10-04-2012, 09:01 PM | #1 |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
F30 Radar Detector Hardwire DIY
Featured on BIMMERPOST.com I initially wanted to wire it like I did my e90 but this was not possible due to different wiring in the dome lamp and pretty much in the entire F30 platform. I also got a fair warning from my dealership that if I piggy backed anything to the wiring and if there were electrical issues the warranty would be void. Something I didnt want to risk on my 57k car. So I opted for the harder, but safer route. The Fuse Box. You will need the direct wire kit from escort passport wich is what I have, or V1 wire kit, or whatever youre hardwiring. I found my direct wire on Amazon for $8. The next few items you will need you can get at any local auto parts store. Mini add a fuse $7, fuses $5, 16 gauge wire spool $7. I chose black wire to stay stealty but you can pick any color. Start in the trunk by removing the carpet panel and exposing the fuse box. Work your way toward the front ofthe car on the passanger side. Youre looking for fuse #146 wich is the RPA and Homelink fuse. You can also use fuse #162 wich on my car is for the 12v accessory, but I chose not to as this is 12 gauge wiring, and I didnt want to lead 12 guauge into 16 gauge. But it will work the same way. Map light removal credit goes to VSMotorsports, thanks for posting that up in a earlier thread and showing us how to take down the dome lamp. Good Luck, Take your time, and follow the pictures. Yes I know its a pain in the butt doing the routing through the trunk and along the panels, as well as time consuming. But this is all we have for now untill someone can find a wire inside the car to tap into, but this is taking chances with warranty as I described earlier. Any questions just PM me.
FBO-PS1 and stuff
10-06-2012, 08:32 AM | #3 | |
Dejan
1753
Rep 4,197
IMO its worth cleaning up all the clutter on the dashboard and freeing up the 12v acc. in the console.
FBO-PS1 and stuff
12-23-2012, 07:37 AM | #6 | |
Dejan
1753
Rep 4,197
Im gonna do a laser jammer/shifter DIY in the spring as soon as it gets warm.
FBO-PS1 and stuff
12-23-2012, 07:56 AM | #7 | |
13
Rep 287
12-25-2012, 01:55 PM | #9 |
Dejan
1753
Rep 4,197
I put it right under the rain sensor cover. I can't really conceal it too much, I upgraded to a 9500ix and it needs the satellite signal, so it pretty much has to be mounted on the windshield.
FBO-PS1 and stuff
12-25-2012, 01:58 PM | #10 | |
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
01-02-2013, 09:50 AM | #11 |
1538
Rep 3,331
I mounted my V1 display directly to the flat area on the back of the steering column. It slightly obstructs the dash display while driving (so I have to lean forward to see the odometer) but it's not a big deal to me. It made it easy to route and conceal the wire as well without tearing everything apart. The wire runs behind the flap that covers the wheel, underneath and back up behind the two center AC vents. That panel pulls off and then I was able to feed the wire straight down to the power outlet above the footwell.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
01-13-2013, 08:22 PM | #13 |
Dejan
1753
Rep 4,197
The homelink gets power as soon as you unlock your car or push the start button once and the car is in aux mode. So no its not on all the time.
FBO-PS1 and stuff
aps335.50 |
01-14-2013, 05:23 PM | #14 |
85
Rep 478
Drives: '15 AY F80
+1
Great DIY. Just a side note, I used the direct wire cord with the additional mute button. If you plan to utilize the mute button don't go up the passenger side like I did just to undo it all and go up the drivers side. Everything is exactly the same and I just ran my mute button next to the driver side seat controls. |
01-14-2013, 07:29 PM | #15 | |
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
01-14-2013, 07:31 PM | #16 | |
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
01-14-2013, 07:58 PM | #17 | |
1538
Rep 3,331
Wireless wouldn't help too much, you'd still need to run a power wire unless you were willing to change the batteries all the time.
01-14-2013, 08:49 PM | #18 | |
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
02-23-2013, 01:31 PM | #19 |
592
Rep 3,870
Very nice write-up !!
02-24-2013, 12:04 PM | #20 |
10436
Rep 40,740
Drives: 2018 Alpina B6 650ix GC
Agreed.
Here is my write up from some time ago on my F10 hardwire install: My 9500ix install is very similar, except instead of wiring it into the Overhead Console, I installed it by separating the Rear View Mirror Housing, which easily separates in the middle at the seam, and tapping into the backside of the 10-Wire Connector Plug inside it, with +12V (Switched off the ignition) on the Brown/Green wire and Ground on the Brown/Black wire. In case anyone is interested, the Wire I am using is a "Corvette Radar Detector InvisiCord" from Southern Car Parts. The InvisiCord has pins soldered on the end of the two wires so they can simply be pushed into the back of the wiring harness. It comes in both 8" and 12" lengths, and while I used the 8", I highly recommend the 12" length, as there is literally no slack in my setup with the Radar Detector centered on the windshield below the mirror housing. Also, I am using the "Escort Radar Detector SCP Mount" mount from Southern Car Parts as well. It is much better than the the two small suction cups the 9500ix comes with, and better than the single "SuperCup Windshield Mount" sold by Escort, which I have in my other car.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
03-03-2013, 10:13 AM | #21 |
Rep 102
Drives: 2011 Toyota 4Runner Ltd
nicely done
That certainly is ambitious and well done. Escort detectors are awesome. I have that escort detector and the cordless one too. I like the corded one better, because of the constant lit display, but also hate the coiled up cord running down the dash. The down side to the cordless one is that it is heavy, won't hang on its window mount very well, and you have to change the batteries every 2-3 weeks.
The one tip I have, which may seem foolish and much, much lazier than yours, ... is to put the detector right on the dash with velcro. No bounce or rattle and lower profile without the window mount. Still works fine. I am wondering though, Since I won't have my f30 for another few weeks I haven't figured out where to put the detector yet. It looks like the new "pseudo-pop-up" nav screen is right where I would normally attach it. |
03-03-2013, 10:27 AM | #22 |
Mr. Nice Says Hello
636
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
great thanks for the write up
