be warned, assuming the diameter of your new tires is roughly equal to the difference between the 18" and 20" wheels (1/9 larger), then your speed (and the trip meter and odometer) will be approximately 90% of the true value. Your speed will show 65 when in actuality you're going about 72.
      10-05-2012, 06:46 PM   #8
auptown
Drives: 2013 F30 328xi
Wait - can coding adjust the speedometer? Mine reads high, I would love to make it accurate!
Andrew
      10-05-2012, 06:58 PM   #9
BMoutlaW
Team Blop
BMoutlaW's Avatar
53
Drives: F30 328i M-sport
Depends on tire size because if they dont match up perfectly it will effect your speedo. As the others have said
      10-05-2012, 07:47 PM   #10
ZMM_OMG
ZMM_OMG's Avatar
143
Drives: '15 M3
2015 M3  [0.00]
2009 BMC Pro Machine  [10.00]
The dealer might have been referring to re-setting the Tire Pressure Monitoring System so that your car doesn't throw an error code after the new wheelset is installed.
Dunno how to do this myself, but apparently it's in the owner's manual.
      10-05-2012, 08:22 PM   #11
ric124
ric124's Avatar
Jamaica
452
Drives: F87 M2 BSM MT
2017 BMW M2  [0.00]
I changed my wheels and I used a set of new TPMS. Once I drove off after wheel install iDrive prompts to reset TPMS when come to a complete stop. At my next stop light i run the reset and thats it.
figure out what is the correct size tyres to mount so that the diameter does not change and you should be fine.
you can use this site to help
http://www.rimsntires.com/specs.jsp
      10-05-2012, 09:06 PM   #12
AWF30MSPORT
AWF30MSPORT's Avatar
65
Drives: '15 Porsche 981 Cayman GTS
Outside diameter remains very close to the same when properly upsizing...larger wheel means lower profile tire. When going from the OEM 18s to the OEM 20s, the difference in outside diameter of tires is miniscule and the difference in speedo readout is practically nonexistent. Not sure if the speed is measured from the rotation of the front or rear tires, but see the attached file to see the speedo differences for front and rear. (That's not to say that some of the configurations that I have seen on here won't make a difference as I have seen several setups here where the outside diameter is smaller/larger by a more significant amount based on the tires sizes people are using)
To the OP, I'm pretty sure your dealer/service advisor is just referring to the TPMS reset, which as ric124 notes is very easily done yourself.
      10-05-2012, 09:53 PM   #13
E36toF30
19
That's why I was confused. Maybe with 20" wheels it's best to go with higher diameter tires though, so they aren't super low profile. Although, as lukeb817 said they're probably just talking about the TPMS reset.
      10-05-2012, 11:59 PM   #14
JamesMA
JamesMA's Avatar
80
Thanks for the responses guys, I am going to measure the wheels/tires themselves and compare.
Search this Thread:
Advanced Search
f30post
