      08-13-2012, 07:40 AM   #1
JHS130
JHS130's Avatar
Australia
14
Drives: BSM 130i 6MT
2006 BMW 130i  [0.00]
E87 Pre-LCI to LCI tail lights - coding
Hi all I'll be getting some LCI blackline tail lights with the LED light tube/strips for my E87 soon and wanted to know if they need to be coded like the coupe/cabrio LCIs...
Anyone tried this retrofit so far? I've not been able to find a thread related specifically to this topic, ie. for the E87. Thanks in advance!
      09-06-2012, 07:31 AM   #2
37&TenCents
37&TenCents's Avatar
Drives: le mans 130i, e30 no more :(
I'm just doing the same right now!
I've found this thread on a German forum (google translate makes it pretty understandable)
You need the 2 new LCI lights (duhhh), and about 2 - 3m of 0.7mm diameter wire (to draw power from the license plate lights to light each of the the LED strips). You can modify the wire harness connectors to fit in the LCI lights.
I think you can get away with no coding, but if you want to change/fix up how the led strips work with the parking lights/brakes then you'll have to code that...
Originally Posted by Blauweisser View Post
I know that progress has demanded the new blown 4's, but for me the N52 is the final, ultimate expression of the BMW NA straight 6.
      09-06-2012, 09:07 AM   #3
JHS130
JHS130's Avatar
Australia
14
Haha yep that's the thread I followed
Did you end up getting the contacts for the LED strip from BMW? I picked mine up from the parts dept today and they look smaller than the pins in the wiring harness... hmm... I've also got some similar looking ones from Bunnings which may or may not work.
      09-07-2012, 04:40 AM   #4
37&TenCents
I was just gonna pick up some 3mm spade connectors from Jaycar and hold them in with a bit of blu-tac or something, it won't make any difference as far as I can tell?
I'll have an answer either way tomorrow... haha
      09-07-2012, 05:59 AM   #5
JHS130
JHS130's Avatar
Australia
14
Finally had some time to finish the wiring on mine today!
Yeah I used some that I picked up from Bunnings. They don't stay in because there aren't any clips but you can hold it in place using electrical tape. I'll upload some photos in a few hours.
The LEDs looked great this morning... and I'd imagine they look better at night... although I won't find out today as my battery is dead Forgot to turn my light off whilst installing my BMWP intake and had the iPod playing through the speakers.
      09-07-2012, 08:09 AM   #6
JHS130
JHS130's Avatar
Australia
14
Okay here are the photos:
As you can see I used the green rubber bits from the contacts I got from BMW hoping that they'd help hold it in place.
LCI Blackline LED Tail Install by J.H. Sohn, on Flickr
Testing fit
All taped up and ready to go
Dodgy wire taps... used a small square file to remove some of the plastic so the new wire could come out of the housing. Had the blue ones like in the 1erforums post but it looked like it was meant for a larger gauge of wire.
Left side of the boot trim is back in. Most difficult part of this install BY FAR.
Right hand side in...
Complete!
The result. Looked fantastic while it lasted
      09-07-2012, 08:54 PM   #7
37&TenCents
I've also just installed my BMWP intake this week! Talk about coincidence...
I have a shark fin aerial I'm about to get painted and I'll throw that on. I was actually sent 2 so if you want the other I could send it your way??? haha
Your wire taps, do you have 2 grey wires from the license plate lights? I only have one by the look of it, wondering what to leech off of...
      09-07-2012, 09:24 PM   #8
37&TenCents
As you can hopefully see here:
Was yours similar or did you have two grey wires? I can't quite tell from your photos.
Everything else works like it ought to, obviously just without the LED strips.
      09-08-2012, 04:15 AM   #9
JHS130
JHS130's Avatar
Australia
14
...I think our thoughts are connected or something. I've been looking at shark fin aerials on other cars for the past three or four days and was seriously considering it. There was a video from Germany of a 130i with an X3 one I believe? Anyway, might have to take you up on that offer... how much you want for it?
By the way, the intake sounds amazing. Finally got the chance to give it a good test today and the sound from 2.5k onwards is awesome!! Sounded even better on the track
Hmm to me it looks like youre searching for the wire a bit further up from where they split into smaller bundles.. if you look all the way down, there should be a small bundle that goes into a rubber boot and through the chassis. Should be two grey wires with a brown stripe. I'll find you a better photo of what I'm talking about.
EDIT: Okay I think I know what the issue was.. there is a foam/polystyrene cover that needs to come out to expose the wiring loom further down... photos up in a min.
      09-08-2012, 04:39 AM   #10
JHS130
JHS130's Avatar
Australia
14
Not sure if that explains it any better haha tell me if you still can't find it
There are two grey + brown striped wires but one is taped up in the photo so you'll just have to trust me when I say it's there haha..
      09-08-2012, 07:44 PM   #11
37&TenCents
Thanks for the photos, I ended up just tapping into the one wire for both LED strips, worked fine & they look great. I was just worried that if I did leech power for both LEDs from the one wire then maybe one license plate light would be dimmer than the other since they appear to be wired individually (with the 1 grey and 1 brown wire each).
As for the shark fin, ygpm.
      09-10-2012, 12:27 AM   #12
JHS130
JHS130's Avatar
Australia
14
Make sure you post up some photos when you get the chance!
Some more of mine:
LCI Blackline LED "High" Version by J.H. Sohn, on Flickr
BMW 130i by J.H. Sohn, on Flickr
Looks a billion times better than the pre-LCI tails
      09-14-2012, 12:09 PM   #13
p4ddY
Germany
Drives: E84 3.0l N52
Looks good. But you still need to get some coding, so the other bulbs don't light up, while the LED strips are lit. So the others only light up for breaking/fog rear lights (if you got these). I'm coming from the German forums
      09-14-2012, 09:17 PM   #14
37&TenCents
Yeah, I'll be getting that sorted soon, but that's not top priority since they work fine as they are for now...
      09-15-2012, 02:48 AM   #15
comar1979
130i Treiber
comar1979's Avatar
Germany
119
Drives: BMW 130i
standart:
pre LCI Blacklines:
LCI Blacklines:
# BMW 130i /// + SPARCO Assetto Gara 8x18 bronze + KW + PP SteeringWheel II +PP Exhaust +PP Kidneys + PP AirFilter + PP Style Flaps + PP SS Kit + AC-Schnitzer Gear Knob + MorVision Diffusor + LCI Blacklines high + GroundZero-Audio #
      11-10-2012, 06:52 AM   #16
xcharles1
Drives: E87 130i
Great thread!
      11-11-2012, 07:23 PM   #17
GClark91
GClark91's Avatar
Australia
Drives: 2011 SB 118d
Mmmmm LCI's Look soo good on the black cars! Great work guys. Making me want to do it now
One happy 1er
Nothing beats the looks I get when I tell them about what I drive and how old I am!
      12-15-2012, 07:25 AM   #18
iastute
Drives:
Just got to do this today!!
It looks awesome!! BTW anyone got the english instructions on the programming of the lights. TIA!
      12-15-2012, 07:36 AM   #19
Sarge135
Semper FI!
Sarge135's Avatar
32
Drives: 2009 135i
That looks great!
2009 SGM 135i M-Sport
Ark l Blackline l iCarbon l AFE l Hawk l VMR l ST Coilover l Parrot Asteroid l JL Audio l Janus-Design l Reiger l BMW Performance l COBB l Evolution Raceworks l TIAL l VRSF
      08-20-2013, 01:55 PM   #20
Burak
Burak's Avatar
Turkey
Drives: E87 120d
2005 BMW 120d  [0.00]
I've done this mod and it worked but now I'm bored with how the led strips work with the parking lights/brakes. I went to an electric technician and he told me that he'll need to get the 6th wire (the one I've added to light the leds) to the ECU and then code the new tail lights. But he also added that my ECU may not be compatible with the LCI taillights, if so I may need to change the ECU which is very expensive of course. May this be true?
One more thing, I've got my ECU remapped, if the I code the LCI taillights, will the remap blow?
'05 E87 120d M Sport
      08-20-2013, 11:13 PM   #21
_Ryan_
No_Country
59
Drives: E87 130i
2005 BMW 130i  [5.24]
Are any of them plug and play? (I can wire, just cbf)
oh yeah, there is also this: http://www.babybmw.net/viewtopic.php?f=29&t=15081
      08-21-2013, 12:07 AM   #22
Burak
Burak's Avatar
Turkey
Drives: E87 120d
No PnP in the market as far as I know.
BTW, don't buy the LCI taillights that' are not suitable for your vehicle. There are 2 kinds of LCI taillights.
LEDs are installed on cars with front Xenons.
Non-LEDs are installed on cars with standard front halogens.
1addicts
