Hey..you guys seen this? E90 Alcon brakes from StaSIS?
07-12-2007, 10:04 AM | #1 |
431
Rep 4,380
Drives: 2014 Audi A4 / 91 Track Miata
I was looking for something for a friends Audi on StaSIS engineering's website..and I saw this for E90. Dont know if it would work on the 335i...but I can check.
Looks like the kit lists for $3295... Monobloc4 - 365mm (14.4") Big Brake System One look says it all - high performance, ultra-refined technology and style with massive gripping power. Nothing screams from behind the spokes like an Alcon-based braking system from STaSIS. What It will do for you: NO MORE FADE Higher heat absorption and dispersion makes for shorter stops turn after turn IMPROVED PEDAL FEEL Firm, confidence-inspiring brake pedal because of ultra-stiff calipers, differential piston sizing and stainless steel braided lines. SAY NO TO WARPED ROTORS Properly Designed 2-Piece Floating Rotors = Quiet, warp-free performance QUICKER REACTION TIME Short, consistent pedal travel can save your life in a panic situation SHED THE POUNDS Less weight gives shorter stops, quicker acceleration, improved steering feel and handling LOWER LONGTERM MAINTENANCE COSTS Cutting edge design = durable, low-cost system COMPATIBILITY & EASE OF INSTALLATION Compatible with ABS and traction control systems with brake bias designed to ensure ultimate gripping power. All hardware is included to ensure a quick and seamless installation. ---------------What's In the Kit: ----ALCON 4 Piston Monobloc Calipers - --ALCON 365mm(14.4") Floating Rotors ----STaSIS Caliper Mounting Bracket & Hardware ----Goodridge Stainless Steel Braided Lines ----Motul brake fluid ----SBS Hi Performance Brake Pads ---------------------------------------------------------------------------- StaSIS knows their stuff. I am real good friends with the owner...Paul Lambert. They campaign three Audis in Speed World Challenge Touring Car. BTW, I am not getting compensated in any way by posting or promoting this option..I just happened to see they had a kit..and I thought some of you might be interested in it. That is all.
Car is now gone .... :-( |
07-12-2007, 04:58 PM | #3 | |
431
Rep 4,380
Sorry if it came off as an ad. I can talk to them about potentially becoming an advertiser here if that is necessary.
Car is now gone .... :-( Last edited by S4to335; 07-12-2007 at 05:45 PM.. |
07-12-2007, 07:33 PM | #4 |
grand poobah
254
Rep 2,253
No, it's cool. I was just reading and thinking "This sounds like an ad off their web page" then I got to your disclaimer.
07-27-2007, 01:58 PM | #6 |
431
Rep 4,380
Ask Eric at Supreme Power..he was trying to work with someone to come up with some.
