08-01-2012, 04:33 PM | #1 |
13
Rep 82
automatic start/stopping problem
Good afternoon to you all. I was wondering if anyone has had problems with the auto start shut off thing. Mine stalls sometimes and doesn't come back on. Do you think this is a fuel pump problem? When it shuts off it says its been turned off and i didn't even turn it off WTF.... Anyone else?
08-01-2012, 04:44 PM | #2 |
592
Rep 3,870
r u sure ?
EDIT: what do you do that you think might induce or that you think should make the car come back on ? when it stalls and doesn't come back on... what do you do to continue driving ? and when there are no problems... what do you feel good about ? when you arrive to a complete stop or a red light... what does the instrument panel show on your car ?
08-01-2012, 04:45 PM | #3 |
woof
84
Rep 1,233
It is possible your vehicle needs a software update.
There was an update which addressed ASS issues, including something similar to what you're describing. Check with your dealer.
2013 F13 ///M6 Sakhir Orange 2013 F30 335i Estoril Blue II 2008 E92 ///M3 Interlagos Blue 2007 E92 335i Montego Blue |
08-01-2012, 05:49 PM | #4 |
288
Rep 1,892
I think the ASS fix was only for 335's. The original poster doesn't indicate which model this occurred on.
I have a 328 and have had ASS stall the engine on me once. The sequence was: 1. Engine auto stopped when I stopped at an intersection as it should have. 2. Engine tried to start automatically due to A/C demand, but stalled instead of starting. I did not remove my foot from the brake. 3. The car put up a message on the iDrive screen saying something like "the auto start/stop system has failed and is now disabled". The transmission (8AT) was automatically put into neutral. 4. I had to restart the engine and re-select D to continue. I now leave the ASS system off all the time. |
08-02-2012, 02:33 PM | #6 | |
13
Rep 82
yes i am sure.
As frogman says..... it is exactly what is happening. i have to restart the car and put it back in drive and i usually have to manually turn off the fuel saver thing. . I should go to the dealer right? Instrument panel says that the auto start thing is off when it doesn't come back on. As to your question about what i feel good about it? Everything mang!!! i had a 06g35 that i just got rid of. First off i love the fact that the tires are the same size. looks amazing. its fast as sh** and its a beemer. What else can you ask for. I 4.7sec is prolly right. |
08-02-2012, 03:20 PM | #7 | |
288
Rep 1,892
http://www.bimmerfest.com/forums/sho...d.php?t=636783 I already coded my car to do the same thing a while ago. When I turn it off, it stays off. |
08-03-2012, 12:07 PM | #8 |
90
Rep 2,707
Yay, congratulations BMW, you are back on my "possible purchase" list.
zhpregistry.net - ZHP stats and free classifieds.
08-03-2012, 12:23 PM | #9 |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
+1 this. Mine had the same issues OP describes, a software update later and it's been perfect.
FBO-PS1 and stuff
08-03-2012, 12:29 PM | #10 |
288
Rep 1,892
08-03-2012, 03:16 PM | #11 | |
28
Rep 75
I now always shut off the ASS. The only time I will ever considering using it in the future is in gridlocked stop and go traffic. In that situation if the engine stalls, I can restart it without affecting traffic around me. It's disturbing to hear people honk their horns at you not because of anything you've done but because your car has a system which supposedly should work but occasionally doesn't. If there is a future update, the only way I will hear about it is in this newsgroup. I definitely do not expect BMW to notify me of it. Last edited by sekitori; 08-03-2012 at 04:18 PM.. |
08-03-2012, 10:32 PM | #12 | |
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
08-04-2012, 01:38 AM | #13 | |
890
Rep 7,047
Have you considered to some coding on your 3? Svache has the codes and how to do it. We need to get a cable. Are you getting a cable? I'm not sure which one is needed, where we get it, or how much. I'm Svache knows. I'm willing to go in on it and we can code our cars to whatever we like. According to the service bulletin, if you complain to the dealer, then they can code the ASS to use "last mode". BMW should have put that in there from the beginning along with last mode for every drive setting too. It will be great to have ASS turned off, sport mode on, and AT use all 8 speeds. This is how I'd like my 3 to setup every time I start it. One thing I'd to code, if it's possible, is to allow the sport AT to use 7th and 8th gear even when in sport mode with the trans in auto mode. Right now, if it's in sport mode the trans will only use up to 6th gear. Does your 3 do this too? I hope it's possible to code it so that it uses all 8 gears even in sport or sport+. My 335i is due around the end of August. |
08-04-2012, 01:55 AM | #14 |
61
Rep 444
Since noone seems able to use the search function:
http://www.f30post.com/forums/showth...uto+start+stop Quote SIB 12 06 12" (Service bulletin 10 12 00 09 00) to your dealer and he should be able to find it on his system. If he can't, complain to BMW NA. |
08-05-2012, 11:57 AM | #15 | ||
Dejan
1753
Rep 4,197
As for the 7& 8th gears in sport, the trick I use is when cruising I just up shift to 8th manually in sport mode. It works good when on the highway. Sport mode, firm steering and suspension and still good fuel efficiency. Quote:
FBO-PS1 and stuff
08-05-2012, 05:03 PM | #16 | |||
31
Rep 70
08-05-2012, 09:27 PM | #17 | |
890
Rep 7,047
It seems really stupid though to have to do that. It makes no sense that BMW would program it that way. Just because we want the firmer steering and more responsive throttle, that doesn't also mean we don't want less engine rpm at highway speeds. I can see not going to 7th or 8th under say 60-65mph, but once we're at those speeds and above it should shift to highest gear. We paid for an 8spd 'automatic' and it should give us 8 gears in automatic mode regardless if we are in eco, comfort, or sport mode. It's such a glaring oversight. After may last test drive I've started questioning my decision to go AT. Too much BMW programming BS. That's one of the great things with MT, it's completely driver controlled without any button pushing hoops to jump through to get the gears you want when you want them. |
08-05-2012, 09:51 PM | #18 | |
32
Rep 1,285
If anything, I find BMW's sport mode to be less aggressive than I would prefer, particularly for cornering after a high speed/hard braking entry. It stays in a much higher gear than it should, and slogs around the corner. Tossing it into "manual" is a trivial fix for both minor issues. It's nice to have the flexibility. |
08-05-2012, 10:49 PM | #19 | |
Dejan
1753
Rep 4,197
FBO-PS1 and stuff
08-05-2012, 11:37 PM | #20 | |
890
Rep 7,047
Yet, if one is in sport mode and needs the drive gears at 65mph, then we could move the lever over to the trans sport mode, which already gives a more aggressive shift nature and also doesn't give you 7th and 8th. So why limit the top gear when in actual "auto" mode? It doesn't make sense to me, given there are already flexible choices and solutions for spirited driving in sport auto mode. I don't see the need to remove or not give that flexibility to drive in full auto with over drive along with sport mode without having to go to manual. I hope there is a code for it. |
08-06-2012, 02:27 PM | #21 |
Rep 1
automatic start / restart problems
Yes, I am having that problem also. My 2012 F30 335i delivered 5/31/12manual will not always restart after stopped in traffic: I usually have to push the clutch in a couple of times to get it to re-start as turning the steering wheel doesn't work. It is happening more frequently and my dealer has not been able to find a fix yet. I disable manually, but would like the feature to function properly. This is my 6th BMW, and otherwise I'm enjoying the car, but wished I had purchased a 2011 M3 as the F30 has less sportier handling than my previous 335i.
