09-14-2012, 08:20 AM | #1 |
Rep 24
TPM - Tire Pressure Monitoring (not installed)
In M5 reviews (or at least one of them) they mentioned how the TPM display showed the tire pressure and temperature for each wheel (pretty cool!). However after a European Delivery on 7 SEP, i found it is not there.... Went to the M5 launch on the 13 SEP and one of the BMW guys said it should be there - so we went out to car, and it wasn't where it was supposed to be... Mine just showed the wheels as being green. I also took car to BMW Niederlassung (apparently a BMW owned service center) on advice of the M VP of Sales, and one of their lead technicians (Florian Peter) was surprised it wasn't there as well... The correct TPM monitors are on the wheels (i.e. the silver ones, that Florian verified), it doesn't show in display.
Anyone pressed BMW on this? or found a way to get it "turned on"?
2007 M6 Convertible
2013 M5 (9/7/12 ED) |
09-14-2012, 10:20 AM | #2 |
2870
Rep 7,885
I didn't check mine before I dropped off the car after ED, but I wouldn't be surprised if it wasn't there like you have reported on yours. I will confirm and bring to the attention of my dealer if it is not on my M5 when I get it back stateside. You can always try contacting BMW North America customer relations, so they can begin to document it for you also. Good luck, bro!
09-14-2012, 10:22 AM | #3 |
256
Rep 4,721
Cdn M5 model does not have. It uses indirect tpms which the sensor is mounted in the ABS system.
I believe the US uses direct tpms which the sensor is mounted to each of the (inside) wheel, you can tell by the valve stem. |
09-14-2012, 10:30 AM | #4 |
17
Rep 164
I did ED and saw what looked like "flat tire detection" but nothing showing temps and pressures. I got the 20s. Any chance you lose the TPMS sensors with the lower profile wheels?
Anyone with 19s check for "full" TPMS? |
09-14-2012, 11:24 AM | #5 | |
110
Rep 1,291
Must stop eating..............
09-14-2012, 04:00 PM | #7 |
74
Rep 571
I ran my VIN and my car is equipped with "Tire Pressure Display". I assume all US M5's have the same. I bet the hardware is all there, and someone will figure out how to code this feature.
09-14-2012, 05:26 PM | #8 |
72
Rep 347
I just checked mine and TPM is there...you need to go to settings , my vehicle info and you'll see TPM.
2012 X5 35D.
2013 M5 ~MCB / Silversone II full~Exec Pkg~20' wheels~B&O~Xpel Ultimate PPF. - Sold ! |
09-14-2012, 06:38 PM | #10 |
17
Rep 164
Per manual (Page 98), only Canadian models display pressure and temperature. U.S. just shows status" Green=OK, Yellow=low pressure.
@Journeyguy: can you confirm whether your U.S. car shows numeric pressure/temp or just green/yellow? |
09-14-2012, 07:03 PM | #11 | |
Knight Commander
559
Rep 5,948
Drives: 2014 911 Turbo S
Garage List 2014 Porsche 911 Tu ... [10.00]
2015 Mercedes-Benz ... [0.00] 2015 Jaguar F Type R [0.00] 2014 BMW M5 [0.00] |
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450 Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray |
09-14-2012, 07:03 PM | #12 |
72
Rep 347
I just checked briefly and it showed green/yellow color like any other TPM in BMW's. There was another option to reset which I dint check.....but it looks likes a standard TPM / green / yellow color where you can reset once you get the warning.
2012 X5 35D.
09-14-2012, 07:17 PM | #13 | ||
103
Rep 1,520
Bingo same coding as any other f10 already done. However to code the cas I needed those newer files. |
09-14-2012, 09:46 PM | #14 | |||
Rep 24
2007 M6 Convertible
09-14-2012, 10:10 PM | #15 | |
103
Rep 1,520
Lots of other goodies as well as: Enable trunk closing with FOB Turned off all annoying disclaimers DVD in motion Still working on a few others, I noticed a "M Lap Timer" in one of the files but I couldn't find it in the I-drive when I coded it. |
09-17-2012, 06:24 AM | #17 |
22
Rep 183
Drives: 1M-VO; Z8(03)-Blk
+1
Garage: 2020 Porsche Tycan 4S
2018 Porsche GT3 Touring, 58 356 Coupe 2014 McLaren 12C Spider 2004 Ferrari 360CS, 07 Lotus Exige S Former M cars: Euro E30 M3, 01 E39 M5, 08 E60 M5, F10 M5, 18 M2Comp |
10-03-2012, 12:29 PM | #19 |
184
Rep 2,245
Drives: '16 991.1 911 GTS, '16 F85 X5M
What MHz does the F10 system work on? Im wondering if my current aftermkt setup for my C63 will for for the M5 aftermkt wheels.
thx
2016 991.1 911 Carrera GTS
2016 F85 X5M - Carbon Black/Mugello Red |
10-08-2012, 01:25 AM | #20 | ||
Rep 11
