kidney grills just pull out on 09 E93?
07-11-2012, 11:22 AM | #1 |
Rep 86
I'm pulling pretty hard, but don't want to break anything. Need to get behind there to repair the stupid holes from the front license plate.
Thanks, -J |
07-11-2012, 11:31 AM | #2 |
194
Rep 6,136
It's held by plastic clips. If you apply even pressure it should come out. If you are having trouble you could also use a flathead on some of the tabs while someone else pulls.
07-11-2012, 11:37 AM | #3 |
1086
Rep 1,912
Get your fingers in between the slats and then feel along the inside edge of the grille. You will feel little plastic tabs. There are two on the bottom, one on the outside edge and two on the top (on the e90, e93 should be the same)... once you undo the lower three bend the grill up and out a bit and it will pop right off of the two on the top edge.
