F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > TPMS issue?
GetBMWParts
      07-30-2012, 12:39 AM   #1
AZ330FZL
47
Drives: 2012 335i Sedan Sport Line
TPMS issue?
Today I got into my car after work and the warning system came on saying I had a LOW tire, but it showed all 4 tires in yellow. Were they all low? Should it single out the one that is low? I would think with all the tech in this car it could tell me which one was the low tire. Thanks for the input.
AZ330FZL
      07-30-2012, 03:13 AM   #2
Gerusarus
Gerusarus's Avatar
South Africa
Drives: 2010 E90 323i Ex individual
Would also like to know!
__________
F30 320i Luxury individual on order
Currently driving E90 2010 323i Exclusive individual
Previously - E90 325i Exclusive individual, E46 320i Exclusive individual, Hyundai csi 1.5
      07-30-2012, 04:37 AM   #3
TonyS
84
Drives: F30 335i
The manual explains all this in detail, and the conditions whereby you might get multiple wheels showing as yellow. Have you read it?
      07-30-2012, 05:02 AM   #4
Gerusarus
Gerusarus's Avatar
South Africa
Only taking delivery of my F30 this week. I know that my E90 is showing all 4 wheels lost pressure when one has got a lower pressure that the other.
__________
      07-30-2012, 07:13 AM   #5
bcl0328
127
Drives: 2012 328i
no that is not normal. when my rear passenger got a nail in it only that tire showed yellow. the rest were green. did you reset it? maybe use nitrogen.
      07-30-2012, 07:16 AM   #6
jwilly
Drives: They're all white now.
What were the tire pressure gauge readings for all four tires when you checked them?
Joel
      07-30-2012, 07:48 AM   #7
bcl0328
127
Drives: 2012 328i
Joel
it doesn't tell you in idrive.
      07-30-2012, 09:05 AM   #8
chrisny
chrisny's Avatar
547
Drives: 2020 X5 40i
Well, it is normal if all 4 are low... And not normal if only one is.
Any drastic change in temperature or altitude or anything? Every winter in NY that will happen. Assuming that didn't happen through the course of your workday.. So just check them manually and you'll find out......
      07-30-2012, 09:22 AM   #9
BTT 335i
BTT 335i's Avatar
51
Drives: X5 F15 M Sport- F30 M Sport
Reset the tpms
      07-30-2012, 09:28 AM   #10
chrisny
chrisny's Avatar
547
Drives: 2020 X5 40i
Originally Posted by BTT 335i
Reset the tpms
After you check the pressure. Otherwise you're telling the car the low pressure is the right pressure.
      07-30-2012, 09:29 AM   #11
jwilly
I wouldn't expect iDrive to know the pressures, but a $10 tire pressure GAUGE would.
A gauge would also eliminate the need for this thread.
Joel
      07-30-2012, 09:36 AM   #12
bcl0328
127
Drives: 2012 328i
Joel
it actually does know, it just doesn't tell you without coding.
      07-30-2012, 11:52 AM   #13
bmwf30
Drives: F30 3351 xdrive Sedan
Take it to a BMW dealer or any other place that has Nitrogen. Fill up the tires with Nitrogen and this is help out greatly with the TPMS mis-reading. This is because Nitrogen is not affected by external temperature and pressure factors. Also if you should inflate the tire on an emergency you can use normal air when needed. Mixing it with the Nitrogen is perfectly ok.
Delivered!! 2013 335i xDrive Sedan, Mineral Grey, ZSL, 2A5, 4AD, 4DL, KCL3, ZAS, 3DZ, 2TB, 688, 508, 3AG, 494, ZTP, ZDH
      07-30-2012, 01:47 PM   #14
AZ330FZL
47
Did'nt have the chance till this morning. I did see that it should single out tires with issues. I was able to check tire presure also this morning once I found my guage and all tires were at about 30 psi. Was able to get tires to correct pressure today before work and reset TPMS.
      07-30-2012, 01:47 PM   #15
AZ330FZL
47
Joel
This morning they were all at 30 psi. I was able to add air and get the TPMS reset.
      07-30-2012, 01:49 PM   #16
AZ330FZL
47
I think that the temp change may have happened, I'm in Arizona and its been in the 100-115 range and a major storm came through yesterday and kicked the temp down to about 80, I did test the tires and they were low. Since been fixed. Thanks for the info.
      07-30-2012, 01:52 PM   #17
AZ330FZL
47
Thanks to everyone for the quick info. I was able to get the pressure set correctly this morning and get the TPMS reset. All tires back in the green. I was reading about the coding that will show you the actual PSI, thought that should just be standard, but something cool to maybe do in the future. Thanks again to all the posters!
AZ330FZL
      07-30-2012, 02:06 PM   #18
RPM90
890
Drives: 340i M-sport AT
AZ330FZL
IT should be standard by now. Since it's just a coding issue, then why not just put the friggin numbers up and be done with it!?
The rental Suburban we just took on a road trip showed individual tire pressures in psi. It even had a trans temp readout, useful for towing.
      07-30-2012, 02:25 PM   #19
Red Bread
4463
Drives: Smog machines
Nitrogen is still effected by temperature. I think what you're referencing is that since it doesn't have water vapor, it doesn't freeze like compressed air when used in airplane tires (which is where nitrogen has a sizable advantage).
http://www.tirerack.com/tires/tirete...jsp?techid=191
      07-30-2012, 06:44 PM   #20
jwilly
Good to hear that you figured it out.
Joel
      08-07-2012, 04:12 PM   #21
bavarianx
bavarianx's Avatar
224
Drives: 2006 X5 4.4i
30psi is close to the cutoff for low pressure warning, you may want to run about 33-34psi, since temp will make the pressure change +/-1-2 psi
      11-15-2012, 11:20 AM   #22
mariodoceye
Drives: BMW F30 320d
f10 19 inch wheels to f30 320d
Hi. I'm getting my 320d tomorrow with stock 414 17inch wheels with run flats. I already have seen 19s that I want to put on. Can I transfer the TPMS to the new rims and reset them on iDrive?
f30post
