JB4 Issue
09-17-2012, 10:00 PM | #1 |
18
Rep 432
JB4 Issue
Seem to be having issue with my jb4 system.
Not getting any codes and i have checked all the connectors twice already and they are all fully connected. Sometimes when I start the car and I go for a spirited drive the car will not boost fully. I am on map 2 and it will barley hit 10psi and you really feel the difference.sometimes switching to map 1 and back to map 2 fixes it,sometimes I have to go to map 0(power off the jb4) and then back to map 2 and the issue is fixed. Sometimes neither of those tricks work and I need to turn the car off and turn it back on. Basically I just play around until it goes back to normal. Let me know what you think Thanks guys |
09-17-2012, 11:47 PM | #2 |
278
Rep 5,062
Drives: Black e92 335i
Do you have any logs from when this happens?
Shoot Terry an email, his customer service is top notch.
JB4 / OSS Angel Eyes / Downpipes / F1-Racewerks FMIC / Custom Meth Kit / BMS DCI / ER Chargepipe / HKS BOV / BMS Meth Elbow / BMW Performance Exhaust / Carbon Fiber Inlay Quad Tips / 19" Miro 111 / Front Aero Lip / M3 Sides / VRS CSL Trunk / Mtech Rear / DD CF Quad Finned Diffuser / LCI Tails / BBK / Smoked Reflectors / F1 Euphoria LED Interior / License LED's / GT 5000k Corners / 5000k HID Fogs / Air Scoops / LED Turn Signals / FK Silverline Coilovers / HPA endlinks / Vibrant Resonators / Osram CBI 5000k D1S
09-18-2012, 10:15 AM | #4 |
JBC
35
Rep 310
Drives: E92 AW 335i
Check the Overboost Safety PSI. What is it set at? I overboosted one time and JB4 shut off until I shut down my car and started it back up again.
Another cause for having very low boost is a leak somewhere within your piping. Check the chargepipe and intercooler piping, make sure that the connections are sealed and tight.
Cobb Protune (PTF), HFS-4 Meth Kit, DCI, PTF Twin Disk Clutch, Raceland DP's, OCC, F1 Racewerks IC, ER Charge Pipe, Forged DV's, CSL Rep Trunk, Aero lip, Mtech Rear, Custom Ground Control Coilovers, 235/35/19 275/30/19, Quaife LSD, Diff Lockdown Kit, DSS Half Shafts, M3 subframe bushing, M3 Rear Sway Bar
09-18-2012, 03:35 PM | #5 |
18
Rep 432
installed a ER chargepipe and bov today so maybe that was the problem with the stock chargepipe being lose somewhere.
problem is i made the stupid mistake of breaking the nipple off the intake manifold....need to fix this first before continuing on with this problem. thanks for the suggestions anyways |
