A/C output temperature question. Is this normal?
07-25-2012, 12:06 PM | #1 |
27
Rep 600
Question to those who truly know about BMW A/C's:
From reading here and there, I am finding that the AC output should blow 45 degrees once the car has been running a few minutes. This holds true in my case, however, it takes a while to get there maybe say 10 minutes of fast driving. When I'm stopped at light or not going fast, it goes up to 52 degrees. Is this normal? Just wondering if I should take my car in to get the A/C system checked. Comments or input welcome. Thanks, Jay Last edited by JRJ1970; 07-25-2012 at 01:41 PM.. |
07-25-2012, 03:13 PM | #4 |
27
Rep 600
Don't laugh but I'm using a "stick" like gauge that I use to froth milk for my cappucinos. It's basically a long stick with a round gauge at top that goes from 40 to 220 degrees. It's stuck inside the AC output vent now. I wish I had a laser type one but don't have access to one.
Jay (in San Antonio, TX)
2014 428i coupe, mineral gray metallic with black interior, black ash trim, luxury edition. |
07-25-2012, 03:23 PM | #5 | |
17
Rep 276
Oh, and I consider myself very far from someone who "truly knows about BMW A/C's", so feel free to dismiss my post ;-) |
07-25-2012, 04:02 PM | #6 |
Rep 204
I had a similar issue. My A/C was taking a very long time to get cold, but when it did, it would be ok. Took it to the dealer and they found a leaky evaporator. Fixed under warranty.
07-25-2012, 05:20 PM | #7 | |
535
Rep 1,873
Check your thermometer against ice water (32F) too. Check your vent temperature with the set point at minimum, recirc on, fan speed at minimum and blend wheel all the way to blue. From there, the more load you put on the system (insufficient cooling at the condenser, higher fan speeds in the interior, higher temperature and humidity in the interior) your temp will start to go up as soon as the system can't keep up any more. If it's truly horrid you could always get it checked. |
07-25-2012, 08:24 PM | #8 |
New to BMW
Rep 70
I was having the same issue in my 335is here in Vegas. Temps in the triple digits everyday and just thought it was the outside temp causing the slow cool down. Turns out it was a clogged up cabin filter that was causing the prob, BMW replaced it and wow, blows hard and cold again even sitting at a light or in the drive way.
2011 335is Coupe - S Gray/Red. Prem, Conv & Cold Weather Pkg. DCT, Navi, Harman w/Sat, Ipod & USB, Mats, Tint. MSRP $62,225 - Paid $57,449 OTD
07-26-2012, 01:38 AM | #9 |
13
Rep 94
My AC sucks ass. It doesnt blow cold at all, and if the inside of the car is the least bit hot, it takes forrreeeevvvverrrr to cool off. My Z4 AC was 10X better.
07-26-2012, 09:26 AM | #10 |
124
Rep 5,627
07-26-2012, 10:50 AM | #11 |
13
Rep 94
07-26-2012, 06:56 PM | #12 | |
124
Rep 5,627
Tom |
07-27-2012, 12:15 PM | #13 |
60
Rep 965
Drives: '14 328xi sport line
Garage List 1981 Fiat 124 Spider [0.00]
2014 F30 BMW 328xi [0.00] 2006 E90 BMW 325i ( ... [0.00] 1988 Audi 90 Quattr ... [0.00] |
Mine blows cold after a good 10 seconds just after I start my car.. I'd get it checked out. I've never had my a/c serviced before, but I do change my cabin air filter myself once a year.
07-27-2012, 12:38 PM | #14 |
27
Rep 600
OP here. Checked out at the dealer and all systems normal. It's cold from the start at 45 degrees and then lowers to 41 degees when driving fast. It just takes a while to feel it in the car..... I need to invest in window tint and park this 'vert in the shade. I don't think the black leather interior and living in TX helps either....
Thanks all for your input.
