Question about Car Cover
11-10-2005, 01:22 PM | #1 |
First Time Bimmer Owner, Long Time Bimmer Admirer
Rep 16
My e90 is going to spend at least a few months with a carport as its only means of protection. I have a few questions:
1. Do I need a car cover? 2. Is there any risk that the car cover could scratch my paint when I place and remove the car cover every day? 3. What brand, material, etc... works best for a location where rain is the harshest whether? Should I go OEM? |
11-16-2005, 02:35 PM | #2 |
15
Rep 146
Weathershield is the Best you can buy. It can be washed in a large washer too. Light weight and water proof. DON'T Buy "NOAH"!!! I did a while back and inside of the cover was a WARNING...not to get too close to flames as it WILL catch on fire......thought GREAT.....all someone would have to do it flick a match from lighting up and POOF..... there goes the car I took that thing back to the dealer and got my money back! Weathershield ISN'T Cheap... cost about $250 depending on the size of the car. Good luck!
11-16-2005, 02:49 PM | #3 | |
Rep 290
I use a BMW cover for my Z4. No problems with scratching. I have no experience with other types. |
06-13-2006, 05:24 PM | #4 |
Silver 3CC
Rep 15
I have been looking for car covers on line today. If under a car port, will rain get directly on the cover? Covercraft has a good site to determine the best cover for your specific needs. To ensure you don't scratch the paint need to use the cover when car is clean. The most weather resistant cover is the Covercraft Weathershield HD. Expensive about 349.99, also claims since it is the thickest it helps prevent door dings. The Weatherdhied standard id $269.99
Description: "Outsmart the Outdoors!" With patented immersion finish Solution Dyed Fibers Resist Fade Sheds Water / Blocks Dust - Dirt Maimum Protection & Performance Warranty: 5 Years |
