08-03-2012, 03:56 AM | #1 |
50
Rep 297
Replacing rear brake pads
Any one replaced the rear brake pads. Could see a few problems as it looks like it needs to plugged into a computer to retract the pistons.
Any easy way to do the job? Seen elsewhere might do it manually if piston screwed in clockwise, which makes some sense, perhaps release bleed nipple if excess fluid. Anyone know what fluid is used. Spotted this; "Emergency Release" "No parking brake emergency release function is provided for the customer. The parking brake can be released using the BMW diagnosis system or the EMF actuators are removed and the spindle is turned back manually" Realise a lot of people on here are probably still using some service agreement they bought with the car, but now 3 years on they are in the second hand market so need to know some diy stuff. Last edited by bigendbob; 08-03-2012 at 12:05 PM.. |
08-04-2012, 11:13 AM | #2 | |
Rep 175
08-06-2012, 12:57 PM | #4 |
Rep 175
08-07-2012, 03:03 PM | #5 |
50
Rep 297
The code is only required to electrically back off the piston, hopefully if the motorgearbox is physically removed, the piston can be manually wound back, exactly what the motor would normally do. This is what it seems you do if you get an on street failure and lock up.
Again hopefully when the motor is reinstalled it drives the piston to its new position and basically stalls the motor, the current then drawn tells the motor via electronics to stop turning. To release brake the electronics just tell the motor to turn for say 1/4 second and assume the pad has then released. A friend that worked at Jaguar design tells me they perfected this type of system and would find out what they do. Time will tell. |
