Differential oil
07-18-2012, 07:23 AM | #1 |
43
Rep 568
Differential oil
Hi,
Just wondering that instead of using a pump and getting the oil via the diff bolt, why can I not remove the differential back cover so I am sure all the oil is out? Any reason for not doing this (except the mess)? Thank you. |
07-18-2012, 07:43 AM | #2 |
47
Rep 1,160
I wouldnt see a problem either, maybe youd have to replace a gasket if you did so.
Monaco Blue 330xi - Terra Interior/6-MT/Sport/Premium/Cold/CSL's/M3 Spoiler Lip/Black Kidney's
07-18-2012, 08:13 AM | #3 | |
535
Rep 1,873
I don't believe there's any reason you can't do it, but you substantially increase the risk of "collateral damage" from a routine maintenance service. Do you know the precise torque specs? Is there a specific torque order? Any one-time fasteners (stretch bolts or whatever) used? What if something does go wrong? I'd recommend having a gasket and at least one new bolt on hand in case something goes wrong. This is another case where overmaintaining a car actually makes things easier. If a fluid is changed "early" it doesn't matter if you only get 80-90% of it out because it's still in good shape. If you push your intervals as far as you can then you feel more compelled to get every last drop of filthy, expired fluid out of whatever it is you're working on. I think I saw comments from Mike Miller quoted somewhere indicating that for the first time the longevity of a BMW MT driveline "remains to be seen" with the E90. For decades they've been overbuilt and you can have a high degree of confidence that they'll last forever. Now they made the gear rings smaller, cheapened the design of some key bearings etc... This tells me that high quality, aggressive fluid changes are more important than ever. Let us know how it goes and if you run into anything interesting. Having no drain bolt is really annoying and frustrating to an over-maintaining DIYer like myself. |
07-18-2012, 11:04 AM | #4 | |
43
Rep 568
I'll let you know how it goes. |
07-18-2012, 09:46 PM | #5 |
17384
Rep 18,774
You don't want to try it. There is a big-ass bushing attached to the rear diff cover. You have to remove the bushing bolt and the bushing and drop the diff to get the cover off. It's NOT like pulling the diff cover off of a pickup truck. My advice is use a pump. Then you have to replace the diff cover gasket, but it's cheap, under 2 bucks.
07-19-2012, 06:21 AM | #7 | |
535
Rep 1,873
I have a 2007 328i 6MT sedan, if it makes any difference. |
07-19-2012, 11:08 AM | #8 | |
40
Rep 818
I measured how much I pulled out with a regular pump, and I could see that I wasn't getting it all - I was at well under a qt, and changed to a vacuum brake bleeder with a thinner more flexible hose that got to the bottom of the diff. When I filled, it took 1.2 qt., so I'm confident that I got 95+% of the fluid.
I had posted the comments by Mike Miller saying the diff is now under-built, and that is critical to change the fluid on a more frequent basis. He recommends Redline. Quote:
