E90 N52 Radiator Change
07-18-2012, 01:49 PM | #1 |
Rep 16
Hello all,
My radiator has a slight leak and I have new one coming in Friday. I have changed radiators on other cars that were simple as pulling them out the top. Having worked on this car in the past, I know most things are not simple (damn starter took me 5 hours!). Any tips and things I should know would be appreciated! Joseph |
07-18-2012, 09:41 PM | #2 | |
17377
Rep 18,773
Remove the radiator cooling fan: The fan comes out as a whole unit. It is secured with one regular torx screw and a thumb clip on the left side. It sits on plastic mounts on the bottom of the radiator. To remove it: • Remove the silver-colored torx screw on the upper right side corner of the fan unit. • Remove the temperature sensor electrical connector on the lower radiator hose. Push the wire clip in and pull the connector straight back. • Remove the electrical connector for the fan motor it; it is on the left-side of the unit next to the fan motor. • Move the small tube that is part of the coolant over-flow hose; it snaps in mounts on the radiator. • Move the electrical harness out of the way. It mounted along the water tube. • Look for the thumb tab on the left side of the unit (about half-way) down. Push it in and pull up on the whole fan unit. • Move the unit back and to the left to clear the lower radiator hose, and then pull the whole unit up and out. |
