Steering wheel lock error message
08-14-2012, 11:45 AM | #1 |
14
Rep 276
Well this is just getting annoying now. Just got ANOTHER error message...this time the steering lock warning symbol in red has appeared, car will still start and drive ok...yet the error message says that i wont be able to start the engine again..
So I have read posts stating possible solution to fix this problem: 1. Steering column needs replacing, which would be well over $1000, unless it gets replaced by good will from BMW (and apparently there's a recall for this?) 2. Battery needs replacing, not enough voltage to trigger the unlock (but my battery was only replaced 4 months ago) 3. Reprogram and software update Has anyone had this error before, would appreciate any advice on which possible options to take or other altenative solutions to this.. |
08-14-2012, 05:03 PM | #2 |
12
Rep 213
Not what you want to hear but mine was number 1, luckily for me car was still under warranty.
E90 320i 07 Exec | innovations package | comfort access | 18" ellipsoid 162 | Yokohama 225/40 front 255/35 rear
08-14-2012, 11:26 PM | #3 |
18
Rep 297
I had this on mine about a month ago - although my steering wheel lock symbol was amber - not red. My car wouldn't even start though!
Turned out to be the CAS (car access system) module had gone. Long story short - $800 part and a 2 week wait from Germany, then fitting. I did a fair bit of research trying to sort the issue and from what I found - yours sounds like it's the steering lock within the column. It was more comon on the 2006 and early 2007 models. (heaps of info on this forum once you start searching). Go to an authorised repairer rather than BMW, otherwise it'll sting twice as bad! Hope it works out for you! |
08-15-2012, 07:21 AM | #4 |
Jedi samurai ninja turtle
619
Rep 3,021
Drives: X3 M40i 2018
sucks! how the hell does something like this go bad??
its a scary thought knowing these things are happening and not cheap to fix either. |
10-24-2012, 08:05 PM | #6 | |
899
Rep 6,285
It would be interesting to get some feedback from the OP into what he had done to solve his problem, some guys state a software update fixes it though it seems the majority have to go with a new column (I have seen a fair few 2nd hand spares for sale though they were from LHD vehicles...) |
10-28-2012, 03:52 AM | #7 |
Rep 126
Majority of the times, it's a steering column lock problem.
Steering column had to be replace. A diagnoses from the factory diagnostic will tell you what it requires, sometimes new column plus programming, sometimes just programming. I have never heard the battery would cause that. I have seen many case where the car still starts and drives normal. And as many case where the car will not start at all. It will require a diagnostic machine to be plug in to it and reset the counter on the ELV. |
11-17-2012, 07:17 PM | #8 | |
14
Rep 276
11-17-2012, 09:15 PM | #9 |
899
Rep 6,285
