2010 2011 BMW 5 Series Forum F10 NEEDED: Replace F10 Horn with Air Horns |
10-02-2012, 08:46 AM | #1 |
16
Rep 104
Drives: 2013
Hi,
Anyone got instructions / advice for installing a set of air horns instead of the normal horn? I (will) have a 2013 F10 535d M-Sport. I figure I should be able to take the power lead from the standard horn & plug it into the air horns but maybe I'm wrong. Any thoughts / pix / tips on where I can mount the air horns etc will be muchly appreciated.
Driving: 2013 F10 535d M-Sport Carbon Black.
10-03-2012, 12:00 PM | #3 | |
526
Rep 2,822
Drives: X5M F85
http://www.teamdelsol.com/forum/view...hp?f=32&t=8327 |
01-06-2014, 11:14 PM | #4 |
Rep 1
You can get a Kahlenberg compressor and air tank.
http://www.kahlenberg.com/sites/defa...8_brochure.pdf and one or two 10" Buell Horns... http://www.buellairhorns.com/buell-1...-pr-16154.html It may be a bit tight, but I think it can be done. The other way is to go with some cheap Napa air horns... |
01-07-2014, 04:02 AM | #5 |
Frequent Flyer
50
Rep 415
As stated there should be plenty of room behind the front grille area to mount a moderate sized air horn (if you're serious and not just having a laugh).
Only advice I could dispense after messing around with BMW electronics the past few years is to never risk overloading a particular circuit on these cars. If you plan to replace stock equipment with something that has significantly more draw, use a relay and a direct 12V source. The power distribution in this car is finicky - you'll likely not run into an issue if you ignored this advice - but I promise you'll be out quite a few AUD on the odd chance something goes. |
