F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Evolution Racewerks F30 328i Intake
proTUNING Freaks
      09-20-2012, 09:07 PM   #1
tiltmode43
I plead the 5th.
tiltmode43's Avatar
523
Drives: '18 Frontier Pro-4X, '06 Z4MR
I posted a video thread the other day and got a couple PM's/posts asking if I could post pics. Keep in mind this is a prototype intake, so the final product may look slightly different! I decided to post pics (and paste the review) here instead of the photo section as the only ones really interested in this part would be 328i owners. Please excuse the dusty bay You can see the video below or in the original thread here.
From in the cabin it is noticeable if you know what to listen for. When trying to point out the sound to passengers that were not car enthusiasts, they said they couldn't hear anything different/had no clue what I was talking about. All in all, the intake was a fun mod with only slight performance benefits but a large increase in sound/driving experience. While it increased some engine noise and the diverter "PSHH," it did so at levels entirely acceptable.
As you can see, the intake connects to the OE lower portion making for an easy install!
-Matt
| Z4M Build Thread | @violetnites | flickr |
      09-20-2012, 09:41 PM   #2
rado
Drives: F30 328i M Sport
It certainly looks simple enough. Is that a K&N or similar oiled filter? If it is, I'd prefer a paper filter, probably easy enough to find one that fits. Is that an IAT sensor? Too many wires. It doesn't look like a MAF, but I guess it could be. Whatever it is, I assume it's a simple bolt-on transfer from the stock intake.
TIA, and thank you for posting the pics!
-Ed
2013 F30 328i M Sport
2008 Lotus Exige S240
      09-21-2012, 02:09 PM   #3
tiltmode43
I plead the 5th.
tiltmode43's Avatar
523
Oh the intake is a direct replacement with the OEM. Filter can easily be changed to any brand desired, you just need the correct dimensions. Wiring looks a little messy but that would be due to the BMS Stage 1 tune I have plugged in. The plug going into the intake tube is indeed the MAF.
-Matt
      10-17-2012, 07:53 PM   #4
AWMSPORT
1ST CLASS AWMSPORT
AWMSPORT's Avatar
74
Drives: 13' 328 MSPORT
When will this item be available for sale..and is there any difference if I get ge Msport 328 version? Or there is a new intake system for the MSport 2013.
'13 328i MSport, AW, Black Dakota leather, Premium Pkg, xenons, ///M Perf, side skirts,Front Lip, Fully coded, CF roundels, Matt Black Grillz, Painted reflectors (front & rear) Smoked tail lights, Plazma l.E.D White PY27W front turn signal,trunk spoiler, Matt Black roof, 8K D1S HID,Custom Exhaust,!
Soon:
JB4,DP,H&R sports,rear diff,!
      10-21-2012, 10:42 PM   #5
Joshhleee
///M Enthusiast
Joshhleee's Avatar
30
Drives: '12 F30, '15 x5 5.0, '15 M4,M5
does this work for the n26?
      10-22-2012, 04:18 PM   #6
tiltmode43
I plead the 5th.
tiltmode43's Avatar
523
I believe Msport has the same intake system as regular 328i, should work. Not 100% sure though, I would see what others say.
Joshhleee - Definitely is N26 compatible, those pics are on an N26 car
-Matt
      12-13-2012, 06:36 PM   #7
tiltmode43
I plead the 5th.
tiltmode43's Avatar
523
Finally listed on their website!
http://evolutionracewerks.com/node/222
-Matt
      12-14-2012, 12:10 AM   #8
tricksterr24
26
Drives: 2012 328i
2009 328 sulev  [0.00]
Is there anything to let us know about hp gains?
      12-14-2012, 09:17 AM   #9
Joshhleee
///M Enthusiast
Joshhleee's Avatar
30
same.
      12-14-2012, 01:02 PM   #10
tiltmode43
I plead the 5th.
tiltmode43's Avatar
523
Originally Posted by Joshhleee View Post
same.
Here is a brief part of the write-up from European Car Magazine detailing the ER intake. This was the 3rd of three mods being installed, BMS Stage 1, ER Downpipe, and ER Intake. Read more here -> http://www.europeancarweb.com/tech/e...2012_bmw_328i/ Basically, no real gains, technically -1 HP on dyno and +3tq but these numbers are so close, I would say negligible. Does seem to help smooth the torque curve up top though.
Intake
The ER air intake kit was easy to install because BMW made it simple to remove the stock airbox. By undoing one bolt and lifting it off two grommets, Fred was able to fit the intake in 5min.
02 sensor is transferred to ER intake
Once the sensor was transferred to the ER intake, we were ready for our final dyno with all three components. However, we were surprised to see F30’s horsepower numbers drop by 1hp; while the torque climbed 3 lb-ft and peak boost held 21psi between 4000-5500rpm.
After analysis, we decided the minor dip is within the tolerance of the dyno and can’t be felt on the road, whereas the torque gain was noticeable. What’s more, the intake creates smoother acceleration through the power band, enhancing the previous two additions.
-Matt
      12-16-2012, 08:54 PM   #11
jokerswld34
161
Drives: 2019 BMW M760li
2019 BMW M760i  [0.00]
Just installed the intake on my N26. Overall pretty unimpressed
My experience: slightly messy install. Fit and finish could be better. Welds aren't the cleanest and although mine came packaged well, my pipe had scratches on it. Pieces of it even have alight dents like scrap metal. Overall, very cheap looking and feeling. Design could be a bit more effective too using available engine bay space.
I'm also getting a system too lean CEL no matter how snug I fit the piping. Since I don't notice any real performance improvement other than a louder diverter valve, I'm wishing I never wasted my money....
      12-17-2012, 11:55 AM   #12
Jamesons Viggen
193
Drives: '98 M Roadster stg 2+ S/C
Not surprised.
So far I only like the AFE intake and not at $400+. **********s had them for $270 on Black Friday. That, or $200-225 used is all it's worth to me as I assume it to only be for sound.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      12-17-2012, 01:48 PM   #13
tiltmode43
I plead the 5th.
tiltmode43's Avatar
523
Originally Posted by Jamesons Viggen View Post
Not surprised.
Wow, that's a good deal!
I too am a fan of the aFe system, I think it's a more refined intake system than ER but considering no substantive gains are to be had either way, I prefer the louder, simpler ER. I do want the aFe scoop though!
I think there was an aFe N26 getting lean code as well, so it could be hit or miss on many cars, rather than particular intake system.
-Matt
      12-17-2012, 02:56 PM   #14
Joshhleee
///M Enthusiast
Joshhleee's Avatar
30
did you get the afe intake?
      12-17-2012, 09:25 PM   #15
jokerswld34
161
No. I got the evolution racewerks intake.
      12-17-2012, 10:53 PM   #16
bnekic
20
Drives: 2013 328i xDrive Sport Line
I got the aFe intake with scoop and couldn't be happier. Clean install and great overall performance.
f30post
