09-23-2012, 10:19 AM | #1 |
LCI'd
257
Rep 819
Do YOU cut corners?
Hiya,
I'm in Europe, so here we drive on the right (steering wheel is on the left). I always get fed up when I'm approaching a right turn, only to find a car taking up half of my lane... Usually, this ends up with me braking/stopping... I've considered doing several things. First of all, I believe cutting corners can increase safety, however only if it's done at the right time and place. However, there are often times when I see drivers doing it plain wrong: they leave me no room to drive through the right turn. My question is: what do I do? Do I hold my path and try to go past and crash into the other car if there's no more room? I.e. can I rely on the other driver to move over as soon as he sees me? Also, when approaching a right turn, I have considered driving over the dotted line to straighten out the corner when approaching it - however, what will the guy coming the opposite way think? So, should I cut corners or not? Do you do it? Do you find it safer? Or are you just too lazy to turn the wheel? |
09-23-2012, 03:07 PM | #2 |
76
Rep 1,644
Nobody should cut corners, ever. At least not at the hilarious speeds I've seen people corner at. Apexing is for VERY high speeds only. I don't have that problem here.
Former car
2011 BMW 335i Step - Montego Blue / Chestnut Brown |
09-23-2012, 07:33 PM | #4 |
124
Rep 2,554
if you aren't in the inner lane around a bend, DO NOT CUT CORNERS.
i consistently pass people on freeway ramps and round abouts, and there isn't much on the road that annoys me more than someone shifting over into my lane as i pass them, causing me to brake hard just to avoid them hitting me. if you want the shorter curve, then get in the correct lane before the bend. |
