F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > What's the OEM center bore size for BMW rims?
Studio RSR
      09-15-2012, 06:07 PM   #1
gamechanger
25
Drives: x
Hi folks
I tried searching in the Sticky section as well as searching but I was not able to find the answer.
What's the center bore size for 2013 wheels or BMW wheels in general
Thanks
Max
      09-16-2012, 07:17 AM   #2
bobblehead
bobblehead's Avatar
256
Drives: warp speed
all 72.56
      09-16-2012, 08:12 AM   #3
gamechanger
25
Drives: x
Originally Posted by bobblehead View Post
all 72.56
Thank you
      09-16-2012, 08:22 AM   #4
remmib
remmib's Avatar
Norway
1566
Drives: 2013 F10 520d M-Sport
all 72.56
Well almost all, a few are 74.1 like the X5 E70, the X6 E71 (front wheels only) and the old 5 series E39.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      09-17-2012, 07:25 PM   #5
tiltmode43
I plead the 5th.
tiltmode43's Avatar
523
Drives: '18 Frontier Pro-4X, '06 Z4MR
We have a winner!
-Matt
| Z4M Build Thread | @violetnites | flickr |
      10-08-2013, 01:24 PM   #6
bluemark81
15
Drives: 2013 328 x-drive luxury
Does the bore on a replacement rim have to be exactly the same as the OEM rim?
      10-25-2013, 02:26 PM   #7
ApexWheels
BimmerPost Supporting Vendor
ApexWheels's Avatar
1421
Drives: M3
Not necessarily, but ideally yes.
If you purchase a replacement rim with a smaller diameter center bore it will have to be bored out by a machine shop.
If you purchase a replacement rim with a larger diameter you must purchase hub-centric rings (plastic or metal) and install them inside the hub bore of the wheel. Hub-centric rings come in many sizes, but make sure to purchase the correct size for your wheel/car (i.e. if your hub bore is 72.56mm and you purchase wheels with a 74mm hub bore, you must install 74mm to 72.56mm hub-centric rings). If you do not install hub-centric rings, you will likely experience steering wheel shake/vibration at cruising speed due to the wheel not being perfectly centered.
The safest method is to purchase wheels with the correct hub bore as they are a direct fit that won't need any machining or rings. Hope this helps!
Appreciate 2
      10-27-2016, 09:18 PM   #8
lo_xyooj
lo_xyooj's Avatar
57
Drives: Alpine 335i
I had to bump this old thread. Thanks Apex for confirming what I need to buy...Winter mode in full effect... Thank goodness I found this thread to confirm buying the right ring before mounting the wheels..
Search this Thread:
Advanced Search
f30post
