N54 turbo upgrades in layman’s terms
09-28-2012, 09:08 AM | #1 |
68
Rep 1,432
1. Single or twins does not matter much in power or spool. What matters for spool and power is the size.
2. Twin upgrade in stock cores that is compatible with the existing hardware is the cheapest. Single and big twins are more expensive. Two turbos could well be more $ than one... 3. So called stage 1, i.e. compressor wheel upgrade + clipping of the turbine wheel is not much better than stock on average. 4. Compressor + turbine wheel upgrade, such as RBs is a nice upgrade at a reasonable cost. RBs must have the highest market share. 5. For more power single is the only proven alternative. 6. Some expectations for big twins are set too high. Refer to point 1. 7. It would be nice and interesting to have big twins available for comparison, but they will perform similar to a respectively sized single turbo, and can be more expensive. Looking forward to any big twins and the results though. 8. High octane and cooling is a must to max the turbos. Preferably both ethanol and methanol. |
09-28-2012, 09:48 AM | #2 | |
11
Rep 442
Lol alterior motive much? Glad you dispelled all the "myths." Lol. |
09-28-2012, 09:54 AM | #3 | |
CCA Member#: 439255
56
Rep 517
Great summary OP and hope you keep the first post updated for potential sticky!
Current: 2015 S4, 2011 E90 M3
09-28-2012, 09:57 AM | #4 |
387
Rep 1,571
This is a very good post, from someone who really does know what he is talking about (don't see this too often honestly). Definitely a great layman post.
09-28-2012, 11:27 AM | #5 |
Chartered Accountant
64
Rep 970
09-28-2012, 12:05 PM | #7 |
14
Rep 579
Drives: 08 AW e92 335i
I think RB's do well for number 5, but it depends on your goals. They are very well proven too.
09-28-2012, 12:12 PM | #8 |
177
Rep 6,631
You forgot the biggest difference which is the powerband on singles vs twins. Twins hit low and hard while singles are rev happy in comparison. I for one would still prefer a singles power delivery but to each their own.
With that said I am more than satisfied with my RBs. 500+ whp still scares me a little.
E90 LCI N54 6AT
09-28-2012, 12:17 PM | #9 | |
70
Rep 2,626
'18 F80 M3 Comp 6MT - Stock
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar. '05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
09-28-2012, 12:23 PM | #10 | |
177
Rep 6,631
20 psi to 18.5 at redline, 12 degrees timing to 13.5 at redline, 12.5 AFR to 12.0 past 6000 RPM, E50 blend with 90/10 meth mix on single CM10 nozzle. VD is constantly spitting out 510-540 whp on the same road with Cobb logs, so I figure it's at least 500 whp through the stock catback.
E90 LCI N54 6AT
09-28-2012, 12:32 PM | #11 | |
68
Rep 1,432
I did not even mention Vishnu or tuning in general. I was talking hardware. So, do you mean I'm biased towards Precision or FFTEC? I think Precision is not any better than the competition, but their prices are customer friendly. EFRs could be better, but they are not readily available. FFTEC manifold looks great, but its not exceptional. P.S. We could start another thread about big ST or BIG twins turbo tuning, but for the time being that would be boring due to the lack of alternatives |
09-28-2012, 12:55 PM | #12 | |
11
Rep 442
09-28-2012, 01:15 PM | #13 | |
70
Rep 2,626
09-28-2012, 01:34 PM | #14 | |
1740
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Back ok topic: good post OP. |
09-28-2012, 02:50 PM | #15 | |
177
Rep 6,631
E90 LCI N54 6AT
09-28-2012, 03:41 PM | #16 |
1740
Rep 17,960
Drives: A Lot
Because you are making a claim of whp and giving advice on how to make said whp. When your whp numbers aren't necessarily accurate. It's not hard to go on a dynojet. Doing it will even give you the chance to tune for more HP. But for someone who has yet to put down any actual numbers, you are a very vocal contributor in threads where you defend different turbo options claiming your "results" as supporting evidence. Get results first, then make these claims. That applies to others just as much as you so please do not take this personally.
09-28-2012, 03:56 PM | #17 |
68
Rep 1,432
If you mean EPL / Tial that JPSimon runs, they were among the best stage 1 turbos, as they were no worse than stock. Actually, they were even a bit better than stock. Still, they did not make business sense and are not available any more.
09-28-2012, 05:03 PM | #18 | |
177
Rep 6,631
Fwiw, VD on this same road stated 415 whp back when I had stock turbos and the car did 412 STD whp on a Dynojet at 17.5 psi @ peak power. 277 whp FBO stock baseline at that. JB4 logs in VD were artificially high reading, presumably due to the polling rate of the log not being quite as detailed as a Cobb log. I apologize in advance if my previous reply disturbed you in any way as it was not my intention or directed at you.
E90 LCI N54 6AT
09-29-2012, 11:29 AM | #19 | |
387
Rep 1,571
In Shivs defense, can you only imagine the wrath he'd face publishing VD numbers like they were credible? I believe that was likely his point.
09-29-2012, 01:02 PM | #20 |
125
Rep 2,172
+1 Good point Rob. VD is nice for personal use, but shouldn't be used as public fact because like Shiv said too many variables. I can show you consistent pulls on the same road in 3rd gear that show over 500 whp on stock turbos running 50/50 Ethanol and meth using VD on DynoJet settings. At this level of whp you really need to pull in 4th to get more consistent logs due to wheel spin in 3rd. Too many people on this forum who are easily influenced when you start telling people what setup you have to get to a certain power level... Just like big twins making 900 hp. I'm sure it can be done if you want a dyno queen and have deep pockets.
09-29-2012, 01:48 PM | #21 | |
136
Rep 1,202
Shiv, got so swamped this week. Totally spaced calling. I will touch base next week. |
09-29-2012, 01:52 PM | #22 | |
14
Rep 961
