E9x BBK using the F30 Brembo Caliper
07-18-2012, 08:29 AM | #1 |
E90 335i n00b
Rep 20
So I have been searching for a few days looking to confirm this setup and trying to find part numbers to confirm my research.
I would like to ask a few questions to see if this can be cleared up. I would like to fit the F30 front calipers to my E90 335i stock rotor size of 348x30 and within the sport style #161 17" wheels. Does this fit? From my research this is what I have found F30 Stock - Front rotor is a 340x30 w/ Brembo Calipers part #'s L/34 11 6850931 R/34 11 6850932 F30 M Package - Front rotor is a 370x30 w/ Brembo Calipers part #'s L/34 11 6799469 R/34 11 6799470 Brake Pads Stock 340mm rotor - part # 34 10 6799805 Brake Pads M 370mm rotor - part # 34 11 6857968 Sensors - part # 34 35 6792289 Bolts - M12x1.5x43 (4 required) part# 34 11 6772117 Are the Calipers the same just an "M Sport" paint package, with larger rotors and a different spindle? F30 Stock Caliper? (HP Autowerks R&D Pic) F30 M Package Caliper (Tuner Motorsport)
Driver Found "More Money" Wanted
10 335i Titan Silver - X-Drive/Nav/Sport/Adpt Cruise 05 Touareg Gray 4.2L - Air Susp/Xenon/Nav/Paddles/Keyless Start/Rear Ent |
07-19-2012, 08:52 PM | #2 |
Rep 66
http://www.e90post.com/forums/showthread.php?t=655274
lot of info here |
07-20-2012, 07:22 AM | #3 | |
E90 335i n00b
Rep 20
Can someone confirm that this will still fit the 17" Sport Wheels (Style #161)????
07-23-2012, 11:11 PM | #5 |
89
Rep 1,529
okay, more research leads to the fact they dont fit due to the brake pad size and the a minimum of 19" wheels are required to fit them. what a loss since most of us run 18s dd and 17s at the track.
07-24-2012, 09:21 AM | #6 | |
E90 335i n00b
Rep 20
Only the 335is & M Package runs 18" / Standard F30 335i & X-Drive have 17" Wheels?????
10 335i Titan Silver - X-Drive/Nav/Sport/Adpt Cruise 05 Touareg Gray 4.2L - Air Susp/Xenon/Nav/Paddles/Keyless Start/Rear Ent Last edited by 335iTitan; 07-24-2012 at 09:28 AM.. |
