Trany synthetic oil
11-12-2005, 05:55 PM | #1 |
Rep 13
Trany synthetic oil
Hi,
Any one yet put some synthetic transmission oil in the gear box? I did that on my BMW motorcycle, Man what a difference in chifting. |
11-25-2005, 10:02 PM | #3 |
Rep 9
BMW used to use MTF-LT-1, which was essentially a 7.5cst (DexIII viscosity) oil, which was later replaced by MTF-LT-2 (which was thicker), but claimed backwards compatiblity to MTF-LT-1 apps. There was recently a post on this site by someone who suggested that MTF-LT-3 is now the factory fill for the E90 manual transmission, and I have no clue if that fluid is similar to the MTF-LT-2 or MTF-LT-1 fluids at all. I'll be checking with the tech depts at Redline and Royal Purple to see if it is similar to the MTF-LT-1.
People on the M5boards have used Royal Purple Synchromax in place of the MTF-LT-01, and others have used Redline D4 ATF in place of it. D4 ATF works well but appears to require replacement every 15K or so to maintain good shift quality. Then again, I'm not sure if a MTF-LT-1 "like" MTF can be used safely in the E90 transmissions because it now uses MTF-LT-3 supposedly, so I'll be checking with the people at Redline and Royal Purple. For fun, I decided to make a comparison of the fluids (OE MTF, RP Synchromax, MTFGlide, and D4 ATF). Note, that this is probably not the best way of comparing the fluids, but its worth looking at: Last edited by AZMike; 11-26-2005 at 06:01 PM.. |
11-29-2005, 01:41 PM | #5 |
Rep 9
Here are my responses from Royal Purple and Redline:
1) Michael, I am unfamiliar with MTF-LT-3, they recently switched to the MTF-LT-2 in '05 models. We won't have our 2006 lubrication guides until about April. If you have a sample of the LT-3 fluid I can have the chemist check the viscosity. At this point I would expect the D4ATF would still be a suitable replacement for the LT-3 fluid. Regards, Dave Red Line Oil 2) That is actually a question better answered by someone at BMW. As for using Synchromax in a new BMW 6 speed transmission. If it were mine I would change it the day I brought it home. Patrick Burris Motorsports Marketing Coordinator Royal Purple One Royal Purple LN. Porter TX. 77365 281-354-8600 ext. 241 713-705-9201 cell |
05-31-2007, 10:26 PM | #7 |
OEMconcept
174
Rep 5,593
i changed the fluid in my E46 to the Redline, and WHAT a difference....
i wonder if it has the same effect on a step transmission??? |
