      07-26-2012, 01:40 PM   #1
HP Autosport
Supreme Allied Commander
3842
Drives: F80 M3
Smile BMW 1M HD adjustable anti roll bar end links
When you lower your 1M with coilovers, the swaybar is moved from the ideal factory geometry to an offset that decreases the ability of the swaybar to perform. The swaybar frame mount and the end of the bar should be on the same horizontal plane. The factory end links are a solid piece. When the car is lowered, the OEM links cannot compensate for the longer length needed to keep the swaybar in its ideal location. Get immediate response from your sway bar and precise control over your suspension. What this means to you is tighter, more responsive handling.
HP Autosport is happy to introduce these HD adjustable end links. With adjustable end links you can return the bar to its ideal leverage point while lowered. They also afford the peace of mind that the links or shock link mount will not fail as is common in factory units, as they will now be adjusted properly. The links are adjustable in length up to an additional 1.25" over stock. HP Autosport end links are adjustable while on the vehicle.
***Not designed to be used on OEM struts***
These end links will fit the following vehicles:
E82 1M and E9x M3
$159.99 pair
Order here:
https://hpautosport.com/product/hp-a...ybar-endlinks/
Having trouble removing the nut or it just spins freely? If your joint/stud has a place for a wrench, these will hold the joint/stud in place to allow you to remove the nut:
https://www.amazon.com/DURATECH-Supe...&creative=9325
      01-12-2016, 07:38 PM   #2
HP Autosport
3842
Drives: F80 M3
bump
      02-07-2016, 02:44 PM   #3
HP Autosport
3842
Drives: F80 M3
bump
      02-19-2016, 04:52 PM   #4
HP Autosport
3842
Drives: F80 M3
Bump
      03-07-2016, 10:41 AM   #5
HP Autosport
3842
Drives: F80 M3
bump
      03-31-2016, 03:21 PM   #6
HP Autosport
3842
Drives: F80 M3
bump
      04-25-2016, 02:14 PM   #7
HP Autosport
3842
Drives: F80 M3
bump
      05-11-2016, 02:00 AM   #8
HP Autosport
3842
Drives: F80 M3
in stock
      05-31-2016, 12:37 AM   #9
HP Autosport
3842
Drives: F80 M3
bump
      06-16-2016, 06:27 PM   #10
HP Autosport
3842
Drives: F80 M3
bump
      07-06-2016, 10:39 AM   #11
HP Autosport
3842
Drives: F80 M3
bump
      07-21-2016, 05:56 PM   #12
HP Autosport
3842
Drives: F80 M3
bump
      08-10-2016, 10:12 AM   #13
HP Autosport
3842
Drives: F80 M3
bump
      08-24-2016, 05:58 PM   #14
HP Autosport
3842
Drives: F80 M3
bump
      09-11-2016, 08:14 PM   #15
HP Autosport
3842
Drives: F80 M3
In stock
      09-28-2016, 02:49 PM   #16
HP Autosport
3842
Drives: F80 M3
bump
      10-13-2016, 11:10 AM   #17
HP Autosport
3842
Drives: F80 M3
bump
      10-25-2016, 06:16 PM   #18
HP Autosport
3842
Drives: F80 M3
bump
      11-06-2016, 01:06 PM   #19
HP Autosport
3842
Drives: F80 M3
bump
      11-18-2016, 10:19 AM   #20
HP Autosport
3842
Drives: F80 M3
bump
      11-30-2016, 12:30 PM   #21
HP Autosport
3842
Drives: F80 M3
cyber week 10% off in stock
      12-15-2016, 11:46 AM   #22
HP Autosport
3842
Drives: F80 M3
bump
1addicts
