BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Classifieds Section > Wanted: 10mm Wheel Spacers
      09-07-2012, 04:18 AM   #1
Cozy
Cozy's Avatar
111
Drives: E82 135i
Wanted: 10/12/15mm Wheel Spacers
...with bolts and preferably hub centric .
      09-07-2012, 05:33 AM   #2
makkan00
makkan00's Avatar
886
Drives: F83 and F36
+1
I need a pair as well after JamJay.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      09-07-2012, 06:28 AM   #3
smoked
Drives: 335i Touring
I've got some 20's if either of you is feeling brave
      09-07-2012, 06:47 AM   #4
Cozy
Cozy's Avatar
111
Drives: E82 135i
Originally Posted by makkan00 View Post
+1
Really, even with your Alufulgen's? What's the offset on those? I was using ET30 on my 335i 'vert and that was about the limit for stock arches.
That'd be very brave for me sadly, it'd stick my stock wheels at around ET30 which for the E82 is a little too much, ET35 is probably the widest I could do without a severe drop but it'd still rub and need arch rolling with a mild drop I think. I do miss the bigger arches on the 3-series.
      09-07-2012, 09:55 AM   #5
Reardy Mister
Drives: 08 E92 325, Space Grey w/black
I need some too, after them two what already said, like.
10mm all round if you have 'em.
      09-07-2012, 10:11 AM   #6
makkan00
makkan00's Avatar
886
Drives: F83 and F36
If I am not wrong, they are ET30.
I am sure 10 mm can still go in there. I may get bit of rubbing but happy to roll the fenders.
      09-10-2012, 10:29 AM   #7
Tyso335
Tyso335's Avatar
49
Drives: E92 335d M Sport.......
ebay sell some with bolts good price
Fuel of the Devil
NOW: E92 335d M Sport lots of mods to come...
Gone But Not Forgotten: EVO 8 MR FQ340 Running 370bhp
      09-10-2012, 10:48 AM   #8
davyk31
1042
Drives: Macan GTS :-) & F40 M135i
Do these only fit an E9x or would they also fit an E70 X5?
      09-10-2012, 10:50 AM   #9
Zechariaha
20
Drives: 2010 E92 M3
i got a set of 12's HC spacer only
      09-10-2012, 11:54 AM   #10
smoked
im not entirely certain. i bet people on here know the pcd's off by heart!
      09-10-2012, 12:33 PM   #11
alzieboy
alzieboy's Avatar
15
Drives: E350 CDi Coupe
Have a look here
http://www.ebay.co.uk/itm/BMW-3-SERI...item45f91f9e62
      09-10-2012, 01:38 PM   #12
AWBimmer
AWBimmer's Avatar
344
Drives: E92 335D Pre-LCI | E63 M6 V10
They can't be that pricey even at brand new? £50-£60?
BMW E92 335D | Lower Klasse
IG: @that.m6
      09-10-2012, 02:58 PM   #13
Reardy Mister
For sale?
      09-11-2012, 02:55 AM   #14
Cozy
Cozy's Avatar
111
Drives: E82 135i
Interested based on price inc shipping to UK ...
      09-11-2012, 02:57 AM   #15
Cozy
Cozy's Avatar
111
Drives: E82 135i
Originally Posted by alzieboy View Post
I already have a set of these, really good quality actually and light also. I am looking for 10mm for the front axle to give the car a marginally wider look at the rear. 15mm is too great as I am upsizing the tyres and I'll rub with my drop.
      09-11-2012, 03:34 AM   #16
alzieboy
alzieboy's Avatar
15
Check his site /shop out they have 10mm Bimmec hubcentric spacers as well
http://mapsltd.co.uk/maps/
      09-11-2012, 04:56 AM   #17
Cozy
Cozy's Avatar
111
Drives: E82 135i
There's the problem, the 10mm hubcentric spacers are only available when upsizing the centre bore from 72.6 - 74.1, that's not good for stock wheels or any wheels with stock centre bore and would require a rebore of the wheels. http://www.ebay.co.uk/itm/BIMECC-BMW...item43b2eccc0e
The 10mm spacer which is a striaght 72.6mm across the board is only available as a shim. http://www.ebay.co.uk/itm/BMW-BIMECC...item45f299dbd0
      09-11-2012, 05:38 AM   #18
alzieboy
alzieboy's Avatar
15
Oooops SorryJamJay I Didnt spot that
      09-11-2012, 05:54 AM   #19
Cozy
Cozy's Avatar
111
Drives: E82 135i
No worries, when I first saw them I nearly jumped the gun and clicked "Buy" .
The only place I have found 10mm hubcentric is Terry @ Juiced Up, he sell the BMS spacers and it doesn't suggest that they are shims only. Can anyone confirm?
It's rapidly looking like a 12mm square setup right now but TBH I guess that there really is only 4mm in it. I've had 10mm front & 15mm rear on a previous car and even though it was only 10mm difference across the whole axle, you could clearly see that the rears were wider.
      09-11-2012, 06:58 AM   #20
Josh1a1h
170
Drives: AzuriteBlack 335i E92
Did the 15mm on the rear look good? any rubbing issues or protruding from the arch problems?
What do you think the widest on the front and rear with stock MV3s is possible?
Cheers
      09-11-2012, 07:40 AM   #21
Hotcoupe
Hotcoupe's Avatar
193
Drives: Don't know yet!
http://www.performancealloys.com/spa...ls.aspx?ID=230
Never argue with an idiot on the internet. He will drag you down to his level and beat you with experience.
      09-11-2012, 08:30 AM   #22
Cozy
Cozy's Avatar
111
Drives: E82 135i
Cheers
15mm on my E93 made the rear look very fat and was about the limit you could go to before rubbing (if lowered). They made the front wheels look dwarf'd though so I'd not recommend only doing one axle and would add some 10mm or 12mm up front if you want a wide rear look or go for a sqaure 12mm or 15mm setup to even it out more.
Originally Posted by Hotcoupe View Post
Nice to come acorss you on a forum again , I've been a little quiet on the car front.
Very nice. I had these on before, very very light but I was hoping to find someone on here with a cheaper second hand set .
