Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Canada > Cheap fix to Seat belt butler missing the belt
      08-29-2012, 06:37 PM   #1
416Black335iS
416Black335iS's Avatar
Drives: 2007 328i Black Coupe
Hi all,
Newbie to the forum. Thought I'd share this video I found in case it's not in the forums, or in case you might not be aware of this cheap quick fix to the seat belt butler missing the belt.
Worked perfectly when I tried it, hasn't missed a beat since.
In case link does not work:
locate the exact spot where the butler extender grabs the belt - spary starch it and iron it like you would a shirt on an ironing board. As easy as that.
Cheers
      08-29-2012, 10:35 PM   #2
Spoolin335
Justin Herass
Spoolin335's Avatar
333
Drives: X6M / M3
2015 BMW M3  [0.00]
2012 Audi TTRS  [10.00]
2012 BMW X6M  [9.00]
2007 BMW 335i  [9.00]
Haha this is hilarious. I was just noticing my passenger belt assist was starting to let go of the belt more often. Ill have to check the belt to see if i have the same issue.
Thanks for the post!
      08-30-2012, 07:52 AM   #3
BRAISKI
BRAISKI's Avatar
135
Drives: '11 335xi e92 M-Pak
2011 BMW 335xi  [7.00]
Thats really good! I was thinking of putting some sort of a stiffener on the belt before.
      11-18-2012, 06:53 PM   #4
Fortyb
M-GAM3
Fortyb's Avatar
240
Drives: 2016 SO M3
Added velcro to my seat belt and on the silver face of the Butler and now it catches every time.. Make sure you raise your seat belt buckle all the way up
above where the butler catches your seat belt then add a 1inch strip to the seat belt up under it..so the buckle will not slide down and take your strip off.. Then add less then half of an inch to the butler and you are finished.
Car Enthusiast.
      11-18-2012, 07:01 PM   #5
infidel335
infidel335's Avatar
29
Drives: 2009 335xi
I don't buy it. Mine was dropping the seat belt too and the dealership replaced the butler and now it works fine.
      11-18-2012, 07:34 PM   #6
Yvette
761
Drives: M
starch spray? would stiffener spray work the same? steamer is necessary?
      11-18-2012, 07:51 PM   #7
Fortyb
M-GAM3
Fortyb's Avatar
240
Drives: 2016 SO M3
I tried that already did not help at all for me it might work for you. But the Velcro I installed seems to be doing the trick.
Car Enthusiast.
      11-18-2012, 07:54 PM   #8
Fortyb
M-GAM3
Fortyb's Avatar
240
Drives: 2016 SO M3
The butler is not the case unless there was something else going on with yours...But it's the seat belt that gets worn in the same spot over time that causes it to drop the seat belt... Very poor design by BMW.
Car Enthusiast.
      11-18-2012, 08:10 PM   #9
Yvette
761
Drives: M
pics of your velcro installed?
      11-18-2012, 08:59 PM   #10
Fortyb
M-GAM3
Fortyb's Avatar
240
Drives: 2016 SO M3
Here you go.
Car Enthusiast.
      11-18-2012, 09:01 PM   #11
Fortyb
M-GAM3
Fortyb's Avatar
240
Drives: 2016 SO M3
Originally Posted by Fortyb View Post
Here you go.
Forgot this one.
Car Enthusiast.
      11-19-2012, 07:13 AM   #12
demontwinz
18
Drives: 335i e92
thanks i will try the velcro .. my flat iron helped a little bit only
      11-19-2012, 07:26 AM   #13
Laguna3
20
Drives: N55 E92 Msport
I just took the fuse out a month after I got my car. Sorry, the velcro looks ghetto.
      11-19-2012, 09:13 AM   #14
Fortyb
M-GAM3
Fortyb's Avatar
240
Drives: 2016 SO M3
You can use clear velcro i just used this because it was an idea i had and it works.. The only thing that is Ghetto is having you are your passenger twisting there back out of shape trying to reach the seat belt in a 40 to 50K car.
Car Enthusiast.
      11-27-2012, 08:48 AM   #15
demontwinz
18
Drives: 335i e92
I ironed it and added hair Gel.
it worked for 2 days but now it doesnt' catch again, the seat belt is too soft.
I dont' like the velcro but I have to think of something.
      11-27-2012, 09:01 AM   #16
Fortyb
M-GAM3
Fortyb's Avatar
240
Drives: 2016 SO M3
This mod may not be for everyone but its the only route I see, and mines works 98% of the time now. The only other route is to have your seat belt replaced ,but you will probably be doing that every two too three years. I'm thinking of replacing the black strip on the catcher with clear Velcro to clean it up a little.
Car Enthusiast.
