Lack of boost
09-23-2012, 12:03 PM | #1 |
Rep 18
Lack of boost
Hello, my car have been feeling slower lately. Its not really slow but not as punchy as before. I feel like it doesnt boost the same but I dont get any codes. Is that possible? Havent changed either fuel pump or turbos so maybe thats it? Any suggestions without logs? Thanks
09-23-2012, 01:26 PM | #3 |
3441
Rep 79,211
Miles on vehicle?
Modifications? Miles on plugs? If there is actually nothing wrong with the car, you could just be used to the power. I noticed you titled the thread "lack of boost", is there actually a low amount of boost pressure, or are you referring to the feeling of power? |
09-23-2012, 01:56 PM | #4 |
Rep 18
Havent done carbon cleaning either, but it started feeling slower after some hard driving. Car is relatively new to me. No modification and cant log now. Modifications is coming but would like to straight this up first, so stock now. Plugs should be fine.
09-23-2012, 02:03 PM | #5 |
Rep 18
Well, I would say it feels like it doesnt boost the same, but at the same time you could just say it lacks of power. Really my main question is what could be wrong without throwing codes?
09-23-2012, 02:06 PM | #6 |
125
Rep 2,172
We have seen a lot of cars lately as they get older have boost issues due to the vacuum lines failing. Depending on the age of your car, it may be a good idea to replace the vacuum lines that go to the vacuum cans and also to the actuators. The lines have a mesh on them for heat, so it's hard to see cracks in the lines, but they go out slowly as you start dropping in vacuum. My car went from 19 psi to 8 psi in like a day. After a week of trying to figure out what the issue was, it had dropped to 4 psi and 0 at WOT. Took the dealership two hours to figure out it was just the vacuum lines. They replaced them under my CPO warranty so it only cost me a $50 deductible. I think 3 or 4 other people had the same issue within a few months. So it wouldn't hurt to check them if you feel your car is not boosting or has lost power over the course of a few weeks.
Eventually it will through a low boost code, but not until the vacuum lines fail completely. |
09-23-2012, 02:56 PM | #7 |
145
Rep 1,314
Drives: 2021 X3 M40i, 2018 Mustang GT
If you're sure it's a boost leak, then check vacuum lines (as mentioned above) and your charge pipe.
