IAT Issue with Procede Rev3 5-23?
07-25-2012, 12:29 AM | #1 |
17
Rep 126
Running 5-23 Stage 1 on Rev3 w/ catless DPs and ER FMIC. Everything seems good, but boost seems low to me and power seems down a bit (will try and post a few datalogs in the morning as they are on my work PC).
The only thing seemingly weird so far is my IATs. they stay pretty much pinned at 83 degrees C regardless of load/rpm/boost/etc. It's been about 70 degrees F here for the past week, so why are my IATs showing so insanely hot, even at cruise? do i have a bad IAT sensor? Thoughts? Based on the IAT Boost Correction map, the Procede should be pulling boost by 2lbs+ if its seeing 80 degrees C at the Inlet, so that would make sense why boost seems a little low and power feels down a bit. Any insight would be great. I have a few codes, but they are all NLS/2-step related (11800+). Thanks
2022 M3 Comp XDrive - BSM on Silverstone - CCB - Exec Pack - CF Buckets - CF Ext and Int package - KW HAS Kit - Awaiting Delivery
1993 Porsche RS America - Polar Silver on Black - 229 of 701. Motion Control Coilovers - BBS LMs - 993TT Big Brakes - Roll bar - Recaro Sportster CS's - Golden Rod/Rothsport SSK - Full Race Billy Boat Exhaust - ERP camber kit |
07-25-2012, 12:43 AM | #2 |
1743
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Try downloading the new user software. There was an older version of the software that had a labeling error (degC should have been degF). It didn't effect the tune at all since it was just a display error. But it would certainly raise an eyebrow if you were reviewing datalogs. If you want to fix this quickly, just go to the data logging channel set-up and select Inlet Air Temp. Click on set-up and change "Deg C" to "Deg F". Simple as that.
07-25-2012, 12:51 AM | #3 |
17
Rep 126
OK. Will try that first thing. I am pretty sure i have the latest software as i downloaded it on Sunday
If it was just C in place of an F, then all is good. But shouldn't i see some rise in IATs under a 2nd through 4th WOT pull? It didn't go up at all. Just stayed bouncing around between 81 to 84. If all is good, then i'm seriously impressed with the ER FMIC!
07-25-2012, 12:58 AM | #4 |
76
Rep 1,883
Log your IATs from cold start up and see what they do. Then you'll know the initial conditions and you'll be able to make an accurate assessment of real values to logged values.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
07-25-2012, 01:33 AM | #5 | |
1743
Rep 17,960
Drives: A Lot
07-25-2012, 01:36 PM | #6 | |
17
Rep 126
07-25-2012, 01:52 PM | #7 | |
1743
Rep 17,960
Drives: A Lot
07-25-2012, 01:59 PM | #8 | |
422
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
07-25-2012, 04:23 PM | #9 | |
17
Rep 126
07-30-2012, 06:03 PM | #10 |
17
Rep 126
Through on the DCI and still running Stage 2 5-23 maps. Need to run some datalogging but am impressed to see the car building boost much more quickly with the DCI. I honestly thought i wouldn't be able to tell that much. Much harder acceleration at part throttle and better pull at WOT too. Gonna load stage 3 today and then check IATs again and we how they are doing.
