OEM headlight ballasts and bulbs for fogs?
07-10-2012, 04:19 PM | #1 |
Going Mach Chicken
Rep 92
Drives: e90 pre-LCI 335
Well, so I pulled the trigger and bought Guerillah's (thanks man!) lci ahl's to replace my pre-lci ahl's. My original plan was to sell the ballast/bulbs/etc. from my pre-lci headlights but I got to thinking.... has anyone used these parts to convert their fogs to hids? I did some searching and couldn't find anything related. Off hand I can think of a few things that could be a problem:
1) Where to mount the ballasts 2) Waterproofing everything 3) Would the bulb even fit? Honestly don't know. What are your guy's thoughts? I'm not really set on trying this, but figured since I have to pull the bumper off anyway to replace the headlights I might as well do something with the fogs.
'07 335xi, Alpine White
| Cold, "Sport", and Luxury packages | Tinted | OEM Black Lines | JB4 | DCI | ER FMIC | Forge DV's | Custom exhaust with secondary cat delete, Magnaflow mufflers, black Dimisa Tips | Staggered 18" V718's, Matte Black | Flappy Paddles | Titanium CF Trim Wrap | BMW Performance Shifter and E-Brake Handle | Last edited by RequestTheOverhead; 07-10-2012 at 04:20 PM.. Reason: can't spell worth a crap |
07-10-2012, 10:39 PM | #2 |
Going Mach Chicken
Rep 92
Haha, nothing huh! So... I'm going to take this as a no, not possible. Oh well, looks like I'll be looking for some HID fog kits!
| Cold, "Sport", and Luxury packages | Tinted | OEM Black Lines | JB4 | DCI | ER FMIC | Forge DV's | Custom exhaust with secondary cat delete, Magnaflow mufflers, black Dimisa Tips | Staggered 18" V718's, Matte Black | Flappy Paddles | Titanium CF Trim Wrap | BMW Performance Shifter and E-Brake Handle | |
07-11-2012, 12:12 AM | #3 |
Where'd my VTEC go?
481
Rep 6,067
easier to just get a HID fog kit. ballasts wont be weather sealed when not used with the headlight housing, and the bulbs are completely different. not to mention the connectors for the fogs are also completely different.
congrats on the LCIs btw! i was eye those hard, but just couldnt get myself to drop the cash.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
07-11-2012, 12:32 AM | #4 | |
Going Mach Chicken
Rep 92
Cheers!!
07-11-2012, 09:07 AM | #5 |
Brotographer
88
Rep 1,741
it could be done, but it would be quite a bit of work! you could, I suppose, "pot" the ballast (waterproof it), build a projector fog housing with the morimoto matchbox projectors, convert the D2S socket to a D1S socket on the projectors, build a wiring harness, and weather seal the whole thing...but that's a lot of effort.
here's what I would do--retrofit the morimoto matchbox projectors from "the retrofit source", and get a morimoto D2S HID kit and the appropriate wiring harness to make it work! you can email the retrofit source and they can help you build a custom kit that will do everything you need. or you can drop in a morimoto hid kit in to your reflector fog housings, code, and call it a day. or, you can drop a HighPerformanceBulbs kit in to your fogs, not code, and call it a day! |
