F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > F30 TPMS Facts!
proTUNING Freaks
      08-02-2012, 03:15 PM   #1
bavarianx
bavarianx's Avatar
219
Drives: 2006 X5 4.4i
F30 TPMS Facts!
We have received a lot of questions from F30 owners about changing their TPMS sensors and if they are compatible with the earlier E90,E91,E92, and E92 versions.
BMW made a part number change in 09/09 for the 3 series from OE #36236781847 (HUF #RDE008) to a newer version #36106790054 (HUF #RDE012) until the end of the E9X chassis.
The new F30 chassis uses a 433MHz sensor with OE#36106798872 which will not work with any of the previous versions.
Here are some reference pics earliest to latest..
36236781847
36106790054
36106798872
      08-02-2012, 04:41 PM   #2
m5 guy
m5 guy's Avatar
1662
Drives: 2020 M5 Comp
Thanks for the info
2020 F90 M5 Comp Oxford Green Metallic II-Aragon JOURNAL
2016 F10 M5 Space Gray-Black SOLD
2012 E70 X5M Monte Carlo Blue-Silverstone SOLD
2001 E46 M3 Oxford Green Metallic II-Cinnamon SOLD
      08-02-2012, 05:53 PM   #3
onehungevo
64
Drives:
FYI....you can transfer your stock TPMS to new rims without a problem.
      08-07-2012, 04:08 PM   #4
bavarianx
bavarianx's Avatar
219
Yes you can, however it is recommended that you replace the service kit (rubber seal) when you do so there is no chance of leaks.
      08-08-2012, 03:01 AM   #5
tiltmode43
I plead the 5th.
tiltmode43's Avatar
523
Drives: '18 Frontier Pro-4X, '06 Z4MR
Did not know this! Almost swapped in a set of '11MY TPMS to come aftermarket wheels thinking the later version would be F30 compatible - saved me a headache Bavarianx, thanks!
-Matt
| Z4M Build Thread | @violetnites | flickr |
      08-08-2012, 08:08 AM   #6
martinf79
martinf79's Avatar
191
Drives: 2020 G05 X5 M50i
Are TPMS sensors needed in Canada? Have been told that BMW cars in Canada do not use TPMS sensors. Can you confirm for the F30?
2020 X5 M50i | 2015 X3 28i xLine | Retired 2013 335i M Sport
      08-08-2012, 04:40 PM   #7
bavarianx
bavarianx's Avatar
219
E9X chassis it was NOT, however the F30 may start coming standard with them. Best bet is to ask your dealer if your vehicle has them via VIN look up.
      08-11-2012, 10:43 AM   #8
rwrwrwrw
No_Country
36
Drives: Car
2016 M235i  [0.00]
I have 328 Sport with standard 18in package and have the FTM system. Measures rotation not pressure of the tire. Not sure about M Sport.
      08-11-2012, 01:08 PM   #9
martinf79
martinf79's Avatar
191
Thanks - that gives me some reassurance that it will likely be the same for the M Sport for Canada
      08-20-2012, 12:01 PM   #10
Yobyot
Yobyot's Avatar
490
Drives: MY19 X3 M40i
I have a MY12 F30 335i that's arriving next week and I've begun investigating winter wheels and tires for it.
Tire Rack offered me a -1 (225/50R17) package of some fugly wheels, Michelin RFT snow plus TPMS sensors, mounting balancing and shipping for about $1700.
A guy in the BMWCCA is selling a set of four style 189 OEM 18" wheels plus some shoddy non-RFT snows for $500.
So, it's a toss up between buying the OEM wheels and fitting them with trustworthy tires (and optionally new TPMS sensors) versus buying the Tire Rack package.
Does anyone know what happens in the F30 if there aren't TPMS sensors in the wheels? If I buy non-RFT tires for the OEM wheels, I am not sure I need TPMS sensors because I could instantly tell if a tire is flat (and I'm manic about checking tire pressure at least monthly).
What do you think?
MY18 X3 30i:
Produced: 2018-03-15; Delivered: 2018-03-29
MY19 X3 M40i:
Produced: 2018-08-15; Delivered 2018-08-22
      08-20-2012, 01:02 PM   #11
tiltmode43
I plead the 5th.
tiltmode43's Avatar
523
What do you think?
I would guess that a TPMS light will come on in the dash, but nothing more. I haven't heard of a car that is equipped with TPMS and by removing the TPMS, causes any sort of real problems. Never hurts to confirm though!
Let's hear it from someone who has put wheels on with no TPMS
-Matt
      08-20-2012, 01:18 PM   #12
Yobyot
Yobyot's Avatar
490
Yeah, I suspected the light would be on. But would it stop there? For example, if you have BMW Assist (and I do), would this "check condition" cause it to call the dealer, as it's supposed to do when a malfunction is noted?
Worse -- and more speculatively -- would it cause the safety systems like ABS and DTC to change behaviors?
These cars are heavily digital. The wheels are there just to keep the computers from scraping the road. I doubt anyone really knows what the impact of no TPMSs would be in the car.
Still, it would be crazy, wouldn't it, to engineer a car so that something else failed if the TPMS sensors failed or were not present.
Maybe I can code the car to turn off a TPMS warning.
MY18 X3 30i:
MY19 X3 M40i:
      08-20-2012, 04:55 PM   #13
BMWinGE
32
Drives: BMW
where is the best/cheapest place to get new TPMS for the F30?
      08-20-2012, 06:23 PM   #14
cardnation
Güten Täg
cardnation's Avatar
No_Country
12
Drives: 91 E30 & 13 F30
I really like these guys (http://www.thebmwpartstore.com/), they are great to work with and super responsive.
2013 F30 328i Sport 6MT MG
1991 E30 318iC 5MT M20B25 swapped Vert Black - gone
      08-20-2012, 11:14 PM   #15
bavarianx
bavarianx's Avatar
219
On the E9X, if the system was run for long enough without TPMS the function would be locked in the warning position, in other words if you tried to add TPMS it would not register and needed to be re-flashed by the dealer to work again.
check our site, we have them with the valves included.
      08-21-2012, 02:10 AM   #16
brian99997
45
Drives: slowly
Am I missing something about TPMS in these cars? I can't seem to find where it reads the actual pressure that I am used to seeing in other cars.
If they just say low, why bother at all?
      08-27-2012, 04:32 PM   #17
bavarianx
bavarianx's Avatar
219
The sensors transmit the actual psi, but BMW decided not to include it in the interface with the driver...
      08-27-2012, 08:51 PM   #18
brian99997
45
Drives: slowly
hmm.. is there anything that reads them then? I wouldn't use the sensor data as a bible but the sensors in my P car were always quite close to what a quality hand held gauge would read
      09-01-2012, 08:46 PM   #19
RPM90
890
Drives: 340i M-sport AT
Search for a "coding" post by a member named "svache".
He has great information about items that can be coded.
Actual tire psi readout is available by coding.
I'm planning on doing it.
It's surprising that BMW didn't just include this as standard, considering it's already available within the system code. It just needs to be turned on. Odd.
      10-07-2012, 03:05 AM   #20
vegadonovan
Drives: F12 Black
Hello RPM90, have you tried it yet? I am also thinking of doing it but wondering if it's just about getting the sensors in the tires and then coding it.
      10-07-2012, 10:24 AM   #21
ocso1606
ocso1606's Avatar
42
Drives: 2013 335i M
2007 BMW 525xi  [0.00]
2010 Volvo  [0.00]
2013 BMW 335i M-Sport  [0.00]
What do you think?
Hope this still on topic.
I fail to understand the logic of not using TPMs. They are a safety feature - why make your car LESS safe?
They are not only for "lazy" people, who never check their tire pressure - they will warn you ahead of time that you will be getting a flat (even more important if you are not using runflats). Yes, "ahead of time", may only be 1-second or less, but that gives you time to reduce speed and prepare for what may happen (loss of control)....this has happened to me - I hope you never have to use any safety features in your car, but you'll be damn happy they are there when you do need them.
M5 with lots of goodies
      10-08-2012, 11:10 PM   #22
FDCT
FDCT's Avatar
Drives: 2015 M4
They are not only for people, who never check their tire pressure - they will warn you ahead of time that you will be getting a flat (even more important if you are not using runflats). Yes, "ahead of time", may only be 1-second or less, but that gives you time to reduce speed and prepare for what may happen (loss of control)....this has happened to me - I hope you never have to use any safety features in your car, but you'll be damn happy they are there when you do need them.
+1
Search this Thread:
Advanced Search
f30post
