08-05-2012, 12:58 PM | #1 |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
I was very annoyed by the fact that the headrest was not able to go all the way down or you couldnt take it all the way out. Here is the simple fix.
Tools: 7mm socket and ratchet. And a pick tool. You may have to move the seat back and forth to give you more room. 1. At the Rear base of your front seat locate the 2 push pins. This is basically the only thing holding the back plastic part on. Gently pull down with both hands and the pins will come free. Slide the Plastic panel straight down. This gives you access to the headrest clamp. 2. Look for the 7mm clamp usually on the left headrest stem. Undo it and slide the clamp off. This will allow you to remove the headrest completely out of the seat. 3. Locate the black plastic cap with out the adjustor. Its on the Right hand side. Gently pry up on the cap. Take your time be careful. This will expose the 2 springs that need to be removed. 4. Using a pick tool romove the 2 springs. Dont throwh them away you may want to reverse this process one day. This allows the plastic clip inside to move freely. Its whats preventing the head rest from moving all the way down. Reinstall the cap. And then the headrest. Then the plastic backing cover. I also left out the clamp so I can take out the headrest if I want. YOURE DONE! Very simple. Last edited by Jadar; 08-11-2012 at 08:10 AM.. |
08-05-2012, 02:31 PM | #3 |
Dejan
1753
Rep 4,197
Literally took me 15-20 minutes. And I stopped to take pics.
FBO-PS1 and stuff
08-06-2012, 04:34 PM | #5 |
592
Rep 3,870
very nice !! Thanks for Sharing !
08-20-2012, 06:04 AM | #6 |
14
Rep 75
Re: Diy Headrest Fix
hello all. we can all agree this headrest issue just seemed a little off..(must be the ocd) but its in place for a reason: TO MOD! jk so i also tried this mod but noticed that i didn't have the clamps on mine instead it was a 20 torx screw on one of the bars. anyway so after doing one side per dd1981 just going through the steps, it dawned to me years later that i didn't even need to do steps 1-2. the only thing i needed to do was pry up on the cap that you cant squeeze down-on while the head rest is still on there (bc the cap covers the internal adjuster thingy), bring down the head rest and then pressed down on both of them simultaneously once you are on the last knotch to bring it down all the way. too late to bare with me but you'll have about 1-2 inches of space to snap the cap back on and your done.
ps still be gentle when prying the cap and make sure u snap it back on real good. it has 3 groves that need to be snapped down still or cant figure it out then just go through with all the steps noted before. it just depends what you want and how much time you have.. ie i only wanted the headrest to be flush down so i went through all the steps on the passenger side and cut the steps in half for the driver side whatever works for you. if you pull up on it then it'll snap back in place and you will have to do it again
the only thing in this world that gives orders is balls. You got that? Balls. Last edited by steadymoddn504; 08-23-2012 at 02:15 PM.. |
natesi204.00 |
08-20-2012, 08:02 PM | #7 | |
Dejan
1753
Rep 4,197
Good job and thanks for adding. Headrests Lookin much better.
FBO-PS1 and stuff
08-21-2012, 03:31 AM | #8 |
81
Rep 436
I have to do this one. Maybe this weekend. Good stuff and thank you.
2023 G80 ///M3x Comp. BSM on Black M Brakes
Gone: 2018 F80 ///M3 ZCP 6 MT, 2013 F30 335i 6MT M-Sport |
08-23-2012, 05:17 AM | #9 | ||
14
Rep 75
the only thing in this world that gives orders is balls. You got that? Balls. Last edited by steadymoddn504; 08-23-2012 at 03:26 PM.. |
09-13-2012, 08:59 PM | #10 |
**Fortune Favors The Brave**
13
Rep 173
Drives: 2013 328i M Sport
Just did this "the easy way" and it was pretty darn easy. Took 3 minutes. Thanks good idea!
2013 ///M Sport Estoril Blue - Navigation - Enhanced BT - Xenons - Sport Auto
09-14-2012, 09:43 AM | #11 |
16
Rep 195
Maybe it's because I'm on the taller side so have never had my headrests all the way down on any vehicle I have ever owned...but what it the point of this mod? Cosmetic only or is there a functional purpose.
2012 328i Sportline - Black Sapphire Metallic - 8AT Sport
I pronounce it "Beemer" and turn my fog lights on even when it's not foggy. |
09-17-2012, 01:44 PM | #13 |
13
Rep 173
Only drawback is you can't tilt the headrest forward when its all the way down..which also looks good and might be a bit more functional. But I notice some F30s don't have that button to tilt forward on the side of the headrest. Not sure if that's a 2013 thing or something in the trim ordered.
09-17-2012, 08:58 PM | #14 | |
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
10-10-2012, 09:15 PM | #15 |
42
Rep 537
Drives: 2013 335i M
Thats a good idea. Thanks
M5 with lots of goodies
12-27-2012, 10:17 AM | #16 |
38
Rep 516
Interesting... but I think you might be removing a safety feature by doing this. In the stock set up the head rest has a movement (front to back) that seems to be for neck injury prevention. I might be wrong but just a thought.
Retired: 99' E46 323i AW / 06' E90 330i SG / 09' LCI E90 335i MB / 13' F30 335i EBII
15' F30 / 328i / Msport /// xDrive / Mineral Grey / Oyster / Anthracite Driving: No BMW right now |
12-27-2012, 06:05 PM | #17 |
Dejan
1753
Rep 4,197
It could very well be for safety, it still does tilt just not as much.
FBO-PS1 and stuff
05-04-2013, 12:35 PM | #22 |
263
Rep 1,130
Drives: '16 340i AW MSport
I dont' get how you guys got the spring out? I was trying now, I almost bent/broke the plastic piece at the end the spring is on, there almost no room for manuevering the spring out???? Help! lol
