M3 style cluster mod done, now a needle issue!
07-29-2012, 08:28 AM | #1 |
30
Rep 540
Hi guys!
Did the smd colour change there yesterday and swapped the needles over for m3 ones. Only problem is that every time I start the car for a few seconds, the fuel needle seems to reset itself lower and lower until it's way way below 0. It takes about 4 on/off cycles before it's nearly pointing west. What have I done and how can I sort it? |
07-29-2012, 10:57 PM | #2 |
124
Rep 1,151
Drives: 10 e90 335i
I have not seen this one before! Sorry, not any help!
JB4, DP, VMR V710, Sonic Tuning S1 coilovers, Hybrid Ovations, Soundsplinter 10" and Zapco DC Ref amps |
07-30-2012, 04:37 AM | #3 |
30
Rep 540
It is a strange one - i was too gentle to physically break or dislodge something, and the mechanism still moves smoothly.
I wonder is the needle too loose and is slipping in one direction only. |
07-30-2012, 10:52 PM | #4 | |
88
Rep 1,404
http://www.e90post.com/forums/showth...ighlight=gauge
Name: Blanca | 07 E92 | AW-Blk | ZSP | Alcon BBK | M3 Bits | VM RR Links | Koni | UUC Sways | V5 | Dinan CAI | ETS IC | Fge DV | ER CP | Cyba | Raden. Exh | Mod Step | Trunk Drawer | Perf LED Wheel | Illum Dr Sills | IS Shifter | Parrot | Philps D1S | 6000k fog | MTECH RR | CSL Trunk | Aero | Roof Spoiler | PSS on BBS RS-GT 19s
07-31-2012, 07:06 AM | #5 |
30
Rep 540
Thanks for the suggestion!
Got a good hoke at the cluster yesterday, and tried putting on the original needles. Guess what, worked perfectly. Think the issue might have came from the fact that these were M5 needles modified to fit the e90/92 servo pins. I had shortened the needles poles but think they were too long and were catching on the mechanism. Also, BMW must use some awesomely bright LEDs for the M3 cluster as the ones I used aren't quite bright enough despite working well in other car clusters I'd done! I'm sure this isn't the end on this saga as I'm determined to get these M5 needles working! |
08-01-2012, 11:16 AM | #6 | |
Rep 256
If I remember correctly, it's because there are multiple resistors in place to gimp the voltage. There was a thread on this long time ago with a picture of which resistors to remove. |
08-01-2012, 03:44 PM | #7 | ||
30
Rep 540
08-02-2012, 03:59 PM | #9 |
Rep 82
OP,
I think this is the one you're looking for: http://www.e90post.com/forums/showthread.php?t=551804 Really helped me out when I did the M3 rings/needle install. Edit: NVM...wrong link that was already posted. |
