M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Mechanical Maintenance - Break-in, Oil, Fluids, Servicing, Etc.
      09-28-2012, 02:27 PM   #1
Sharpie12
65
Drives: 2013 F10 M5 SG/SO
Exclamation Red Line Synthetic Oil SAE 5W-30
The oil says BMW-LL01 on the back. Is this okay to use? I haven't had much luck searching the internet for the oil and my dealer is CLUELESS. Someone with experience please chime in, thank you.
2015 F10 M5 - AW/SO- Retired 2013 F10 M5 - SG/SO - Retired 2010 E60 M5 - Retired 2010 X6 50i - Retired
2006 E60 M5 - Retired 2004 E60 530i - Retired
      09-30-2012, 06:35 AM   #2
bobblehead
bobblehead's Avatar
256
Drives: warp speed
http://f10.m5post.com/forums/showthread.php?t=694149
see post # 9
Therefore, I think you are fine with Red Line.
      09-30-2012, 08:38 PM   #3
Sharpie12
65
Just because its "LL 01" does it mean that this oil is a "BMW LL 01" approved oil?
      10-02-2012, 01:53 AM   #4
H60Doctor
///M-Flight
Germany
Drives: 2013 F10 M5 Monte Carlo Blue
Your oil needs to have the certifications by API SK/CF or ACEA A3/B4 the weights will also be in your owners manual.
      10-02-2012, 12:55 PM   #5
Sharpie12
65
I assume its okay because this is what it says "Ester-based Full Synthetic Group V with Zinc & Phosphorus Antiwear. Meet SM/CJ-4, ILSAC GF-5, API SN/SM/CF, ACEA A3/B3/B4, Dexos 1, BMW-LL-1, VW 500.00 / 501.01 / 502.00/ 503.00/ 503.01/ 505.00, Nissan Ester Oil, Ford WSS-M2C946-A Specifications."
      10-02-2012, 03:55 PM   #6
bobblehead
bobblehead's Avatar
256
Drives: warp speed
For my next oil change, I am going to try Motul X-Clean 5W40
      10-02-2012, 04:04 PM   #7
Sharpie12
65
http://www.jscspeed.com/catalog/Motu...0_X_cess_23038
http://www.motul.com/system/product_...pdf?1302646818
5W40 X-cess
      10-02-2012, 04:09 PM   #8
Sharpie12
65
is that would you would use?
      10-02-2012, 04:18 PM   #9
bobblehead
bobblehead's Avatar
256
Drives: warp speed
http://motul.speclube.com/technical-info/engine-oils/
Xcess is only LL98 - not meeting std
      10-02-2012, 04:20 PM   #10
Sharpie12
65
I already ordered some redline from my bmw indy shop and theirs says BMW LL01 and ACEA A3/B3/B4...but I called redline and their current label doesn't say BMW LL01? So what gives?
I assume mixing the redline 5w30 and the motul 5w40 wont cause any harm?
Should I just use the 5W40 period?
      10-02-2012, 04:27 PM   #11
bobblehead
bobblehead's Avatar
256
Drives: warp speed
You should be ok.
Try the redline and see if your gas consumption improves or not.
The bmw oil Castrol 5w30 seems to burn oil faster than Motul. I switched to that on my 2011 550 and that's what I noticed. Not sure if this would have the same effect on our M car.
      10-02-2012, 04:29 PM   #12
Sharpie12
65
Originally Posted by bobblehead View Post
You should be ok.
But the owners manual says that 5W-40 is okay to use? (As long as its LL01 and ACEA A3/B4)
      10-02-2012, 04:30 PM   #13
bobblehead
bobblehead's Avatar
256
Drives: warp speed
5w40 is okay. I would not worry too much. Actually, I prefer 5w40 more, if it's available.
      10-02-2012, 04:33 PM   #14
Sharpie12
65
OK well they sell it on this website, check it out
http://www.jscspeed.com/catalog/Univ...Motor_Oil.html
      10-02-2012, 04:38 PM   #15
bobblehead
bobblehead's Avatar
256
Drives: warp speed
I buy locally (Canada) the 8100 X-Clean 5L jug for $40.
      10-02-2012, 04:43 PM   #16
Sharpie12
65
great price. I just found it online for just under $40 as well. thanks for your help
      10-03-2012, 08:43 AM   #17
Sharpie12
65
Based on this http://motul.speclube.com/technical-info/engine-oils/
motul 8100 x-max 5w30/5w40 is exactly what we need
m5post
